So it seems like some
owners want to go slightly advanced but instructions for installing the DFU-driver is a little vague.
How to put your core in DFU-mode
- Press on BOTH buttons
- Release only the Reset button
- Release the Mode button once the core start
blinking yellow - This will be the dfu-mode
Pre-check!
If you have somehow done this process previously but is unable to use dfu-util successfully, you will need to uninstall the DFU-driver 1st
- Put your core in DFU-mode
- Open Control Panel
- Look for something like
libusbk USB devices - Right-click and press âuninstallâ. Make sure you
'check'the > âdelete the driver softwareâ
Installing DFU-driver
Place the
core in DFU mode -
Run Zadig program
- Go to http://zadig.akeo.ie/
- Under âdownloadsâ grab the (windows vista and above or windows xp) -
In Zadig, Click on âOptionsâ --> 'List all devicesâ
- Select âCORE DFUâ and âlibusbKâ for the driver. Press 'Install Driverâ
So far, âlibusbKâ is proven working with the
core
- It will show âDriver installed successfully!!!â (ok not so many ! :))
Using DFU-UTIL to test that driver works
WARNING: Make sure you are using DFU-Util 0.8
https://s3.amazonaws.com/spark-assets/dfu-util-0.8-binaries.tar.xz
MD5 hash: 9a7b0594881c9ba8480bdc9956b5b01a
Launch âcmdâ (make sure your path is that where dfu-util.exe is)
Type
dfu-util -l -
You should see:
Adding DFU-util to Windows path
Follow the instructions here: http://windowsitpro.com/systems-management/how-can-i-add-new-folder-my-system-path
This will allow DFU-util to be executed globally in command prompt.
*If you miss out this step, Spark-cli will be grumpy!
Updated on: 24 Feb 2015
Thanks @peetersm for testing and proving this method works
cloud to compile your code folder and return a .bin file.
