Error writing firmware... dfu-util not installed
After entering the command ‘particle flash --usb tinker’ the following message is
‘running dfu-util -l’
and
‘Error writing firmware…dfu-util is not installed’.
Photon is breathing cyan connected to USB. I am trying to connect a Nexus 6 tablet to Photon over WiFi using the Internet.
How do you install dfu-util in Windows 10?
Just download it, save it somewhere and add it to the PATH.
You can also use
particle flash -serial tinker
which doesn’t require dfu-util.
