ScruffR
November 26, 2016, 12:12pm
5
Photon in DFU Mod e should not be listed as Universal Serial Bus Device .
In order to use it in DFU Mode you need to install the DFU drivers via zadig as shown here
So it seems like some owners want to go slightly advanced but instructions for installing the DFU-driver is a little vague.
How to put your core in DFU-mode
Press on BOTH buttons
Release only the Reset button
Release the Mode button once the core start blinking yellow
This will be the dfu-mode
Pre-check!
If you have somehow done this process previously but is unable to use dfu-util successfully, you will need to uninstall the DFU-driver 1st
Put your core in DFU-mode
Ope…
But as it seems you don't even have dfu-util installed, so I'd recommend to uninstall CLI and install the full package with this
https://binaries.particle.io/cli/installer/windows/ParticleCLISetup.exe
