HOWTO: Update CC3000 via DFU-util (windows)
##NOTE:##
The .bat script is written and .exe files zipped up by me. If you are not comfortable using the .exe from the download link, please give this tutorial a miss. :wink:
Hey there!
Is your :spark: core having difficulty connecting to Wifi?
Geting confused over how to flash the cc3000 patch file via USB?
This should help you get going! :smiley:
STEP 1: Place Core in DFU MODE
1.) Press BOTH buttons and release ONLY the RST button
2.) Wait for the RGB LED to BLINK YELLOW and release the MODE button
STEP 2: Install DFU Driver
1.) Download zatig.exe from http://zadig.akeo.ie/
2.) In Zadig, Click on ‘Options’ --> 'List all devices’
3.) Select ‘CORE DFU’ and ‘libusbK’ for the driver. Press 'Install Driver’
So far, ‘libusbK’ is proven working with the :spark: core
4.) It will show ‘Driver installed successfully!!!’ (ok not so many ! :))
STEP 3: Download Bundled Package
1.) Download from: http://limsimiteh.com/kenneth/download/spark-dfu-flash.zip
2.) Inside the folder, you will see:
3.) Click on DFU-flash-script.bat
This will appear:
4.) For CC3000 patch, key in 1 and hit ENTER
*Make sure core is blinking yellow (DFU mode)
5.) Downloading will start!
6.) The sequence for CC3000 patch will be as such:
Blinking Magenta --> Blinking yellow
7.) The next step is to flash a binary file
Run DFU-flash-script.bat again and key in 2 and hit ENTER
8.) Your core will now download the stock tinker app and restart!
hi can you help me…On step 4 : when I click on the button 1 it said that dfu util not recognised what does it means.
HELP ME PLEASE.
Have you got dfu-util installed and in your path?
Check in a console (cmd) and type dfu-util.
If it can’t be found have a look here (for example)
http://dfu-util.sourceforge.net/
