hi guys,
i am using spark core(tiny wifi),i need to install patch for CC3000,i need to install dfu-util for windows,i am not able to find the software,can u upload me the dfu driver for windows as soon as possible.
thank you
hi guys,
thank you
hey @aadhavanshines,
you can download via the link mentioned here:
hi,
i am unable to install Dfu-util for windows,pls help me through the procedures
Did you download from: http://dfu-util.sourceforge.net/releases/dfu-util-0.8-binaries/win32-mingw32/dfu-util.exe ?
Once you have downloaded, you can use it via the command-line. Simply cd to the path containing the dfu-util.exe and execute the commands accordingly
whil
hi,
while executing the dfu-util i am gettng system error,kindly help me with this
Hmmm… try downloading the .dll from the site and test again?
thanks for the help i have installed the dfu-util.exe,
i have turned on spark core in dfu mode, when i try to execute the command spark flash --usb cc3000 ,i get the following error pls help with this
Seems like a dfu error that was not able to clear.
How did you install the driver for DFU? Try executing the command and see what happens
I have installed using Command prompt only,i have checked in command prompt whether dfu-util.exe is installed or not by dfu-util -l,it shows following details
Try executing the command again and see what happens.
Also, make sure you are running the command prompt as an Adminstrator
i have tried as admin but i am getting the same error message
Can you try installing the DFU driver with this instructions?
Hi I have found a working DFU utility that works here is the Link https://community.spark.io/t/latest-2014-dfu-util-for-windows-compiled/5264/13
download it from here https://dl.dropboxusercontent.com/u/54378433/dfu-util/dfu-util.exe
cheers
Meth
