Help programming cc3000 with dfu util. thanks
Im trying to reflash the core but Im getting this when I try:
Please help
vvvvvvvvvvv
D:\Firmware>dfu-util -l
dfu-util 0.8
Found DFU: [1d50:607f] ver=0200, devnum=2, cfg=1, intf=0, alt=1, name="UNKNOWN",
 serial="UNKNOWN"
Found DFU: [1d50:607f] ver=0200, devnum=2, cfg=1, intf=0, alt=0, name="UNKNOWN",
 serial="UNKNOWN"
D:\Firmware>spark flash --factory tinker
FOUND DFU DEVICE 1d50:607f
checking file  C:\Users\clayton\AppData\Roaming\npm\node_modules\spark-cli\binar
ies\spark_tinker.bin
spawning dfu-util -d 1d50:607f -a 1 -i 0 -s 0x00020000 -D C:\Users\clayton\AppDa
ta\Roaming\npm\node_modules\spark-cli\binaries\spark_tinker.bin
dfu-util 0.8
Invalid DFU suffix signature
ID 1d50:607f
Claiming USB DFU Interface...
Cannot claim interface
Error writing firmware...
D:\Firmware>
From the D:\ I’d guess you’re on Windows.
Have you taken all the steps outlined here
In my case I missed the Zadig part at first - once I had this sorted it worked.
Yes I did use Zadig but the win32 driver.
Maybe the wrong one.I will try it again with the one in your post
It’s working now by changing to the plain driver for usb.
Thanks for you help
