LC: Core goes flashing green after keys swap
Hi @kennethlimcp :slight_smile:
Got a new core recently, and I’m also facing the flashing green forever issues.
I tired the method highlighted in this thread.
  1. Did dfu-util -d 1d50:607f -a 0 -s 0x08005000:leave -D cc3000-patch-programmer.bin
Got the following
dfu-util 0.8
ID 1d50:607f
Claiming USB DFU Interface...
Determining device status: state = dfuERROR, status = 10
dfuERROR, clearing status
dfuIDLE, continuing
Device returned transfer size 1024
DfuSe interface name: "Internal Flash  "
Downloading to address = 0x08005000, size = 25248
Download	[=========================] 100%        25248 bytes
Download done.
File downloaded successfully
Transitioning to dfuMANIFEST state
  1. Also did dfu-util -d 1d50:607f -a 0 -s 0x08005000:leave -D spark_tinker.bin
    got the following
    dfu-util 0.8
    Opening DFU capable USB device…
    ID 1d50:607f
    Claiming USB DFU Interface…
    Setting Alternate Setting #0 …
    dfuIDLE, continuing
    Downloading to address = 0x08005000, size = 79996
    Download [=========================] 100% 79996 bytes
    Download done.
after which I got a blinking blue, so I use it with spark setup wifi
the core’s led turn off for a moment
than it start to become solid blue (for a few second)
and goes back to flashing green again
Could I be flashing the core wrong way?
Thank you
edited : video link
Left is the core that is flashing green while right core is the one that flashing green than to red which I ask in another thread.
1.) A quick way to test would be to setup a hotspot using your mobile phone and send in the Wifi credentials via USB.
If this works, that implies the wifi network settings might have some issue we need to look into further.
2.) Make sure the core you use has an antenna attached if you bought the u.fl version
3.) If you have Spark-cli installed, update it to the latest using sudo npm update -g spark-cli and use the command spark flash --usb cc3000 in DFU mode for the patching.
Let me know how it goes :wink:
Hi @kennethlimcp
did both
➜  ~  spark flash --usb cc3000
FOUND DFU DEVICE 1d50:607f
checking file  /Users/bosslee/.nvm/v0.10.13/lib/node_modules/spark-cli/binaries/cc3000-patch-programmer.bin
spawning dfu-util -d 1d50:607f -a 0 -i 0 -s 0x08005000:leave -D /Users/bosslee/.nvm/v0.10.13/lib/node_modules/spark-cli/binaries/cc3000-patch-programmer.bin
dfu-util 0.8
ID 1d50:607f
dfuIDLE, continuing
Downloading to address = 0x08005000, size = 25240
Download	[=========================] 100%        25240 bytes
Download done.
Flashed!
➜  ~  spark flash --usb tinker
checking file  /Users/bosslee/.nvm/v0.10.13/lib/node_modules/spark-cli/binaries/spark_tinker.bin
spawning dfu-util -d 1d50:607f -a 0 -i 0 -s 0x08005000:leave -D /Users/bosslee/.nvm/v0.10.13/lib/node_modules/spark-cli/binaries/spark_tinker.bin
dfu-util 0.8
ID 1d50:607f
dfuIDLE, continuing
Download done.
Flashed!
After I finished this 2 steps, the core is blinking blue
I did the following
  1. spark setup wifi
  2. key in the details
  3. spark led goes off
  4. spark led goes to blue
  5. spark goes back to blinking green
Did you try this:
Trying that right now :smiley:
I using an iphone 5.
I set it to hotspot
what do I choose for the following?
Security 0=unsecured, 1=WEP, 2=WPA, 3=WPA2:
Serial said: Awesome. Now we'll connect!
If you see a pulsing cyan light, your Spark Core
has connected to the Cloud and is ready to go!
If your LED flashes red or you encounter any other problems,
visit https://www.spark.io/support to debug.
    Spark <3 you!
Done!  Your core should now restart.
I tried it with WPA2
and it goes back to the same thing. (flashing green)
Are you using a white or black core? It should probably be WPA or WPA2 so give both a shot.
Edit: Apple says WPA2
Also, just to be sure, you did not mess with the core or server keys?
I did I was trying out with the local cloud setup
but after I failed to get the local cloud up
I did the following from this link
http://support.spark.io/hc/en-us/articles/203038434-How-do-I-backup-restore-change-my-Core-s-Key-
I followed step 3 How to Change your Key:
I have also successfully sent the key
If that’s the case, place the core in DFU mode and run this command spark keys doctor CORE_ID
This will revert the core back a the spark :cloud: public key as well as submit a new core public key to the cloud.
Hi @kennethlimcp
Thanks for helping
As per your instruction I did the following
I put it to DFU, than I did as you instructed
after the final statement of "your core should restart."
the core went back to flashing green
➜  ~  spark keys doctor 54ff6c066678574924440167
running dfu-util -l
running openssl genrsa -out 54ff6c066678574924440167_new.pem 1024
running openssl rsa -in 54ff6c066678574924440167_new.pem -pubout -out 54ff6c066678574924440167_new.pub.pem
running openssl rsa -in 54ff6c066678574924440167_new.pem -outform DER -out 54ff6c066678574924440167_new.der
New Key Created!
running dfu-util -l
running dfu-util -l
running dfu-util -d 1d50:607f -a 1 -s 0x00002000:1024 -U pre_54ff6c066678574924440167_new.der
running openssl rsa -in pre_54ff6c066678574924440167_new.der -inform DER -pubout  -out pre_54ff6c066678574924440167_new.pub.pem
Saved!
checking file  54ff6c066678574924440167_new.der
spawning dfu-util -d 1d50:607f -a 1 -i 0 -s 0x00002000:leave -D 54ff6c066678574924440167_new.der
dfu-util 0.8
ID 1d50:607f
Setting Alternate Setting #1 ...
dfuIDLE, continuing
DfuSe interface name: "SPI Flash : SST25x"
Downloading to address = 0x00002000, size = 608
Download	[=========================] 100%          608 bytes
Download done.
Saved!
attempting to add a new public key for core 54ff6c066678574924440167
submitting public key succeeded!
Okay!  New keys in place, your core should restart.
1.) Awesome! We sorted the keys issue
2.) Seems like your core has some issues trying to connect to the cloud successfully
3.) Can you perform a factory reset and connect to any Wifi network that the core originally worked properly with?
I did a factory reset.
this is a new core, have yet to work with existing wifi.
initially, I wanted to try and set up the new core with local cloud.
however this my wifi info
is it of any help?
Update:
1 Factory reset and try to connect back to home network
Same thing happen, after spark setup wifi
led goes off
led goes to blue
led goes to flashing green
2 Factory reset and try to connect back to hotspot network
led goes off
led goes to blue
Hi @bosslee,
If you’ve patched that flashing green core, and it simply won’t get on the network, but your other core will, it’s possible that unit might be damaged. If you can’t get it to work, can you email us at hello@spark.io, and we can maybe arrange a replacement?
David
Thanks @Dave
I would give it one more try and if it does not work out I would email in.
Thanks for the help and thanks @kennethlimcp for his prompt support.
Let me know if local support would help (non spark related) and I can probably take a look at the core.
@kennethlimcp that would be awesome If you have some time. I can head down to SUTD if that works for you. Looking to learn more stuff from you :smile: Maybe we can take this via pm. Messaging you from there.
