How to report bugs and provide feedback
Hello Particle Workbench users :wave:
We greatly value your feedback - to help us better diagnose and fix your issue as quickly as possible, here's what you can do:
  1. Search in the community for similar reports - often times your question will have already been asked and answered
  2. Create a new topic / thread and include the "[ISSUE]" prefix - this will help us quickly differentiate bug reports from general questions / discussion
  3. Verify you are using the latest versions of VSCode & Particle Workbench - there's a decent chance we've already fixed your issue. Here's how to update extensions and how to update VSCode
  4. Disable Other Extensions - VSCode extensions can interact poorly. To help identify these scenarios, please reproduce your issue with all non-Workbench extensions disabled. Here's how to disable extensions
  5. Disable Antivirus - some antivirus programs interfere with VSCode / Particle Workbench - temporarily disable or explicitly grant VSCode higher privileges and confirm your issue is still present
  6. Bypass USB hub / extensions - if you are working with a device and are seeing issues related to its USB connection, try disconnecting all USB devices and reconnecting only your Particle device directly to you computer’s USB port.
  7. Check your USB Cable - Likewise, if you are having issues connecting to your device over USB, try using a different cable. You'd be surprised how many "power-only" USB cables are out there.
  8. Avoid Cloud Storage Drives Storing your project in Dropbox / OneDrive / Google Drive? Try moving it to a standard directory
  9. Avoid Custom Shell Commands - Local compilation on macOS & Linux relies on a number of standard shell commands (e.g. cd, ls, rm, stat, etc). In rare cases a developer may choose to replace these standard built-in commands with custom versions that behave differently. Verify you are not using custom shell commands or disable them temporarily and re-test your issue.
  10. Please provide clear steps to reproduce your issue - what chain of events lead to the issue? what happened? what did you expect would happen?
  11. Include an Environment Audit Report - run the Particle: Audit Environment command (docs) and include the nonsensitive portions in your issue details
Thanks for using Workbench and thanks for helping us make it better for everyone :pray:
Compile fails in workbench. Problem in make file?
Particle Workbench stop working - can't compile, missing DLL's
[ISSUE] No Device Found on Particle Workbench
[ISSUE] Unable to local Compile
Workbench trying to detect DFU mode to long
Particle Workbench Compiler error
Could not find task: Compile application (local)
[ISSUE] Failed to launch OpenOCD GDB Server: Timeout
Folder path cannot include whitespace! particle
Flashing using DFU
Compile Error output is not helpful, always looks the same if there's ANY error
About Developer Tools & How to Get Help
External Mesh Antenna Code error while using Workbench
[ISSUE] Terminal fails to launch, prevents local compile
Missing nrf52840.h compile error
[SOLVED] Unable to flash with 5.7.0 HTTP error 406
Tracker One compilation error in Particle Bench
[FIXED] PRODUCT_ID, PRODUCT_VERSION, SYSTEM_THREAD, SYSTEM_MODE in Workbench
[ISSUE] MacOS: dfu-util cannot see the particle device
[ISSUE] SOS Debugging Tinker on Argon (MacOS). vscode/Particle workbench
Including a non-Particle library into a project in the Particle workbench
[ISSUE] Particle: Flash for debug fails and puts device in error state. Also related to Failed to launch OpenOCD GDB. Server: Timeout
Cloud flash failed because path must be a string
Local compile throwing out 706 errors
[ISSUE]Workbench Can't local Compile due to 'make: command not found' (on Windows 10)
[ISSUE] Could not find task: Flash application (local) for <directory>/ParticleWorkbench/<project name>
[ISSUE] 'chownr' Error Message on Create New Project
[issue] Local compile fails libcrypto.a is not an archive
[ISSUE] Particle Workbench extension keeps installing 1.0.1 compiler toolchain
[ISSUE] Error with Workbench new project - also see when I try to compile existing project
P1 to P2 migration
Cloud Compile doesn't work in workbench but works in Particle Build
[ISSUE]B-SOM 40x Serial command not working
Can I have multiple top-level .INO files in a Workbench project, and if so, how do I target one or the other for build?
Debug errors using Debugger hardware with Electron
Boron code not updating
Any/Everything Command Pallet fails to run in VS Code?
Running debugger on local machine
Log in to build.particle issue
Local compile after Windows update to 2004 not working: make: command not found
