Boron code not updating
Hi Ive started running into a problem when flashing my boron/s its happening to multiples boron devices.
i hit complie and flash and the following happens and says successfull but there is a line that concerns me. (see bottom)
Serial device PARTICLE_SERIAL_DEV : not available
The boron then try to connect to Particle cloud but goes into a debug mode. If i reset it, itgoes into debug again, but on the second or third time it gets stuck in DFU mode forever.
I unplug it & and plug it back in straight into DFU
We i started using a new code i got this problem, but i when back to code i know works still same issue.
Executing task: make -f 'C:\Users\AGLOT.particle\toolchains\buildscripts\1.9.2\Makefile' flash-user -s <
:::: PUTTING DEVICE INTO DFU MODE
Done.
:::: FLASHING APPLICATION
Creating d:/Particle/Code/Boron420mA/target/1.5.2/boron/platform_user_ram.ld ...
text data bss dec hex filename
14600 192 1440 16232 3f68 d:/Particle/Code/Boron420mA/target/1.5.2/boron/Boron420mA.elf
dfu-suffix (dfu-util) 0.9
Copyright 2011-2012 Stefan Schmidt, 2013-2014 Tormod Volden
Suffix successfully added to file
Flashing using dfu:
dfu-util 0.9
ID 2b04:d00d
Claiming USB DFU Interface...
dfuIDLE, continuing
Downloading to address = 0x000d4000, size = 14796
Download [=========================] 100% 14796 bytes
Download done.
File downloaded successfully
Transitioning to dfuMANIFEST state
*** FLASHED SUCCESSFULLY ***
Press any key to close the terminal.
Hi there :wave:
Welcome to the Developer Tools category - some tips before your post:
For topics related to the Particle CLI, please post in the CLI subcategory:
...and be sure to include the troubleshooting info listed here if you are reporting a bug or need technical help.
For topics related to the Particle Workbench, please post in the Workbench subcategory:
...and likewise include the troubleshooting info listed here if you are reporting a bug or need technical help.
Otherwise, post here AFTER REMOVING THIS MESSAGE :heart::pray::+1:
Can you try flashing deviceOS and your application?
From the Command Palette (SHIFT + CTRL + P), run the following task.
Particle: Flash application & DeviceOS (local)
Also, this warning can be ignored.
Thanks this did fix it.
