No app will flash (USB Hub issue?)
Hi Community,
I'm unable to flash any app to my Boron. The error message on the terminal reads:
:::: PUTTING DEVICE INTO DFU MODE
Done.
:::: FLASHING APPLICATION
   text    data     bss     dec     hex filename
   5196     116    1412    6724    1a44 /Users/ryan/Code/Particle/birdie2/target/1.5.2/photon/birdie2.elf
Serial device PARTICLE_SERIAL_DEV : not available
Flashing using dfu:
dfu-util 0.9
ID 2b04:d00d
Claiming USB DFU Interface...
dfuIDLE, continuing
Downloading to address = 0x080a0000, size = 5312
_dfu-util: Last page at 0x080a14bf is not writeable
make[2]: *** [program-dfu] Error 74
make[1]: *** [modules/photon/user-part] Error 2
make: *** [flash-user] Error 2
The terminal process "/bin/bash '-c', 'make -f '/Users/ryan/.particle/toolchains/buildscripts/1.9.2/Makefile' flash-user -s'" terminated with exit code: 2.
Press any key to close the terminal.
I've seen a number of community posts like the following
...and this is the only one with a clear culprit: the person's USB hub.
The problem is that my computer only has USB-C connections, so I have a use a hub for my Boron.
Thoughts to debug?
Ryan
If anyone else is using a new Macbook Air or Pro… you can’t. :frowning:
Particle boards won’t work with USB hubs. You need to buy a USB-C cord for your board!
