Cannot flash boron-clouddebug-v121-rc3.bin
I have been experiencing connectivity issues with my new Borons and would like to run the Cloud Debug application and provide feedback. My devices are on v1.3.0-rc.1 not v1.2.1-rc.3 as described above.
Will the following instructions described above work for my v1.3.0-rc.1 devices:
  • Use the Particle CLI upgrade your Device OS and flash the cloud-debug firmware to your device
    • Put your device into DFU mode (flashing yellow)
      • particle flash --usb <device>-system-part1@1.2.1-rc.3.bin
      • particle flash --usb <device>-clouddebug-v1.2.1-rc.3.bin
    • Put your device into listening mode (blinking blue)
      • particle flash --serial <device>-bootloader@1.2.1-rc.3.bin
  • Open up a serial terminal by issuing the following CLI command:
    • particle serial monitor --follow
(I ask because I have bricked Borons to a red flashing state trying to downgrade previously)
You can run applications targeted at lower version numbers on devices with a higher version installed.
Thanks Scruff. So only flashing:
should be necessary then?
Well - that unfortunately was the wrong thing to do.
I put the 1.3.0-rc.1 Boron in DFU mode and ran:
C:\Users\rober\Downloads>particle flash --usb boron-clouddebug-v121-rc3.bin
Error writing firmware: Invalid DFU suffix signature
dfuse_download: libusb_control_transfer returned -9
the Boron is now flashing yellow and I tried power cycling, resetting, holding the mode button down, safe start but nothing I do gets it out of this mode.
Try with particle flash --usb boron-clouddebug-v121-rc3.bin -v (to get verbose output).
Flashing boron-clouddebug-v121-rc3.bin to a 1.3.0-rc.1 Boron should not cause issues.
However, this should help getting out of DFU Mode
particle flash --usb tinker -v
Tried:
C:\Users\rober\Downloads>particle flash --usb tinker -v
dfu-util 0.8
ID 2b04:d00d
Claiming USB DFU Interface...
dfuIDLE, continuing
Downloading to address = 0x000d4000, size = 11412
Download        [=========================] 100%        11412 bytes
Download done.
File downloaded successfully
Transitioning to dfuMANIFEST state
Flash success!
Still flashing yellow (DFU mode) after this.
Tried:
C:\Users\rober\Downloads>particle flash --usb boron-clouddebug-v121-rc3.bin -v
dfu-util 0.8
ID 2b04:d00d
dfuIDLE, continuing
Downloading to address = 0x00030000, size = 754448
Download        [                         ]   0%            0 bytesInvalid DFU suffix signature
Error during download get_status
VError: Error writing firmware: Invalid DFU suffix signature
    at Promise.resolve.then.then.then.then.then.then.catch.err (C:\Users\rober\AppData\Local\particle\node_modules\particle-cli\dist\cmd\flash.js:198:13)
    at <anonymous>
    at process._tickCallback (internal/process/next_tick.js:189:7)
caused by: Error: Invalid DFU suffix signature
    at ensureError (C:\Users\rober\AppData\Local\particle\node_modules\particle-cli\dist\lib\utilities.js:670:14)
    at Promise.resolve.then.then.then.then.then.then.catch.err (C:\Users\rober\AppData\Local\particle\node_modules\particle-cli\dist\cmd\flash.js:198:24)
    at <anonymous>
It failed.
Also tried holding mode then reset (yellow, white, yellow) then:
dfu-util 0.8
ID 2b04:d00d
dfuIDLE, continuing
    at <anonymous>
    at <anonymous>
Thanks for your help.
I have moved this conversation to a separate thread to keep the original one more tidy.
Can you check your particle --version
C:\Users\rober\Downloads>particle --version
1.42.0
I have now tried flashing boron-clouddebug-v121-rc3.bin to my Boron 2G/3G v1.3.0-rc.1 and didn’t see any issue - as expected.
Maybe you have some driver issues.
Uninstall CLI and reinstall via the lastes Windows Installer and make sure to tick both checkboxes (remove and install drivers).
And for superstition restart your Windows too :wink:
Also try using a different USB port and cable.
After that try revive your Boron with these steps (again)
(in DFU Mode)
particle update -v
particel flash --usb tinker -v
After that your Boron should be back to 1.1.1 breathing cyan and running Tinker.
Problem solved. It was a batch of bad USB cables.
Thanks for your help @ScruffR
Sorry for wasting everyone’s time.
