@ParticleD I just read your thread about flashing the firmware. Thanks, I wish I’d seen that yesterday
There’s a difference between what you suggest and what is listed in the docs.
The docs suggest to use the hybrid.bin files and flash in one step. You suggest to use the system+tinker+bootloader files in a few steps. Is the end result the same? Can you confirm?
