Brand new 404x, new antenna using part.cl/setup-boron404x and it is blinking green for over an hour. Logs attached if someone can tell me what it all means, please.
Device ID:
ICCID:
IMEI:
IMSI:
Modem Manufacturer: u-blox
Modem Model: SARA-R510S
Modem Firmware Version: 03.15
Modem Application Version: 03.15,A00.01
Power Supply: USB Host
Battery: Charging
Battery SoC: 22.4141
Country:
Carrier:
Access Technology:
Band:
Cellular Global Identity:
0000000272 [system.nm] TRACE: Request to power on the interface
0000000272 [ncp.client] TRACE: Powering modem on, ncpId: 0x47
0000000273 [ncp.client] TRACE: Modem already on
0000000273 [ncp.client] TRACE: Setting UART voltage translator state 1
0000000275 [system.nm] INFO: State changed: DISABLED -> IFACE_DOWN
0000000374 [ncp.client] TRACE: Setting UART voltage translator state 0
0000000474 [ncp.client] TRACE: Setting UART voltage translator state 1
0000000474 [ncp.client] TRACE: Muxer is not currently running
0000000475 [ncp.client] TRACE: Initialized muxer @ 460800 baudrate
0000000476 [mux] INFO: Starting GSM07.10 muxer
0000000477 [mux] INFO: GSM07.10 muxer thread started
0000000480 [ncp.client] TRACE: Resumed muxed session
0000000481 [mux] INFO: Openning mux channel 1
0000000533 [ncp.at] TRACE: > AT
0000000536 [ncp.at] TRACE: < OK
0000000537 [ncp.client] TRACE: NCP ready to accept AT commands
0000000538 [ncp.at] TRACE: > AT
0000000541 [ncp.at] TRACE: < OK
0000000542 [ncp.at] TRACE: > ATI9
0000000546 [ncp.at] TRACE: < 03.15,A00.01
0000000546 [ncp.at] TRACE: < OK
0000000547 [ncp.client] TRACE: App firmware: 1
0000000548 [ncp.at] TRACE: > AT+UGPIOC?
0000000552 [ncp.at] TRACE: < +UGPIOC:
0000000554 [ncp.at] TRACE: < 16,255
0000000554 [ncp.at] TRACE: < 19,255
0000000556 [ncp.at] TRACE: < 23,0
0000000556 [ncp.at] TRACE: < 24,255
0000000557 [ncp.at] TRACE: < 25,255
0000000558 [ncp.at] TRACE: < 33,255
0000000558 [ncp.at] TRACE: < 42,255
0000000559 [ncp.at] TRACE: < 46,255
0000000559 [ncp.at] TRACE: < OK
0000000560 [ncp.at] TRACE: > AT+UGPIOR=23
0000000564 [ncp.at] TRACE: < +UGPIOR: 23,1
0000000564 [ncp.at] TRACE: < OK
0000000565 [ncp.client] INFO: Using internal SIM card
0000000566 [ncp.at] TRACE: > AT+CPIN?
0000000570 [ncp.at] TRACE: < +CPIN: READY
0000000570 [ncp.at] TRACE: < OK
0000000571 [ncp.at] TRACE: > AT+CCID
0000000613 [ncp.at] TRACE: < +CCID: 89883070000036197646
0000000613 [ncp.at] TRACE: < OK
0000000614 [ncp.at] TRACE: > AT+IFC?
0000000618 [ncp.at] TRACE: < +IFC: 2,2
0000000618 [ncp.at] TRACE: < OK
0000000619 [ncp.at] TRACE: > AT+IFC=2,2
0000000622 [ncp.at] TRACE: < OK
0000000628 [ncp.at] TRACE: > AT
0000000631 [ncp.at] TRACE: < OK
0000000632 [ncp.at] TRACE: > AT+CCID
0000000656 [ncp.at] TRACE: < +CCID: 89883070000036197646
0000000657 [ncp.at] TRACE: < OK
0000000658 [ncp.at] TRACE: > AT+UMNOPROF?
0000000663 [ncp.at] TRACE: < +UMNOPROF: 100
0000000663 [ncp.at] TRACE: < OK
0000000664 [ncp.at] TRACE: > AT+UBANDMASK?
0000000668 [ncp.at] TRACE: < +UBANDMASK: 0,6170,0
0000000669 [ncp.at] TRACE: < OK
0000000670 [ncp.at] TRACE: > AT+COPS=3,2
0000000673 [ncp.at] TRACE: < OK
0000000674 [ncp.at] TRACE: > AT+CGEREP=1,0
0000000677 [ncp.at] TRACE: < OK
0000000678 [ncp.at] TRACE: > AT+URAT?
0000000682 [ncp.at] TRACE: < +URAT: 7
0000000682 [ncp.at] TRACE: < OK
0000000683 [ncp.at] TRACE: > AT+CPSMS?
0000000688 [ncp.at] TRACE: < +CPSMS: 0,,,"00010011","00000011"
0000000688 [ncp.at] TRACE: < OK
0000000689 [ncp.at] TRACE: > AT+CEDRXS?
0000000693 [ncp.at] TRACE: < +CEDRXS: 4,"0000"
0000000694 [ncp.at] TRACE: < OK
0000000694 [mux] INFO: Mux channel 1 already opened
0000000695 [ncp.at] TRACE: > AT
0000000698 [ncp.at] TRACE: < OK
0000000699 [ncp.client] TRACE: NCP state changed: 1
0000000699 [net.pppncp] TRACE: NCP event 1
0000000701 [app] INFO: cellular is on
0000000703 [ncp.at] TRACE: > AT+CCID
0000000727 [ncp.at] TRACE: < +CCID: 89883070000036197646
0000000729 [ncp.at] TRACE: < OK
0000000731 [ncp.at] TRACE: > AT+CGMI
0000000735 [ncp.at] TRACE: < u-blox
0000000736 [ncp.at] TRACE: < OK
0000000738 [ncp.at] TRACE: > AT+CGMM
0000000742 [ncp.at] TRACE: < SARA-R510S
0000000742 [ncp.at] TRACE: < OK
0000000744 [ncp.at] TRACE: > AT+CGMR
0000000748 [ncp.at] TRACE: < 03.15
0000000748 [ncp.at] TRACE: < OK
0000000749 [ncp.at] TRACE: > AT+CGSN
0000000753 [ncp.at] TRACE: < 351457831014359
0000000754 [ncp.at] TRACE: < OK
0000001723 [app] INFO: Auto-connect disabled
0000002167 [ncp.at] TRACE: > AT+CFUN?
0000002171 [ncp.at] TRACE: < +CFUN: 1,7
0000002171 [ncp.at] TRACE: < OK
0000002172 [ncp.at] TRACE: > AT+CCID
0000002195 [ncp.at] TRACE: < +CCID: 89883070000036197646
0000002196 [ncp.at] TRACE: < OK
0000002197 [ncp.at] TRACE: > AT+CGSN
0000002201 [ncp.at] TRACE: < 351457831014359
0000002202 [ncp.at] TRACE: < OK
0000002202 [ncp.at] TRACE: > ATI9
0000002206 [ncp.at] TRACE: < 03.15,A00.01
0000002206 [ncp.at] TRACE: < OK
0000002775 [ncp.at] TRACE: > AT+CFUN?
0000002779 [ncp.at] TRACE: < +CFUN: 1,7
0000002780 [ncp.at] TRACE: < OK
0000002782 [ncp.at] TRACE: > AT+CCID
0000002806 [ncp.at] TRACE: < +CCID: 89883070000036197646
0000002807 [ncp.at] TRACE: < OK
0000002808 [ncp.at] TRACE: > AT+CGSN
0000002812 [ncp.at] TRACE: < 351457831014359
0000002813 [ncp.at] TRACE: < OK
0000002813 [ncp.at] TRACE: > ATI9
0000002817 [ncp.at] TRACE: < 03.15,A00.01
0000002817 [ncp.at] TRACE: < OK
0000003334 [system.nm] INFO: State changed: IFACE_DOWN -> IFACE_REQUEST_UP
0000003337 [net.ppp.client] TRACE: PPP thread event ADM_UP data=0
0000003337 [net.ppp.client] TRACE: State NONE -> READY
0000003340 [ncp.at] TRACE: > AT+CFUN?
0000003341 [system.nm] INFO: State changed: IFACE_REQUEST_UP -> IFACE_UP
0000003344 [ncp.at] TRACE: < +CFUN: 1,7
0000003344 [ncp.at] TRACE: < OK
0000003345 [ncp.at] TRACE: > AT+CCID
0000003371 [ncp.at] TRACE: < +CCID: 89883070000036197646
0000003372 [ncp.at] TRACE: < OK
0000003373 [ncp.at] TRACE: > AT+CGDCONT?
0000003379 [ncp.at] TRACE: < +CGDCONT: 1,"IPV4V6","","0.0.0.0 0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0",0,0,
0000003380 [ncp.at] TRACE: < OK
0000003381 [ncp.at] TRACE: > AT+CFUN=4
0000003393 [ncp.at] TRACE: < OK
0000003394 [ncp.at] TRACE: > AT+CGDCONT=1,"IP","super"
0000003399 [ncp.at] TRACE: < OK
0000003399 [ncp.at] TRACE: > AT+CFUN?
0000003403 [ncp.at] TRACE: < +CFUN: 4,7
0000003403 [ncp.at] TRACE: < OK
0000003404 [ncp.at] TRACE: > AT+CFUN=1
0000003490 [ncp.at] TRACE: < OK
0000003491 [ncp.at] TRACE: > AT+CEREG=2
0000003495 [ncp.at] TRACE: < OK
0000003496 [ncp.client] TRACE: NCP connection state changed: 1
0000003496 [net.pppncp] TRACE: NCP event 2
0000003497 [net.pppncp] TRACE: State changed event: 1
0000003498 [ncp.at] TRACE: > AT+COPS?
0000003498 [net.ppp.client] TRACE: PPP thread event LOWER_DOWN data=0
0000003502 [ncp.at] TRACE: < +COPS: 0
0000003502 [ncp.at] TRACE: < OK
0000003503 [ncp.at] TRACE: > AT+CEREG?
0000003507 [ncp.at] TRACE: < +CEREG: 2,0
0000003507 [ncp.at] TRACE: < OK
0000018508 [ncp.at] TRACE: > AT+CEREG?
0000018512 [ncp.at] TRACE: < +CEREG: 2,0
0000018513 [ncp.at] TRACE: < OK
0000018513 [ncp.at] TRACE: > AT+UCGED?
0000018520 [ncp.at] TRACE: < +UCGED: 2
0000018520 [ncp.at] TRACE: < 6,2,fff,fff
0000018521 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,25
0000018522 [ncp.at] TRACE: < OK
0000033522 [ncp.at] TRACE: > AT+CEREG?
0000033526 [ncp.at] TRACE: < +CEREG: 2,0
0000033527 [ncp.at] TRACE: < OK
0000033527 [ncp.at] TRACE: > AT+UCGED?
0000033534 [ncp.at] TRACE: < +UCGED: 2
0000033534 [ncp.at] TRACE: < 6,2,fff,fff
0000033535 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,25
0000033536 [ncp.at] TRACE: < OK
0000043436 [ncp.at] TRACE: < +CEREG: 3
0000048536 [ncp.at] TRACE: > AT+CEREG?
0000048540 [ncp.at] TRACE: < +CEREG: 2,3
0000048541 [ncp.at] TRACE: < OK
0000048542 [ncp.at] TRACE: > AT+UCGED?
0000048548 [ncp.at] TRACE: < +UCGED: 2
0000048548 [ncp.at] TRACE: < 6,2,fff,fff
0000048549 [ncp.at] TRACE: < 5110,12,255,6,ffff,0000000,452,00000000,ffff,ff,76,27,20.50,1,255,255,
0000048550 [ncp.at] TRACE: < OK
0000063550 [ncp.at] TRACE: > AT+CIMI
0000063583 [ncp.at] TRACE: < 234507088334502
0000063583 [ncp.at] TRACE: < OK
0000063584 [ncp.at] TRACE: > AT+CEREG?
0000063587 [ncp.at] TRACE: < +CEREG: 2,3
0000063588 [ncp.at] TRACE: < OK
0000063589 [ncp.at] TRACE: > AT+UCGED?
0000063595 [ncp.at] TRACE: < +UCGED: 2
0000063595 [ncp.at] TRACE: < 6,2,fff,fff
0000063596 [ncp.at] TRACE: < 676,2,255,25,ffff,0000000,117,00000000,ffff,ff,76,27,20.50,1,255,255,2
0000063597 [ncp.at] TRACE: < OK
0000078597 [ncp.at] TRACE: > AT+CEREG?
0000078601 [ncp.at] TRACE: < +CEREG: 2,3
0000078602 [ncp.at] TRACE: < OK
0000078603 [ncp.at] TRACE: > AT+UCGED?
0000078609 [ncp.at] TRACE: < +UCGED: 2
0000078610 [ncp.at] TRACE: < 6,2,fff,fff
0000078610 [ncp.at] TRACE: < 2350,4,255,50,ffff,0000000,135,00000000,ffff,ff,76,27,20.50,1,255,255,
0000078611 [ncp.at] TRACE: < OK
0000093611 [ncp.at] TRACE: > AT+CEREG?
0000093615 [ncp.at] TRACE: < +CEREG: 2,3
0000093616 [ncp.at] TRACE: < OK
0000093617 [ncp.at] TRACE: > AT+UCGED?
0000093623 [ncp.at] TRACE: < +UCGED: 2
0000093624 [ncp.at] TRACE: < 6,2,fff,fff
0000093624 [ncp.at] TRACE: < 2350,4,255,50,ffff,0000000,135,00000000,ffff,ff,76,27,20.50,1,255,255,
0000093625 [ncp.at] TRACE: < OK
0000108725 [ncp.at] TRACE: > AT+CEREG?
0000108730 [ncp.at] TRACE: < +CEREG: 2,3
0000108730 [ncp.at] TRACE: < OK
0000108731 [ncp.at] TRACE: > AT+UCGED?
0000108744 [ncp.at] TRACE: < +UCGED: 2
0000108745 [ncp.at] TRACE: < 6,2,fff,fff
0000108745 [ncp.at] TRACE: < 2350,4,255,50,ffff,0000000,135,00000000,ffff,ff,76,27,20.50,1,255,255,
0000108746 [ncp.at] TRACE: < OK
0000123646 [ncp.at] TRACE: > AT+CIMI
0000123684 [ncp.at] TRACE: < 234507088334502
0000123684 [ncp.at] TRACE: < OK
0000123785 [ncp.at] TRACE: > AT+CEREG?
0000123789 [ncp.at] TRACE: < +CEREG: 2,3
0000123789 [ncp.at] TRACE: < OK
0000123790 [ncp.at] TRACE: > AT+UCGED?
0000123796 [ncp.at] TRACE: < +UCGED: 2
0000123797 [ncp.at] TRACE: < 6,2,fff,fff
0000123797 [ncp.at] TRACE: < 5110,12,50,50,ffff,0000000,452,00000000,ffff,ff,65,21,12.50,1,255,255,
0000123798 [ncp.at] TRACE: < OK
0000138898 [ncp.at] TRACE: > AT+CEREG?
0000138902 [ncp.at] TRACE: < +CEREG: 2,3
0000138902 [ncp.at] TRACE: < OK
0000138903 [ncp.at] TRACE: > AT+UCGED?
0000138910 [ncp.at] TRACE: < +UCGED: 2
0000138910 [ncp.at] TRACE: < 6,2,fff,fff
0000138911 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,25
0000138912 [ncp.at] TRACE: < OK
0000153912 [ncp.at] TRACE: > AT+CEREG?
0000153916 [ncp.at] TRACE: < +CEREG: 2,3
0000153916 [ncp.at] TRACE: < OK
0000153917 [ncp.at] TRACE: > AT+UCGED?
0000153930 [ncp.at] TRACE: < +UCGED: 2
0000153930 [ncp.at] TRACE: < 6,2,fff,fff
0000153931 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,25
0000153932 [ncp.at] TRACE: < OK
0000168932 [ncp.at] TRACE: > AT+CEREG?
0000168936 [ncp.at] TRACE: < +CEREG: 2,3
0000168936 [ncp.at] TRACE: < OK
0000168937 [ncp.at] TRACE: > AT+UCGED?
0000168944 [ncp.at] TRACE: < +UCGED: 2
0000168944 [ncp.at] TRACE: < 6,2,fff,fff
0000168945 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,25
0000168946 [ncp.at] TRACE: < OK
0000183747 [ncp.at] TRACE: > AT+CIMI
0000183773 [ncp.at] TRACE: < 234507088334502
0000183774 [ncp.at] TRACE: < OK
0000183974 [ncp.at] TRACE: > AT+CEREG?
0000183978 [ncp.at] TRACE: < +CEREG: 2,3
0000183978 [ncp.at] TRACE: < OK
0000183979 [ncp.at] TRACE: > AT+UCGED?
0000183986 [ncp.at] TRACE: < +UCGED: 2
0000183986 [ncp.at] TRACE: < 6,2,fff,fff
0000183987 [ncp.at] TRACE: < 5110,12,255,6,ffff,0000000,452,00000000,ffff,ff,78,27,18.06,1,255,255,
0000183988 [ncp.at] TRACE: < OK
0000198988 [ncp.at] TRACE: > AT+CEREG?
0000198992 [ncp.at] TRACE: < +CEREG: 2,3
0000198993 [ncp.at] TRACE: < OK
0000198994 [ncp.at] TRACE: > AT+UCGED?
0000199000 [ncp.at] TRACE: < +UCGED: 2
0000199000 [ncp.at] TRACE: < 6,2,fff,fff
0000199001 [ncp.at] TRACE: < 676,2,255,25,ffff,0000000,117,00000000,ffff,ff,50,16,5.25,1,255,255,25
0000199002 [ncp.at] TRACE: < OK
0000214002 [ncp.at] TRACE: > AT+CEREG?
0000214006 [ncp.at] TRACE: < +CEREG: 2,3
0000214007 [ncp.at] TRACE: < OK
0000214008 [ncp.at] TRACE: > AT+UCGED?
0000214014 [ncp.at] TRACE: < +UCGED: 2
0000214014 [ncp.at] TRACE: < 6,2,fff,fff
0000214015 [ncp.at] TRACE: < 676,2,255,6,ffff,0000000,117,00000000,ffff,ff,50,16,5.25,1,255,255,255
0000214016 [ncp.at] TRACE: < OK
0000229016 [ncp.at] TRACE: > AT+CEREG?
0000229020 [ncp.at] TRACE: < +CEREG: 2,3
0000229021 [ncp.at] TRACE: < OK
0000229022 [ncp.at] TRACE: > AT+UCGED?
0000229028 [ncp.at] TRACE: < +UCGED: 2
0000229029 [ncp.at] TRACE: < 6,2,fff,fff
0000229029 [ncp.at] TRACE: < 2350,4,255,50,ffff,0000000,135,00000000,ffff,ff,50,16,5.25,1,255,255,2
0000229030 [ncp.at] TRACE: < OK
0000243830 [ncp.at] TRACE: > AT+CIMI
0000243856 [ncp.at] TRACE: < 234507088334502
0000243857 [ncp.at] TRACE: < OK
0000244057 [ncp.at] TRACE: > AT+CEREG?
0000244061 [ncp.at] TRACE: < +CEREG: 2,3
0000244062 [ncp.at] TRACE: < OK
0000244063 [ncp.at] TRACE: > AT+UCGED?
0000244549 [ncp.at] TRACE: < +UCGED: 2
0000244550 [ncp.at] TRACE: < 6,2,310,410
0000244550 [ncp.at] TRACE: < 5110,12,50,50,4302,4a42711,452,00000000,ffff,ff,53,-2,0.37,3,255,255,2
0000244551 [ncp.at] TRACE: < OK
0000252751 [ncp.at] TRACE: < +CEREG: 5,"4302","04a42711",7
0000252752 [ncp.client] TRACE: NCP connection state changed: 2
0000252752 [mux] INFO: Openning mux channel 2
0000253838 [net.pppncp] TRACE: NCP event 100
0000253838 [net.pppncp] TRACE: New auth info
0000253841 [net.pppncp] TRACE: NCP event 2
0000253841 [net.pppncp] TRACE: State changed event: 2
0000253842 [ncp.at] TRACE: > AT+CIMI
0000253843 [ncp.at] TRACE: < +CGEV: ME PDN ACT 1
0000253844 [ncp.at] TRACE: < +CEREG: 0
0000253844 [ncp.at] TRACE: < +CGEV: ME PDN DEACT 1
0000253843 [net.ppp.client] TRACE: PPP thread event LOWER_UP data=0
0000253846 [net.ppp.client] TRACE: State READY -> CONNECT
0000253846 [net.ppp.client] TRACE: State CONNECT -> CONNECTING
0000253886 [ncp.at] TRACE: < 234104099955503
0000253886 [ncp.at] TRACE: < OK
0000253887 [ncp.at] TRACE: > AT+CGATT?
0000253890 [ncp.at] TRACE: < +CGATT: 1
0000253891 [ncp.at] TRACE: < OK
0000254891 [ncp.at] TRACE: > AT
0000254895 [ncp.at] TRACE: < OK
0000254896 [ncp.at] TRACE: > AT+UPORTFWD=100,1
0000254900 [ncp.at] TRACE: < +UPORTFWD: 100,1
0000254900 [ncp.at] TRACE: < OK
0000254901 [ncp.at] TRACE: > ATD*99***1#
0000434901 [ncp.client] ERROR: Failed to enter data mode
0000434901 [net.ppp.client] ERROR: Failed to dial
0000434902 [net.ppp.client] TRACE: State CONNECTING -> CONNECT
0000434902 [net.pppncp] TRACE: NCP event 3
0000434903 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_DOWN
0000434904 [system.nm] TRACE: Interface 4 power state changed: 3
0000434904 [ncp.client] TRACE: Try powering modem off using AT command
0000434905 [ncp.at] TRACE: > AT+CPWROFF
0000434906 [ncp.at] TRACE: < +CGEV: ME DETACH
0000434906 [ncp.at] TRACE: < +CEREG: 3
0000434907 [ncp.at] TRACE: < +CEREG: 5,"4302","04a42711",7
0000434908 [ncp.at] TRACE: < +CGEV: ME PDN ACT 1
0000434908 [ncp.at] TRACE: < +CEREG: 0
0000434909 [ncp.at] TRACE: < +CGEV: ME PDN DEACT 1
0000434910 [ncp.at] TRACE: < +CGEV: ME DETACH
0000434910 [ncp.at] TRACE: < +CEREG: 5,"4302","04a42711",7
0000434911 [ncp.at] TRACE: < +CGEV: ME PDN ACT 1
0000434911 [ncp.at] TRACE: < +CEREG: 0
0000434912 [ncp.at] TRACE: < +CGEV: ME PDN DEACT 1
0000434912 [ncp.at] TRACE: < +CGEV: ME DETACH
0000434913 [ncp.at] TRACE: < +CEREG: 3
0000435002 [net.ppp.client] TRACE: State CONNECT -> CONNECTING
0000436868 [ncp.at] TRACE: < OK
0000436868 [ncp.client] TRACE: Waiting the modem to be turned off...
0000436913 [net.pppncp] TRACE: NCP event 3
0000436913 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_DOWN
0000436914 [system.nm] TRACE: Interface 4 power state changed: 1
0000436914 [ncp.client] TRACE: It takes 46 ms to power off the modem.
0000436915 [mux] INFO: Stopping GSM07.10 muxer
0000436916 [mux] INFO: Gracefully stopping GSM07.10 muxer
0000436916 [mux] INFO: Closing all muxed channels
0000436917 [mux] INFO: Closing mux channel 1
0000436917 [mux] INFO: Closing mux channel 2
0000436918 [mux] INFO: Muxed channel 3 already closed
0000436918 [mux] INFO: Muxed channel 4 already closed
0000436919 [mux] INFO: GSM07.10 muxer thread exiting
0000436920 [ncp.client] TRACE: NCP connection state changed: 1
0000436920 [net.pppncp] TRACE: NCP event 2
0000436921 [net.pppncp] TRACE: State changed event: 1
0000436921 [mux] INFO: GSM07.10 muxer stopped
0000436922 [ncp.client] TRACE: Setting UART voltage translator state 0
0000436922 [ncp.client] TRACE: Soft power off modem successfully
0000436923 [ncp.client] TRACE: Deinit modem serial.
0000436924 [ncp.client] ERROR: Failed to enter data mode
0000436924 [net.ppp.client] ERROR: Failed to dial
0000436925 [net.ppp.client] TRACE: State CONNECTING -> CONNECT
0000436925 [net.ppp.client] TRACE: PPP thread event LOWER_DOWN data=0
0000436926 [net.ppp.client] TRACE: State CONNECT -> DISCONNECT
0000436927 [net.ppp.client] TRACE: State DISCONNECT -> DISCONNECTING
0000436927 [net.ppp.client] TRACE: PPP thread event ERROR data=5
0000436928 [net.pppncp] ERROR: PPP error event data=5
0000436928 [net.ppp.client] TRACE: PPP thread event DOWN data=0
0000436929 [net.ppp.client] TRACE: State DISCONNECTING -> DISCONNECTED
0000436930 [net.ppp.client] TRACE: State DISCONNECTED -> READY
0000437023 [net.pppncp] ERROR: Failed to initialize cellular NCP client: -210
0000437024 [ncp.client] TRACE: Modem already off
0000437024 [ncp.client] TRACE: Setting UART voltage translator state 0
0000437025 [ncp.client] TRACE: Soft power off modem successfully
0000437025 [ncp.client] TRACE: Deinit modem serial.
0000437026 [ncp.client] TRACE: NCP connection state changed: 0
0000437026 [net.pppncp] TRACE: NCP event 2
0000437027 [net.pppncp] TRACE: State changed event: 0
0000437027 [ncp.client] TRACE: NCP state changed: 0
0000437028 [net.pppncp] TRACE: NCP event 1
0000437028 [net.ppp.client] TRACE: PPP thread event LOWER_DOWN data=0
0000437128 [ncp.client] TRACE: Powering modem on, ncpId: 0x47
0000437128 [net.pppncp] TRACE: NCP event 3
0000437129 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_UP
0000437130 [system.nm] TRACE: Interface 4 power state changed: 4
0000438630 [net.pppncp] TRACE: NCP event 3
0000438630 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_UP
0000438631 [system.nm] TRACE: Interface 4 power state changed: 2
0000438632 [ncp.client] TRACE: Modem powered on
0000438632 [ncp.client] TRACE: Setting UART voltage translator state 1
0000438732 [ncp.client] TRACE: Setting UART voltage translator state 0
0000438832 [ncp.client] TRACE: Setting UART voltage translator state 1
0000439833 [ncp.at] TRACE: > AT
0000440189 [ncp.at] TRACE: < OK
0000440189 [ncp.client] TRACE: NCP ready to accept AT commands
0000440190 [ncp.at] TRACE: > AT
0000440192 [ncp.at] TRACE: < OK
0000440193 [ncp.at] TRACE: > ATI9
0000440195 [ncp.at] TRACE: < 03.15,A00.01
0000440196 [ncp.at] TRACE: < OK
0000440196 [ncp.client] TRACE: App firmware: 1
0000440197 [ncp.at] TRACE: > AT+UGPIOC?
0000440199 [ncp.at] TRACE: < +UGPIOC:
0000440200 [ncp.at] TRACE: < 16,255
0000440200 [ncp.at] TRACE: < 19,255
0000440201 [ncp.at] TRACE: < 23,0
0000440201 [ncp.at] TRACE: < 24,255
0000440202 [ncp.at] TRACE: < 25,255
0000440202 [ncp.at] TRACE: < 33,255
0000440203 [ncp.at] TRACE: < 42,255
0000440204 [ncp.at] TRACE: < 46,255
0000440204 [ncp.at] TRACE: < OK
0000440205 [ncp.at] TRACE: > AT+UGPIOR=23
0000440207 [ncp.at] TRACE: < +UGPIOR: 23,1
0000440208 [ncp.at] TRACE: < OK
0000440208 [ncp.client] INFO: Using internal SIM card
0000440209 [ncp.at] TRACE: > AT+CPIN?
0000440211 [ncp.at] TRACE: < ERROR
0000440217 [app] INFO: CPIN ERROR
0000441211 [ncp.at] TRACE: > AT+CPIN?
0000441213 [ncp.at] TRACE: < +CPIN: READY
0000441214 [ncp.at] TRACE: < OK
0000441214 [ncp.at] TRACE: > AT+CCID
0000441612 [ncp.at] TRACE: < +CCID: 89883070000036197646
0000441612 [ncp.at] TRACE: < OK
0000441613 [ncp.at] TRACE: > AT+IFC?
0000441615 [ncp.at] TRACE: < +IFC: 2,2
0000441616 [ncp.at] TRACE: < OK
0000441616 [ncp.at] TRACE: > AT+IFC=2,2
0000441619 [ncp.at] TRACE: < OK
0000441620 [ncp.at] TRACE: > AT
0000441622 [ncp.at] TRACE: < OK
0000441622 [ncp.at] TRACE: > AT+IPR=460800
0000441625 [ncp.at] TRACE: < OK
0000442626 [ncp.at] TRACE: > AT
0000442696 [ncp.at] TRACE: < OK
0000442696 [ncp.at] TRACE: > AT+CCID
0000442739 [ncp.at] TRACE: < +CCID: 89883070000036197646
0000442740 [ncp.at] TRACE: < OK
0000442740 [ncp.at] TRACE: > AT+UMNOPROF?
0000442744 [ncp.at] TRACE: < +UMNOPROF: 100
0000442745 [ncp.at] TRACE: < OK
0000442745 [ncp.at] TRACE: > AT+UBANDMASK?
0000442749 [ncp.at] TRACE: < +UBANDMASK: 0,6170,0
0000442749 [ncp.at] TRACE: < OK
0000442750 [ncp.at] TRACE: > AT+COPS=3,2
0000442752 [ncp.at] TRACE: < OK
0000442753 [ncp.at] TRACE: > AT+CGEREP=1,0
0000442755 [ncp.at] TRACE: < OK
0000442756 [ncp.at] TRACE: > AT+URAT?
0000442758 [ncp.at] TRACE: < +URAT: 7
0000442759 [ncp.at] TRACE: < OK
0000442759 [ncp.at] TRACE: > AT+CPSMS?
0000442762 [ncp.at] TRACE: < +CPSMS: 0,,,"00010011","00000011"
0000442763 [ncp.at] TRACE: < OK
0000442763 [ncp.at] TRACE: > AT+CEDRXS?
0000442767 [ncp.at] TRACE: < +CEDRXS: 4,"0000"
0000442767 [ncp.at] TRACE: < OK
0000442768 [ncp.at] TRACE: > AT+CMUX=0,0,,1509,,,,,
0000442771 [ncp.at] TRACE: < OK
0000442772 [mux] INFO: Starting GSM07.10 muxer
0000442773 [mux] INFO: Openning mux channel 0
0000442773 [mux] INFO: GSM07.10 muxer thread started
0000442776 [mux] INFO: Openning mux channel 1
0000442780 [ncp.at] TRACE: > AT
0000442781 [ncp.at] TRACE: < +CEREG: 0
0000442784 [ncp.at] TRACE: < OK
0000442785 [ncp.client] TRACE: NCP state changed: 1
0000442785 [net.pppncp] TRACE: NCP event 1
0000442786 [net.ppp.client] TRACE: PPP thread event ADM_UP data=0
0000442789 [ncp.at] TRACE: > AT
0000442792 [ncp.at] TRACE: < OK
0000442793 [ncp.at] TRACE: > AT+CFUN?
0000442796 [ncp.at] TRACE: < +CFUN: 1,7
0000442797 [ncp.at] TRACE: < OK
0000442798 [ncp.at] TRACE: > AT+CCID
0000442821 [ncp.at] TRACE: < +CCID: 89883070000036197646
0000442822 [ncp.at] TRACE: < OK
0000442823 [ncp.at] TRACE: > AT+CGDCONT?
0000442828 [ncp.at] TRACE: < +CGDCONT: 1,"IP","super","0.0.0.0",0,0,0,2,0,0,0,0,0,0,0
0000442829 [ncp.at] TRACE: < OK
0000442829 [ncp.at] TRACE: > AT+CFUN?
0000442833 [ncp.at] TRACE: < +CFUN: 1,7
0000442834 [ncp.at] TRACE: < OK
0000442835 [ncp.at] TRACE: > AT+CEREG=2
0000442838 [ncp.at] TRACE: < OK
0000442838 [ncp.client] TRACE: NCP connection state changed: 1
0000442839 [net.pppncp] TRACE: NCP event 2
0000442839 [net.pppncp] TRACE: State changed event: 1
0000442840 [ncp.at] TRACE: > AT+COPS?
0000442841 [net.ppp.client] TRACE: PPP thread event LOWER_DOWN data=0
0000442844 [ncp.at] TRACE: < +COPS: 0
0000442845 [ncp.at] TRACE: < OK
0000442846 [ncp.at] TRACE: > AT+CEREG?
0000442849 [ncp.at] TRACE: < +CEREG: 2,0
0000442850 [ncp.at] TRACE: < OK
0000457850 [ncp.at] TRACE: > AT+CEREG?
0000457854 [ncp.at] TRACE: < +CEREG: 2,0
0000457854 [ncp.at] TRACE: < OK
0000457855 [ncp.at] TRACE: > AT+UCGED?
0000457862 [ncp.at] TRACE: < +UCGED: 2
0000457862 [ncp.at] TRACE: < 6,2,fff,fff
0000457863 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,25
0000457863 [ncp.at] TRACE: < OK
0000472864 [ncp.at] TRACE: > AT+CEREG?
0000472868 [ncp.at] TRACE: < +CEREG: 2,0
0000472868 [ncp.at] TRACE: < OK
0000472869 [ncp.at] TRACE: > AT+UCGED?
0000472876 [ncp.at] TRACE: < +UCGED: 2
0000472876 [ncp.at] TRACE: < 6,2,fff,fff
0000472877 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,25
0000472878 [ncp.at] TRACE: < OK
0000474678 [ncp.at] TRACE: < +CEREG: 3
0000487878 [ncp.at] TRACE: > AT+CEREG?
0000487889 [ncp.at] TRACE: < +CEREG: 2,3
0000487889 [ncp.at] TRACE: < OK
0000487890 [ncp.at] TRACE: > AT+UCGED?
0000487897 [ncp.at] TRACE: < +UCGED: 2
0000487897 [ncp.at] TRACE: < 6,2,fff,fff
0000487898 [ncp.at] TRACE: < 5110,12,255,6,ffff,0000000,452,00000000,ffff,ff,77,26,19.93,1,255,255,
0000487899 [ncp.at] TRACE: < OK
0000502899 [ncp.at] TRACE: > AT+CIMI
0000502929 [ncp.at] TRACE: < 234507088334502
0000502929 [ncp.at] TRACE: < OK
0000502930 [ncp.at] TRACE: > AT+CEREG?
0000502934 [ncp.at] TRACE: < +CEREG: 2,3
0000502934 [ncp.at] TRACE: < OK
0000502935 [ncp.at] TRACE: > AT+UCGED?
0000502942 [ncp.at] TRACE: < +UCGED: 2
0000502942 [ncp.at] TRACE: < 6,2,fff,fff
0000502943 [ncp.at] TRACE: < 676,2,255,25,ffff,0000000,126,00000000,ffff,ff,77,26,19.93,1,255,255,2
0000502944 [ncp.at] TRACE: < OK
0000517944 [ncp.at] TRACE: > AT+CEREG?
0000517948 [ncp.at] TRACE: < +CEREG: 2,3
0000517948 [ncp.at] TRACE: < OK
0000517949 [ncp.at] TRACE: > AT+UCGED?
0000517956 [ncp.at] TRACE: < +UCGED: 2
0000517956 [ncp.at] TRACE: < 6,2,fff,fff
0000517957 [ncp.at] TRACE: < 2350,4,255,50,ffff,0000000,135,00000000,ffff,ff,77,26,19.93,1,255,255,
0000517958 [ncp.at] TRACE: < OK
0000532958 [ncp.at] TRACE: > AT+CEREG?
0000532962 [ncp.at] TRACE: < +CEREG: 2,3
0000532962 [ncp.at] TRACE: < OK
0000532963 [ncp.at] TRACE: > AT+UCGED?
0000532970 [ncp.at] TRACE: < +UCGED: 2
0000532970 [ncp.at] TRACE: < 6,2,fff,fff
0000532971 [ncp.at] TRACE: < 2350,4,255,50,ffff,0000000,135,00000000,ffff,ff,77,26,19.93,1,255,255,
0000532972 [ncp.at] TRACE: < OK
0000547972 [ncp.at] TRACE: > AT+CEREG?
0000547976 [ncp.at] TRACE: < +CEREG: 2,3
0000547977 [ncp.at] TRACE: < OK
0000547977 [ncp.at] TRACE: > AT+UCGED?
0000547984 [ncp.at] TRACE: < +UCGED: 2
0000547984 [ncp.at] TRACE: < 6,2,fff,fff
0000547985 [ncp.at] TRACE: < 5230,13,255,50,ffff,0000000,203,00000000,ffff,ff,77,26,19.93,1,255,255
0000547986 [ncp.at] TRACE: < OK
0000559286 [ncp.at] TRACE: < +CEREG: 5,"4302","04a42711",7
0000559287 [ncp.client] TRACE: NCP connection state changed: 2
0000559287 [mux] INFO: Openning mux channel 2
0000560048 [net.pppncp] TRACE: NCP event 100
0000560048 [net.pppncp] TRACE: New auth info
0000560050 [net.pppncp] TRACE: NCP event 2
0000560051 [net.pppncp] TRACE: State changed event: 2
0000560052 [ncp.at] TRACE: > AT+CIMI
0000560053 [ncp.at] TRACE: < +CEREG: 0
0000560052 [net.ppp.client] TRACE: PPP thread event LOWER_UP data=0
0000560054 [net.ppp.client] TRACE: State READY -> CONNECT
0000560054 [net.ppp.client] TRACE: State CONNECT -> CONNECTING
0000560153 [ncp.at] TRACE: < 234104099955503
0000560153 [ncp.at] TRACE: < OK
0000560154 [ncp.at] TRACE: > AT+CGATT?
0000560158 [ncp.at] TRACE: < +CGATT: 1
0000560159 [ncp.at] TRACE: < OK
0000561159 [ncp.at] TRACE: > AT
0000561163 [ncp.at] TRACE: < OK
0000561163 [ncp.at] TRACE: > AT+UPORTFWD=100,1
0000561167 [ncp.at] TRACE: < +UPORTFWD: 100,1
0000561168 [ncp.at] TRACE: < OK
0000561169 [ncp.at] TRACE: > ATD*99***1#
