Boron 404X stuck on blinking green and won't connect to network or cloud
Hi, I am trying to get my 404X board to connect to the cloud. I have followed the setup process and can flash a basic light blink. However it is stuch on blinking green, and never will connect. I am using an external Hologram Sim.
I have an older 2G/3G board and this works and connects immediately, using the same antenna, sim, and code as the new 404X.
Here are the Doctor logs (continued in reply):
B0000000272 [system.nm] TRACE: Request to power on the interface
0000000273 [ncp.client] TRACE: Powering modem on, ncpId: 0x47
0000000273 [ncp.client] TRACE: Modem already on
0000000274 [ncp.client] TRACE: Setting UART voltage translator state 1
0000000275 [system.nm] INFO: State changed: DISABLED -> IFACE_DOWN
0000000374 [ncp.client] TRACE: Setting UART voltage translator state 0
0000000474 [ncp.client] TRACE: Setting UART voltage translator state 1
0000000475 [ncp.client] TRACE: Muxer is not currently running
0000000476 [ncp.client] TRACE: Initialized muxer @ 460800 baudrate
0000000477 [mux] INFO: Starting GSM07.10 muxer
0000000478 [mux] INFO: GSM07.10 muxer thread started
0000000481 [ncp.client] TRACE: Resumed muxed session
0000000481 [mux] INFO: Openning mux channel 1
0000000533 [ncp.at] TRACE: > AT
0000000535 [ncp.at] TRACE: < OK
0000000535 [ncp.client] TRACE: NCP ready to accept AT commands
0000000536 [ncp.at] TRACE: > AT
0000000540 [ncp.at] TRACE: < OK
0000000540 [ncp.at] TRACE: > ATI9
0000000544 [ncp.at] TRACE: < 03.15,A00.01
0000000545 [ncp.at] TRACE: < OK
0000000545 [ncp.client] TRACE: App firmware: 1
0000000546 [ncp.at] TRACE: > AT+UGPIOC?
0000000549 [ncp.at] TRACE: < +UGPIOC:
0000000550 [ncp.at] TRACE: < 16,255
0000000551 [ncp.at] TRACE: < 19,255
0000000552 [ncp.at] TRACE: < 23,0
0000000553 [ncp.at] TRACE: < 24,255
0000000554 [ncp.at] TRACE: < 25,255
0000000555 [ncp.at] TRACE: < 33,255
0000000555 [ncp.at] TRACE: < 42,255
0000000556 [ncp.at] TRACE: < 46,255
0000000556 [ncp.at] TRACE: < OK
0000000557 [ncp.at] TRACE: > AT+UGPIOR=23
0000000561 [ncp.at] TRACE: < +UGPIOR: 23,0
0000000562 [ncp.at] TRACE: < OK
0000000562 [ncp.client] INFO: Using external Nano SIM card
0000000563 [ncp.at] TRACE: > AT+CPIN?
0000000567 [ncp.at] TRACE: < +CPIN: READY
0000000567 [ncp.at] TRACE: < OK
0000000568 [ncp.at] TRACE: > AT+CCID
0000000590 [ncp.at] TRACE: < +CCID: 8944501012213606353
0000000591 [ncp.at] TRACE: < OK
0000000592 [ncp.at] TRACE: > AT+IFC?
0000000595 [ncp.at] TRACE: < +IFC: 2,2
0000000595 [ncp.at] TRACE: < OK
0000000596 [ncp.at] TRACE: > AT+IFC=2,2
0000000600 [ncp.at] TRACE: < OK
0000000600 [ncp.at] TRACE: > AT
0000000603 [ncp.at] TRACE: < OK
0000000604 [ncp.at] TRACE: > AT+CCID
0000000626 [ncp.at] TRACE: < +CCID: 8944501012213606353
0000000627 [ncp.at] TRACE: < OK
0000000627 [ncp.at] TRACE: > AT+CIMI
0000000670 [ncp.at] TRACE: < 234500068360635
0000000670 [ncp.at] TRACE: < OK
0000000671 [ncp.at] TRACE: > AT+UMNOPROF?
0000000676 [ncp.at] TRACE: < +UMNOPROF: 100
0000000676 [ncp.at] TRACE: < OK
0000000677 [ncp.at] TRACE: > AT+UBANDMASK?
0000000681 [ncp.at] TRACE: < +UBANDMASK: 0,6170,0
0000000682 [ncp.at] TRACE: < OK
0000000683 [ncp.at] TRACE: > AT+COPS=3,2
0000000687 [ncp.at] TRACE: < OK
0000000688 [ncp.at] TRACE: > AT+CGEREP=1,0
0000000690 [ncp.at] TRACE: < OK
0000000691 [ncp.at] TRACE: > AT+URAT?
0000000695 [ncp.at] TRACE: < +URAT: 7
0000000695 [ncp.at] TRACE: < OK
0000000696 [ncp.at] TRACE: > AT+CPSMS?
0000000701 [ncp.at] TRACE: < +CPSMS: 0,,,"00010011","00000011"
0000000701 [ncp.at] TRACE: < OK
0000000702 [ncp.at] TRACE: > AT+CEDRXS?
0000000706 [ncp.at] TRACE: < +CEDRXS: 4,"0000"
0000000707 [ncp.at] TRACE: < OK
0000000708 [mux] INFO: Mux channel 1 already opened
0000000709 [ncp.at] TRACE: > AT
0000000711 [ncp.at] TRACE: < OK
0000000712 [ncp.client] TRACE: NCP state changed: 1
0000000712 [net.pppncp] TRACE: NCP event 1
0000000715 [app] INFO: cellular is on
0000000717 [ncp.at] TRACE: > AT+CCID
0000000752 [ncp.at] TRACE: < +CCID: 8944501012213606353
0000000754 [ncp.at] TRACE: < OK
0000000760 [ncp.at] TRACE: > AT+CGMI
0000000764 [ncp.at] TRACE: < u-blox
0000000766 [ncp.at] TRACE: < OK
0000000767 [ncp.at] TRACE: > AT+CGMM
0000000771 [ncp.at] TRACE: < SARA-R510S
0000000772 [ncp.at] TRACE: < OK
0000000774 [ncp.at] TRACE: > AT+CGMR
0000000778 [ncp.at] TRACE: < 03.15
0000000779 [ncp.at] TRACE: < OK
0000000781 [ncp.at] TRACE: > AT+CGSN
0000000786 [ncp.at] TRACE: < 351457830730583
0000000787 [ncp.at] TRACE: < OK
0000003552 [app] INFO: Auto-connect disabled
0000003990 [ncp.at] TRACE: > AT+CFUN?
0000003993 [ncp.at] TRACE: < +CFUN: 1,7
0000003995 [ncp.at] TRACE: < OK
0000003996 [ncp.at] TRACE: > AT+CCID
0000004018 [ncp.at] TRACE: < +CCID: 8944501012213606353
0000004019 [ncp.at] TRACE: < OK
0000004019 [ncp.at] TRACE: > AT+CGSN
0000004023 [ncp.at] TRACE: < 351457830730583
0000004024 [ncp.at] TRACE: < OK
0000004025 [ncp.at] TRACE: > ATI9
0000004028 [ncp.at] TRACE: < 03.15,A00.01
0000004028 [ncp.at] TRACE: < OK
0000004680 [system.nm] INFO: State changed: IFACE_DOWN -> IFACE_REQUEST_UP
0000004683 [net.ppp.client] TRACE: PPP thread event ADM_UP data=0
0000004684 [net.ppp.client] TRACE: State NONE -> READY
0000004686 [ncp.at] TRACE: > AT+CFUN?
0000004687 [system.nm] INFO: State changed: IFACE_REQUEST_UP -> IFACE_UP
0000004690 [ncp.at] TRACE: < +CFUN: 1,7
0000004691 [ncp.at] TRACE: < OK
0000004691 [ncp.at] TRACE: > AT+CGDCONT?
0000004696 [ncp.at] TRACE: < +CGDCONT: 1,"IP","hologram","0.0.0.0",0,0,0,2,0,0,0,0,0,0,0
0000004697 [ncp.at] TRACE: < OK
0000004698 [ncp.at] TRACE: > AT+CFUN?
0000004702 [ncp.at] TRACE: < +CFUN: 1,7
0000004703 [ncp.at] TRACE: < OK
0000004703 [ncp.at] TRACE: > AT+CEREG=2
0000004706 [ncp.at] TRACE: < OK
0000004707 [ncp.client] TRACE: NCP connection state changed: 1
0000004707 [net.pppncp] TRACE: NCP event 2
0000004708 [net.pppncp] TRACE: State changed event: 1
0000004709 [ncp.at] TRACE: > AT+COPS?
0000004709 [net.ppp.client] TRACE: PPP thread event LOWER_DOWN data=0
0000004713 [ncp.at] TRACE: < +COPS: 0
0000004714 [ncp.at] TRACE: < OK
0000004714 [ncp.at] TRACE: > AT+CEREG?
0000004718 [ncp.at] TRACE: < +CEREG: 2,4
0000004718 [ncp.at] TRACE: < OK
0000019819 [ncp.at] TRACE: > AT+CEREG?
0000019822 [ncp.at] TRACE: < +CEREG: 2,4
0000019823 [ncp.at] TRACE: < OK
0000019823 [ncp.at] TRACE: > AT+UCGED?
0000019830 [ncp.at] TRACE: < +UCGED: 2
0000019831 [ncp.at] TRACE: < 6,2,fff,fff
0000019831 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,25
0000019832 [ncp.at] TRACE: < OK
0000034933 [ncp.at] TRACE: > AT+CEREG?
0000034936 [ncp.at] TRACE: < +CEREG: 2,4
0000034937 [ncp.at] TRACE: < OK
0000034937 [ncp.at] TRACE: > AT+UCGED?
0000034944 [ncp.at] TRACE: < +UCGED: 2
0000034945 [ncp.at] TRACE: < 6,2,fff,fff
0000034945 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,25
0000034946 [ncp.at] TRACE: < OK
0000050047 [ncp.at] TRACE: > AT+CEREG?
0000050050 [ncp.at] TRACE: < +CEREG: 2,4
0000050051 [ncp.at] TRACE: < OK
0000050052 [ncp.at] TRACE: > AT+UCGED?
0000050058 [ncp.at] TRACE: < +UCGED: 2
0000050059 [ncp.at] TRACE: < 6,2,fff,fff
0000050059 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,25
0000050060 [ncp.at] TRACE: < OK
0000064761 [ncp.at] TRACE: > AT+CIMI
0000064802 [ncp.at] TRACE: < 234500068360635
0000064802 [ncp.at] TRACE: < OK
0000065103 [ncp.at] TRACE: > AT+CEREG?
0000065106 [ncp.at] TRACE: < +CEREG: 2,4
0000065107 [ncp.at] TRACE: < OK
0000065107 [ncp.at] TRACE: > AT+UCGED?
0000065114 [ncp.at] TRACE: < +UCGED: 2
0000065115 [ncp.at] TRACE: < 6,3,fff,fff
0000065115 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,25
0000065116 [ncp.at] TRACE: < OK
0000080117 [ncp.at] TRACE: > AT+CEREG?
0000080120 [ncp.at] TRACE: < +CEREG: 2,4
0000080121 [ncp.at] TRACE: < OK
0000080122 [ncp.at] TRACE: > AT+UCGED?
0000080128 [ncp.at] TRACE: < +UCGED: 2
0000080129 [ncp.at] TRACE: < 6,2,fff,fff
0000080129 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,25
0000080130 [ncp.at] TRACE: < OK
0000095231 [ncp.at] TRACE: > AT+CEREG?
0000095234 [ncp.at] TRACE: < +CEREG: 2,4
0000095235 [ncp.at] TRACE: < OK
0000095236 [ncp.at] TRACE: > AT+UCGED?
0000095242 [ncp.at] TRACE: < +UCGED: 2
0000095243 [ncp.at] TRACE: < 6,2,fff,fff
0000095243 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,25
0000095244 [ncp.at] TRACE: < OK
0000110345 [ncp.at] TRACE: > AT+CEREG?
0000110348 [ncp.at] TRACE: < +CEREG: 2,4
0000110349 [ncp.at] TRACE: < OK
0000110350 [ncp.at] TRACE: > AT+UCGED?
0000110356 [ncp.at] TRACE: < +UCGED: 2
0000110357 [ncp.at] TRACE: < 6,2,fff,fff
0000110357 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,25
0000110358 [ncp.at] TRACE: < OK
0000124859 [ncp.at] TRACE: > AT+CIMI
0000124880 [ncp.at] TRACE: < 234500068360635
0000124881 [ncp.at] TRACE: < OK
0000125381 [ncp.at] TRACE: > AT+CEREG?
0000125384 [ncp.at] TRACE: < +CEREG: 2,4
0000125385 [ncp.at] TRACE: < OK
0000125386 [ncp.at] TRACE: > AT+UCGED?
0000125392 [ncp.at] TRACE: < +UCGED: 2
0000125393 [ncp.at] TRACE: < 6,2,fff,fff
0000125393 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,25
0000125394 [ncp.at] TRACE: < OK
0000140495 [ncp.at] TRACE: > AT+CEREG?
0000140498 [ncp.at] TRACE: < +CEREG: 2,4
0000140499 [ncp.at] TRACE: < OK
0000140499 [ncp.at] TRACE: > AT+UCGED?
0000140506 [ncp.at] TRACE: < +UCGED: 2
0000140507 [ncp.at] TRACE: < 6,2,fff,fff
0000140507 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,25
0000140508 [ncp.at] TRACE: < OK
0000155609 [ncp.at] TRACE: > AT+CEREG?
0000155612 [ncp.at] TRACE: < +CEREG: 2,4
0000155613 [ncp.at] TRACE: < OK
0000155614 [ncp.at] TRACE: > AT+UCGED?
0000155620 [ncp.at] TRACE: < +UCGED: 2
0000155621 [ncp.at] TRACE: < 6,2,fff,fff
0000155621 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,25
0000155622 [ncp.at] TRACE: < OK
0000170723 [ncp.at] TRACE: > AT+CEREG?
0000170726 [ncp.at] TRACE: < +CEREG: 2,4
0000170727 [ncp.at] TRACE: < OK
0000170728 [ncp.at] TRACE: > AT+UCGED?
0000170734 [ncp.at] TRACE: < +UCGED: 2
0000170735 [ncp.at] TRACE: < 6,2,fff,fff
0000170735 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,25
0000170736 [ncp.at] TRACE: < OK
0000184937 [ncp.at] TRACE: > AT+CIMI
0000184958 [ncp.at] TRACE: < 234500068360635
0000184959 [ncp.at] TRACE: < OK
0000185760 [ncp.at] TRACE: > AT+CEREG?
0000185763 [ncp.at] TRACE: < +CEREG: 2,4
0000185764 [ncp.at] TRACE: < OK
0000185765 [ncp.at] TRACE: > AT+UCGED?
0000185771 [ncp.at] TRACE: < +UCGED: 2
0000185772 [ncp.at] TRACE: < 6,2,fff,fff
0000185772 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,25
0000185773 [ncp.at] TRACE: < OK
0000200874 [ncp.at] TRACE: > AT+CEREG?
0000200877 [ncp.at] TRACE: < +CEREG: 2,4
0000200878 [ncp.at] TRACE: < OK
0000200879 [ncp.at] TRACE: > AT+UCGED?
0000200885 [ncp.at] TRACE: < +UCGED: 2
0000200886 [ncp.at] TRACE: < 6,2,fff,fff
0000200886 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,25
0000200887 [ncp.at] TRACE: < OK
0000215988 [ncp.at] TRACE: > AT+CEREG?
0000215991 [ncp.at] TRACE: < +CEREG: 2,4
0000215992 [ncp.at] TRACE: < OK
0000215993 [ncp.at] TRACE: > AT+UCGED?
0000215999 [ncp.at] TRACE: < +UCGED: 2
0000216000 [ncp.at] TRACE: < 6,2,fff,fff
0000216000 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,25
0000216001 [ncp.at] TRACE: < OK
0000231102 [ncp.at] TRACE: > AT+CEREG?
0000231105 [ncp.at] TRACE: < +CEREG: 2,4
0000231106 [ncp.at] TRACE: < OK
0000231107 [ncp.at] TRACE: > AT+UCGED?
0000231113 [ncp.at] TRACE: < +UCGED: 2
0000231114 [ncp.at] TRACE: < 6,2,fff,fff
0000231114 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,25
0000231115 [ncp.at] TRACE: < OK
0000245016 [ncp.at] TRACE: > AT+CIMI
0000245037 [ncp.at] TRACE: < 234500068360635
0000245038 [ncp.at] TRACE: < OK
0000246139 [ncp.at] TRACE: > AT+CEREG?
0000246141 [ncp.at] TRACE: < +CEREG: 2,4
0000246142 [ncp.at] TRACE: < OK
0000246142 [ncp.at] TRACE: > AT+UCGED?
0000246149 [ncp.at] TRACE: < +UCGED: 2
0000246150 [ncp.at] TRACE: < 6,2,fff,fff
0000246150 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,25
0000246151 [ncp.at] TRACE: < OK
0000261252 [ncp.at] TRACE: > AT+CEREG?
0000261255 [ncp.at] TRACE: < +CEREG: 2,4
0000261256 [ncp.at] TRACE: < OK
0000261257 [ncp.at] TRACE: > AT+UCGED?
0000261263 [ncp.at] TRACE: < +UCGED: 2
0000261264 [ncp.at] TRACE: < 6,2,fff,fff
0000261264 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,25
0000261265 [ncp.at] TRACE: < OK
0000276366 [ncp.at] TRACE: > AT+CEREG?
0000276369 [ncp.at] TRACE: < +CEREG: 2,4
0000276370 [ncp.at] TRACE: < OK
0000276371 [ncp.at] TRACE: > AT+UCGED?
0000276377 [ncp.at] TRACE: < +UCGED: 2
0000276378 [ncp.at] TRACE: < 6,3,fff,fff
0000276378 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,25
0000276379 [ncp.at] TRACE: < OK
0000291480 [ncp.at] TRACE: > AT+CEREG?
0000291483 [ncp.at] TRACE: < +CEREG: 2,4
0000291484 [ncp.at] TRACE: < OK
0000291485 [ncp.at] TRACE: > AT+UCGED?
0000291491 [ncp.at] TRACE: < +UCGED: 2
0000291492 [ncp.at] TRACE: < 6,2,fff,fff
0000291492 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,25
0000291493 [ncp.at] TRACE: < OK
0000305094 [ncp.at] TRACE: > AT+CIMI
0000305115 [ncp.at] TRACE: < 234500068360635
0000305116 [ncp.at] TRACE: < OK
0000306517 [ncp.at] TRACE: > AT+CEREG?
0000306520 [ncp.at] TRACE: < +CEREG: 2,4
0000306521 [ncp.at] TRACE: < OK
0000306522 [ncp.at] TRACE: > AT+UCGED?
0000306528 [ncp.at] TRACE: < +UCGED: 2
0000306529 [ncp.at] TRACE: < 6,2,fff,fff
0000306529 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,25
0000306530 [ncp.at] TRACE: < OK
0000321631 [ncp.at] TRACE: > AT+CEREG?
0000321634 [ncp.at] TRACE: < +CEREG: 2,4
0000321635 [ncp.at] TRACE: < OK
0000321636 [ncp.at] TRACE: > AT+UCGED?
0000321642 [ncp.at] TRACE: < +UCGED: 2
0000321643 [ncp.at] TRACE: < 6,2,fff,fff
0000321643 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,25
0000321644 [ncp.at] TRACE: < OK
0000336745 [ncp.at] TRACE: > AT+CEREG?
0000336748 [ncp.at] TRACE: < +CEREG: 2,4
0000336749 [ncp.at] TRACE: < OK
0000336750 [ncp.at] TRACE: > AT+UCGED?
0000336756 [ncp.at] TRACE: < +UCGED: 2
0000336757 [ncp.at] TRACE: < 6,2,fff,fff
0000336757 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,25
0000336758 [ncp.at] TRACE: < OK
0000351859 [ncp.at] TRACE: > AT+CEREG?
0000351862 [ncp.at] TRACE: < +CEREG: 2,4
0000351863 [ncp.at] TRACE: < OK
0000351864 [ncp.at] TRACE: > AT+UCGED?
0000351870 [ncp.at] TRACE: < +UCGED: 2
0000351871 [ncp.at] TRACE: < 6,2,fff,fff
0000351871 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,25
0000351872 [ncp.at] TRACE: < OK
0000365173 [ncp.at] TRACE: > AT+CIMI
0000365194 [ncp.at] TRACE: < 234500068360635
0000365195 [ncp.at] TRACE: < OK
0000366896 [ncp.at] TRACE: > AT+CEREG?
0000366899 [ncp.at] TRACE: < +CEREG: 2,4
0000366900 [ncp.at] TRACE: < OK
0000366901 [ncp.at] TRACE: > AT+UCGED?
0000366907 [ncp.at] TRACE: < +UCGED: 2
0000366908 [ncp.at] TRACE: < 6,2,fff,fff
0000366909 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,25
0000366909 [ncp.at] TRACE: < OK
0000382010 [ncp.at] TRACE: > AT+CEREG?
0000382013 [ncp.at] TRACE: < +CEREG: 2,4
0000382014 [ncp.at] TRACE: < OK
0000382015 [ncp.at] TRACE: > AT+UCGED?
0000382021 [ncp.at] TRACE: < +UCGED: 2
0000382022 [ncp.at] TRACE: < 6,2,fff,fff
0000382022 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,25
0000382023 [ncp.at] TRACE: < OK
0000397124 [ncp.at] TRACE: > AT+CEREG?
0000397127 [ncp.at] TRACE: < +CEREG: 2,4
0000397128 [ncp.at] TRACE: < OK
0000397129 [ncp.at] TRACE: > AT+UCGED?
0000397135 [ncp.at] TRACE: < +UCGED: 2
0000397136 [ncp.at] TRACE: < 6,2,fff,fff
0000397136 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,25
0000397137 [ncp.at] TRACE: < OK
0000412238 [ncp.at] TRACE: > AT+CEREG?
0000412241 [ncp.at] TRACE: < +CEREG: 2,4
0000412242 [ncp.at] TRACE: < OK
0000412243 [ncp.at] TRACE: > AT+UCGED?
0000412249 [ncp.at] TRACE: < +UCGED: 2
0000412250 [ncp.at] TRACE: < 6,3,fff,fff
0000412250 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,25
0000412251 [ncp.at] TRACE: < OK
0000425252 [ncp.at] TRACE: > AT+CIMI
0000425272 [ncp.at] TRACE: < 234500068360635
0000425272 [ncp.at] TRACE: < OK
0000427273 [ncp.at] TRACE: > AT+CEREG?
0000427276 [ncp.at] TRACE: < +CEREG: 2,4
0000427277 [ncp.at] TRACE: < OK
0000427278 [ncp.at] TRACE: > AT+UCGED?
0000427284 [ncp.at] TRACE: < +UCGED: 2
0000427285 [ncp.at] TRACE: < 6,3,fff,fff
0000427285 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,25
0000427286 [ncp.at] TRACE: < OK
0000442387 [ncp.at] TRACE: > AT+CEREG?
0000442390 [ncp.at] TRACE: < +CEREG: 2,4
0000442391 [ncp.at] TRACE: < OK
0000442392 [ncp.at] TRACE: > AT+UCGED?
0000442398 [ncp.at] TRACE: < +UCGED: 2
0000442399 [ncp.at] TRACE: < 6,2,fff,fff
0000442400 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,25
0000442400 [ncp.at] TRACE: < OK
0000457501 [ncp.at] TRACE: > AT+CEREG?
0000457504 [ncp.at] TRACE: < +CEREG: 2,4
0000457505 [ncp.at] TRACE: < OK
0000457506 [ncp.at] TRACE: > AT+UCGED?
0000457512 [ncp.at] TRACE: < +UCGED: 2
0000457513 [ncp.at] TRACE: < 6,2,fff,fff
0000457513 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,25
0000457514 [ncp.at] TRACE: < OK
0000472615 [ncp.at] TRACE: > AT+CEREG?
0000472618 [ncp.at] TRACE: < +CEREG: 2,4
0000472619 [ncp.at] TRACE: < OK
0000472620 [ncp.at] TRACE: > AT+UCGED?
0000472626 [ncp.at] TRACE: < +UCGED: 2
0000472627 [ncp.at] TRACE: < 6,2,fff,fff
0000472627 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,25
0000472628 [ncp.at] TRACE: < OK
0000485329 [ncp.at] TRACE: > AT+CIMI
0000485349 [ncp.at] TRACE: < 234500068360635
0000485350 [ncp.at] TRACE: < OK
0000487651 [ncp.at] TRACE: > AT+CEREG?
0000487654 [ncp.at] TRACE: < +CEREG: 2,4
0000487655 [ncp.at] TRACE: < OK
0000487656 [ncp.at] TRACE: > AT+UCGED?
0000487662 [ncp.at] TRACE: < +UCGED: 2
0000487663 [ncp.at] TRACE: < 6,2,fff,fff
0000487663 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,25
0000487664 [ncp.at] TRACE: < OK
0000502765 [ncp.at] TRACE: > AT+CEREG?
0000502768 [ncp.at] TRACE: < +CEREG: 2,4
0000502769 [ncp.at] TRACE: < OK
0000502770 [ncp.at] TRACE: > AT+UCGED?
0000502776 [ncp.at] TRACE: < +UCGED: 2
0000502777 [ncp.at] TRACE: < 6,2,fff,fff
0000502777 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,25
0000502778 [ncp.at] TRACE: < OK
0000517879 [ncp.at] TRACE: > AT+CEREG?
0000517882 [ncp.at] TRACE: < +CEREG: 2,4
0000517883 [ncp.at] TRACE: < OK
0000517884 [ncp.at] TRACE: > AT+UCGED?
0000517890 [ncp.at] TRACE: < +UCGED: 2
0000517891 [ncp.at] TRACE: < 6,2,fff,fff
0000517891 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,25
0000517892 [ncp.at] TRACE: < OK
0000532993 [ncp.at] TRACE: > AT+CEREG?
0000532996 [ncp.at] TRACE: < +CEREG: 2,4
0000532997 [ncp.at] TRACE: < OK
0000532998 [ncp.at] TRACE: > AT+UCGED?
0000533004 [ncp.at] TRACE: < +UCGED: 2
0000533005 [ncp.at] TRACE: < 6,2,fff,fff
0000533005 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,25
0000533006 [ncp.at] TRACE: < OK
0000545407 [ncp.at] TRACE: > AT+CIMI
0000545427 [ncp.at] TRACE: < 234500068360635
0000545428 [ncp.at] TRACE: < OK
0000548029 [ncp.at] TRACE: > AT+CEREG?
0000548032 [ncp.at] TRACE: < +CEREG: 2,4
0000548033 [ncp.at] TRACE: < OK
0000548034 [ncp.at] TRACE: > AT+UCGED?
0000548040 [ncp.at] TRACE: < +UCGED: 2
0000548041 [ncp.at] TRACE: < 6,3,fff,fff
0000548041 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,25
0000548042 [ncp.at] TRACE: < OK
0000563143 [ncp.at] TRACE: > AT+CEREG?
0000563146 [ncp.at] TRACE: < +CEREG: 2,4
0000563147 [ncp.at] TRACE: < OK
0000563148 [ncp.at] TRACE: > AT+UCGED?
0000563154 [ncp.at] TRACE: < +UCGED: 2
0000563155 [ncp.at] TRACE: < 6,2,fff,fff
0000563156 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,25
0000563156 [ncp.at] TRACE: < OK
0000578257 [ncp.at] TRACE: > AT+CEREG?
0000578260 [ncp.at] TRACE: < +CEREG: 2,4
0000578261 [ncp.at] TRACE: < OK
0000578262 [ncp.at] TRACE: > AT+UCGED?
0000578268 [ncp.at] TRACE: < +UCGED: 2
0000578269 [ncp.at] TRACE: < 6,2,fff,fff
0000578269 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,25
0000578270 [ncp.at] TRACE: < OK
0000593371 [ncp.at] TRACE: > AT+CEREG?
0000593374 [ncp.at] TRACE: < +CEREG: 2,4
0000593375 [ncp.at] TRACE: < OK
0000593376 [ncp.at] TRACE: > AT+UCGED?
0000593382 [ncp.at] TRACE: < +UCGED: 2
0000593383 [ncp.at] TRACE: < 6,2,fff,fff
0000593384 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,25
0000593384 [ncp.at] TRACE: < OK
Any ideas would be greatly appreciated thank you.
There does not appear to be Hologram service at that location using LTE Cat M1, or possibly an activation issue for your SIM card.
6 = radio service
2 = searching
fff,fff = mcc, mnc
There is no tower reporting a mcc and mnc, so those are fff, not a valid carrier and country code.
Not all towers that support 2G/3G support LTE Cat M1, even if they support LTE Cat 1.
If you are not located in the United States, Canada, or Mexico, you may have difficulties with the BRN404X. In particular, if you are in Europe, it will not work because only the North America bands are enabled and it cannot connect to EMEAA bands.
