Boron 404X unable to connect
We have almost the same trouble and can't figure it out, 3 devices are green but not connected to the network. At the same time, the same 404x devices are working in our local area without any problems. Location: Alberta , Particle's embedded simcard.
Maxim
Device ID: e00fce685ee5ec1b7bcabc45
ICCID: 89883070000039801913
IMEI: 351457833745687
IMSI:
Modem Manufacturer: u-blox
Modem Model: SARA-R510S
Modem Firmware Version: 03.15
Modem Application Version: 03.15,A00.01
Power Supply: USB Host
Battery: Unknown
Battery SoC: -1
Country:
Carrier:
Access Technology:
Band:
Cellular Global Identity:
0000000277 [system.nm] TRACE: Request to power on the interface
0000000277 [ncp.client] TRACE: Powering modem on, ncpId: 0x47
0000000278 [ncp.client] TRACE: Modem already on
0000000278 [ncp.client] TRACE: Setting UART voltage translator state 1
0000000280 [system.nm] INFO: State changed: DISABLED -> IFACE_DOWN
0000000379 [ncp.client] TRACE: Setting UART voltage translator state 0
0000000479 [ncp.client] TRACE: Setting UART voltage translator state 1
0000000479 [ncp.client] TRACE: Muxer is not currently running
0000000480 [ncp.client] TRACE: Initialized muxer @ 460800 baudrate
0000000481 [mux] INFO: Starting GSM07.10 muxer
0000000482 [mux] INFO: GSM07.10 muxer thread started
0000000486 [ncp.client] TRACE: Resumed muxed session
0000000486 [mux] INFO: Openning mux channel 1
0000000538 [ncp.at] TRACE: > AT
0000000542 [ncp.at] TRACE: < OK
0000000542 [ncp.client] TRACE: NCP ready to accept AT commands
0000000543 [ncp.at] TRACE: > AT
0000000546 [ncp.at] TRACE: < OK
0000000547 [ncp.at] TRACE: > ATI9
0000000551 [ncp.at] TRACE: < 03.15,A00.01
0000000551 [ncp.at] TRACE: < OK
0000000553 [ncp.client] TRACE: App firmware: 1
0000000553 [ncp.at] TRACE: > AT+UGPIOC?
0000000561 [ncp.at] TRACE: < +UGPIOC:
0000000561 [ncp.at] TRACE: < 16,255
0000000563 [ncp.at] TRACE: < 19,255
0000000563 [ncp.at] TRACE: < 23,0
0000000564 [ncp.at] TRACE: < 24,255
0000000565 [ncp.at] TRACE: < 25,255
0000000565 [ncp.at] TRACE: < 33,255
0000000566 [ncp.at] TRACE: < 42,255
0000000566 [ncp.at] TRACE: < 46,255
0000000567 [ncp.at] TRACE: < OK
0000000568 [ncp.at] TRACE: > AT+UGPIOR=23
0000000572 [ncp.at] TRACE: < +UGPIOR: 23,1
0000000573 [ncp.at] TRACE: < OK
0000000573 [ncp.client] INFO: Using internal SIM card
0000000574 [ncp.at] TRACE: > AT+CPIN?
0000000578 [ncp.at] TRACE: < +CPIN: READY
0000000579 [ncp.at] TRACE: < OK
0000000579 [ncp.at] TRACE: > AT+CCID
0000000604 [ncp.at] TRACE: < +CCID: 89883070000039801913
0000000604 [ncp.at] TRACE: < OK
0000000605 [ncp.at] TRACE: > AT+IFC?
0000000609 [ncp.at] TRACE: < +IFC: 2,2
0000000609 [ncp.at] TRACE: < OK
0000000610 [ncp.at] TRACE: > AT+IFC=2,2
0000000614 [ncp.at] TRACE: < OK
0000000614 [ncp.at] TRACE: > AT
0000000617 [ncp.at] TRACE: < OK
0000000618 [ncp.at] TRACE: > AT+CCID
0000000645 [ncp.at] TRACE: < +CCID: 89883070000039801913
0000000646 [ncp.at] TRACE: < OK
0000000647 [ncp.at] TRACE: > AT+UMNOPROF?
0000000652 [ncp.at] TRACE: < +UMNOPROF: 100
0000000652 [ncp.at] TRACE: < OK
0000000653 [ncp.at] TRACE: > AT+UBANDMASK?
0000000657 [ncp.at] TRACE: < +UBANDMASK: 0,6170,0
0000000658 [ncp.at] TRACE: < OK
0000000659 [ncp.at] TRACE: > AT+COPS=3,2
0000000663 [ncp.at] TRACE: < OK
0000000663 [ncp.at] TRACE: > AT+CGEREP=1,0
0000000666 [ncp.at] TRACE: < OK
0000000667 [ncp.at] TRACE: > AT+URAT?
0000000671 [ncp.at] TRACE: < +URAT: 7
0000000671 [ncp.at] TRACE: < OK
0000000672 [ncp.at] TRACE: > AT+CPSMS?
0000000677 [ncp.at] TRACE: < +CPSMS: 0,,,"00010011","00000011"
0000000677 [ncp.at] TRACE: < OK
0000000678 [ncp.at] TRACE: > AT+CEDRXS?
0000000682 [ncp.at] TRACE: < +CEDRXS: 4,"0000"
0000000683 [ncp.at] TRACE: < OK
0000000683 [mux] INFO: Mux channel 1 already opened
0000000690 [ncp.at] TRACE: > AT
0000000693 [ncp.at] TRACE: < OK
0000000694 [ncp.client] TRACE: NCP state changed: 1
0000000694 [net.pppncp] TRACE: NCP event 1
0000000695 [app] INFO: cellular is on
0000000698 [ncp.at] TRACE: > AT+CCID
0000000699 [app] INFO: Auto-connect disabled
0000000725 [ncp.at] TRACE: < +CCID: 89883070000039801913
0000000727 [ncp.at] TRACE: < OK
0000000729 [ncp.at] TRACE: > AT+CGMI
0000000734 [ncp.at] TRACE: < u-blox
0000000734 [ncp.at] TRACE: < OK
0000000735 [ncp.at] TRACE: > AT+CGMM
0000000740 [ncp.at] TRACE: < SARA-R510S
0000000740 [ncp.at] TRACE: < OK
0000000741 [ncp.at] TRACE: > AT+CGMR
0000000746 [ncp.at] TRACE: < 03.15
0000000746 [ncp.at] TRACE: < OK
0000000747 [ncp.at] TRACE: > AT+CGSN
0000000751 [ncp.at] TRACE: < 351457833745687
0000000753 [ncp.at] TRACE: < OK
0000001143 [ncp.at] TRACE: > AT+CFUN?
0000001146 [ncp.at] TRACE: < +CFUN: 1,7
0000001146 [ncp.at] TRACE: < OK
0000001148 [ncp.at] TRACE: > AT+CCID
0000001174 [ncp.at] TRACE: < +CCID: 89883070000039801913
0000001175 [ncp.at] TRACE: < OK
0000001177 [ncp.at] TRACE: > AT+CGSN
0000001181 [ncp.at] TRACE: < 351457833745687
0000001183 [ncp.at] TRACE: < OK
0000001185 [ncp.at] TRACE: > ATI9
0000001188 [ncp.at] TRACE: < 03.15,A00.01
0000001188 [ncp.at] TRACE: < OK
0000001632 [system.nm] INFO: State changed: IFACE_DOWN -> IFACE_REQUEST_UP
0000001634 [system.nm] INFO: State changed: IFACE_REQUEST_UP -> IFACE_UP
0000001635 [net.ppp.client] TRACE: PPP thread event ADM_UP data=0
0000001635 [net.ppp.client] TRACE: State NONE -> READY
0000001638 [ncp.at] TRACE: > AT+CFUN?
0000001642 [ncp.at] TRACE: < +CFUN: 1,7
0000001642 [ncp.at] TRACE: < OK
0000001643 [ncp.at] TRACE: > AT+CCID
0000001670 [ncp.at] TRACE: < +CCID: 89883070000039801913
0000001671 [ncp.at] TRACE: < OK
0000001672 [ncp.at] TRACE: > AT+CGDCONT?
0000001678 [ncp.at] TRACE: < +CGDCONT: 1,"IP","super","0.0.0.0",0,0,0,2,0,0,0,0,0,0,0
0000001678 [ncp.at] TRACE: < OK
0000001679 [ncp.at] TRACE: > AT+CFUN?
0000001683 [ncp.at] TRACE: < +CFUN: 1,7
0000001683 [ncp.at] TRACE: < OK
0000001684 [ncp.at] TRACE: > AT+CEREG=2
0000001688 [ncp.at] TRACE: < OK
0000001688 [ncp.client] TRACE: NCP connection state changed: 1
0000001689 [net.pppncp] TRACE: NCP event 2
0000001689 [net.pppncp] TRACE: State changed event: 1
0000001690 [net.ppp.client] TRACE: PPP thread event LOWER_DOWN data=0
0000001691 [ncp.at] TRACE: > AT+COPS?
0000001694 [ncp.at] TRACE: < +COPS: 0
0000001694 [ncp.at] TRACE: < OK
0000001695 [ncp.at] TRACE: > AT+CEREG?
0000001699 [ncp.at] TRACE: < +CEREG: 2,4
0000001700 [ncp.at] TRACE: < OK
0000016700 [ncp.at] TRACE: > AT+CEREG?
0000016704 [ncp.at] TRACE: < +CEREG: 2,4
0000016705 [ncp.at] TRACE: < OK
0000016705 [ncp.at] TRACE: > AT+UCGED?
0000016712 [ncp.at] TRACE: < +UCGED: 2
0000016713 [ncp.at] TRACE: < 6,2,fff,fff
0000016713 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,25
0000016714 [ncp.at] TRACE: < OK
0000031814 [ncp.at] TRACE: > AT+CEREG?
0000031818 [ncp.at] TRACE: < +CEREG: 2,4
0000031819 [ncp.at] TRACE: < OK
0000031820 [ncp.at] TRACE: > AT+UCGED?
0000031826 [ncp.at] TRACE: < +UCGED: 2
0000031827 [ncp.at] TRACE: < 6,3,fff,fff
0000031827 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,25
0000031828 [ncp.at] TRACE: < OK
I moved this into a separate topic because it was unrelated to the other post.
This error indicates that there are no compatible towers in the area. This could also be an antenna issue.
Your SIM is activated and looks normal on the network side, though if it was deactivated you'd get a different debug log.
Thank you sir
