I do not see my Photon on /dev/tty.* as I used to.
Configuration:
Photon f/w: 2.3.0
particle-cli: 3.1.0
macos: 12.2.1
shell: zsh
connection: I cannot bypass a hub here as my mac only has USB-C ports and I do not have a µB <–> C cable. I have tried multiple hubs and cables however.
Obviously particle-cli nor dfu-util sees my device.
I used to be able to see the /dev/tty.usbmodem*
Is there an issue with the Monterey drivers?
There is no known problem with that combination. I flashed 2.3.0 to a Photon and tested Monterey 12.2.1 and it worked properly:
% ls -l /dev/tty.usb*
crw-rw-rw- 1 root wheel 0x9000006 Mar 7 17:12 /dev/tty.usbmodem1414201
Does anything show up with:
ioreg -p IOUSB -n Photon
Not sure if you’re on M1 mac or not, but it all works properly on my M1 running Monterey over the apple USB C adapter to a photon.
Probably a stupid question, but have you confirmed that the device is in serial mode? Do you have a different photon you can try to rule out any device issues?
