Not sure what I’m doing wrong. Here are the steps I’m taking;
- Unclaimed a Boron LTE from my development main account
- Added the device to a test product as approved devices
- Powered up the device
- Created a test customer account
- Generated the access token for that customer account
- Used the access token from that customer and the IMEI/ICCID/ID to generate the claim code
curl -X POST -H "Authorization: Bearer xxxxxxxx" https://api.particle.io/v1/products/xxxx/device_claims?xxxxxx
Response:
{"claim_code":"xxxxxxxx","device_ids":[]}
Nothing happens. I see the customer account under the product but no devices are attached to it. Rebooted the Boron/waited 30 minutes but no dice.
Also tried:
curl “https://api.particle.io/v1/device_claims?access_token=XXXXXXX” -d id=XXXXX
