Hello!
I have a Boron with a 3rd party SIM, it is currently breathing Cyan (which I understand it means its already connected to the network ). Nevertheless, I’m unable to claim it, I tried through the web editor and the CLI, It just says the device is not connected. I checked the device ID using the CL. As a newbie, I’m out of ideas…
Yes sir, I’m exactly following that tutorial . I’m stuck in the “claiming device” part, I cant do it despite my Boron is breathing cyan. It does not say anything about what to try if you cant claim the device.
Well, your 3rd party SIM probably has a short keepalive time and you will need to flash a user firmware that sets it to a much lower value for it to remain “online” for claiming.
I solved it, it was a very stupid mistake in deed. It turns out it wasnt breathing Cyan, it was breathing white, which means a total different history. I updated the firmware and it works! Thank you!
