Boron stuck in rapid cyan blink
After going over on my data limit and un-pausing the SIM card, I cannot get the Boron to connect to the particle cloud. It is stuck in rapid blinking cyan mode.
I have tried to reset the device firmware, factory reset the device, and even unclaimed the device. Now I’m trying to reclaim the device, but it keeps failing because it is not connected to the particle cloud. Any ideas?
Hi @MikeG -
I don't have much experience with Boron but if what I read in this thread:
is indeed correct, it seems you will have to submit a support ticket. I suppose you have tried particle flash --serial tinker via CLI as it seems to solve many problems :slight_smile:
Regards,
F.
