Boron not connecting to network (blinking green)
I'm a long term Particle user, but I'm stuck with a Boron not registering into network.
I have a fleet of Borons working correctly with 3rd-party SIMs (the internal SIMs have never been activated).
I want to use one of this Borons in a different project (and with a different user account), then:
  • I have unclaimed the device from original user account and claimed it with the new one (device correctly appears into new user devices list).
  • I have switched back to internal MFF2 SIM (flashing special code, following documentation).
  • I have removed 3rd party SIM card
  • When I setup the device (in new account) it gets stuck in last step (device activation) -> Led blinking green.
  • When using Device doctor, it stucks in "connecting to network" -> Led blinking green.
  • I have tried "Device restore over USB" tool with same results.
Boron is a BRN310 model.
Connecting from Spain.
I also see that SIM card is not appearing in "SIM Cards" user account. If I try to import the SIM I get:
`There was a problem acting on your SIM: {"error_description":"SimCard validation failed: status: status must be one of the following: never_before_activated, active, inactive_user_deactivated, inactive_data_limit_reached, inactive_invalid_payment_method","error":"server_error"}
Device doctor log:
> Modem Manufacturer: u-blox
> Modem Model: SARA-U201
> Modem Firmware Version: 23.60
> Modem Application Version: 23.60,A01.01
> Power Supply: USB Host
> Battery: Charged
> Battery SoC: 97.6836
> Country:
> Carrier:
> Access Technology:
> Band:
> Cellular Global Identity:
> 0000000270 [system.nm] TRACE: Request to power on the interface
> 0000000270 [ncp.client] TRACE: Powering modem on, ncpId: 0x42
> 0000000271 [ncp.client] TRACE: Modem already on
> 0000000271 [ncp.client] TRACE: Setting UART voltage translator state 1
> 0000000273 [system.nm] INFO: State changed: DISABLED -> IFACE_DOWN
> 0000000372 [ncp.client] TRACE: Setting UART voltage translator state 0
> 0000000472 [ncp.client] TRACE: Setting UART voltage translator state 1
> 0000000472 [ncp.client] TRACE: Muxer is not currently running
> 0000000473 [ncp.client] TRACE: Initialized muxer @ 921600 baudrate
> 0000000474 [mux] INFO: Starting GSM07.10 muxer
> 0000000475 [mux] INFO: GSM07.10 muxer thread started
> 0000000477 [ncp.client] TRACE: Resumed muxed session
> 0000000477 [mux] INFO: Openning mux channel 1
> 0000000827 [mux] INFO: Closing mux channel 2
> 0000001153 [app] INFO: Auto-connect disabled
> 0000001177 [ncp.at] TRACE: > AT
> 0000001180 [ncp.at] TRACE: < A
> 0000001180 [ncp.at] TRACE: < ABORTED
> 0000002179 [ncp.at] TRACE: > AT
> 0000002181 [ncp.at] TRACE: < OK
> 0000002181 [ncp.client] TRACE: NCP ready to accept AT commands
> 0000002182 [ncp.at] TRACE: > AT
> 0000002185 [ncp.at] TRACE: < OK
> 0000002186 [ncp.at] TRACE: > ATI9
> 0000002199 [ncp.at] TRACE: < 23.60,A01.01
> 0000002200 [ncp.at] TRACE: < OK
> 0000002200 [ncp.client] TRACE: App firmware: 101
> 0000002201 [ncp.at] TRACE: > AT+UGPIOC?
> 0000002205 [ncp.at] TRACE: < +UGPIOC:
> 0000002205 [ncp.at] TRACE: < 16,255
> 0000002206 [ncp.at] TRACE: < 23,255
> 0000002206 [ncp.at] TRACE: < 24,4
> 0000002207 [ncp.at] TRACE: < 25,5
> 0000002207 [ncp.at] TRACE: < 34,12
> 0000002208 [ncp.at] TRACE: < 35,12
> 0000002209 [ncp.at] TRACE: < 36,12
> 0000002209 [ncp.at] TRACE: < 37,12
> 0000002210 [ncp.at] TRACE: < 42,7
> 0000002210 [ncp.at] TRACE: < OK
> 0000002211 [ncp.client] INFO: Using internal SIM card
> 0000002212 [ncp.at] TRACE: > AT+CPIN?
> 0000002215 [ncp.at] TRACE: < +CPIN: READY
> 0000002215 [ncp.at] TRACE: < OK
> 0000002216 [ncp.at] TRACE: > AT+CCID
> 0000002233 [ncp.at] TRACE: < +CCID: 89314404000791932883
> 0000002234 [ncp.at] TRACE: < OK
> 0000002235 [ncp.at] TRACE: > AT+IFC?
> 0000002238 [ncp.at] TRACE: < +IFC: 2,2
> 0000002238 [ncp.at] TRACE: < OK
> 0000002239 [ncp.at] TRACE: > AT+IFC=2,2
> 0000002241 [ncp.at] TRACE: < OK
> 0000002242 [ncp.at] TRACE: > AT
> 0000002245 [ncp.at] TRACE: < OK
> 0000002246 [ncp.at] TRACE: > AT+COPS=3,2
> 0000002249 [ncp.at] TRACE: < OK
> 0000002250 [ncp.at] TRACE: > AT+CGEREP=1,0
> 0000002252 [ncp.at] TRACE: < OK
> 0000002253 [ncp.at] TRACE: > AT+UPSV=0
> 0000002255 [ncp.at] TRACE: < OK
> 0000002256 [mux] INFO: Mux channel 1 already opened
> 0000002257 [ncp.at] TRACE: > AT
> 0000002259 [ncp.at] TRACE: < OK
> 0000002259 [ncp.client] TRACE: NCP state changed: 1
> 0000002260 [net.pppncp] TRACE: NCP event 1
> 0000002262 [ncp.at] TRACE: > AT+CFUN?
> 0000002265 [ncp.at] TRACE: < +CFUN: 1,0
> 0000002265 [ncp.at] TRACE: < OK
> 0000002266 [ncp.at] TRACE: > AT+CCID
> 0000002269 [app] INFO: cellular is on
> 0000002283 [ncp.at] TRACE: < +CCID: 89314404000791932883
> 0000002284 [ncp.at] TRACE: < OK
> 0000002285 [ncp.at] TRACE: > AT+CGSN
> 0000002298 [ncp.at] TRACE: < 358887099135095
> 0000002299 [ncp.at] TRACE: < OK
> 0000002300 [ncp.at] TRACE: > ATI9
> 0000002311 [ncp.at] TRACE: < 23.60,A01.01
> 0000002312 [ncp.at] TRACE: < OK
> 0000002315 [ncp.at] TRACE: > AT+CCID
> 0000002330 [ncp.at] TRACE: < +CCID: 89314404000791932883
> 0000002332 [ncp.at] TRACE: < OK
> 0000002334 [ncp.at] TRACE: > AT+CGMI
> 0000002338 [ncp.at] TRACE: < u-blox
> 0000002338 [ncp.at] TRACE: < OK
> 0000002340 [ncp.at] TRACE: > AT+CGMM
> 0000002342 [ncp.at] TRACE: < SARA-U201
> 0000002344 [ncp.at] TRACE: < OK
> 0000002345 [ncp.at] TRACE: > AT+CGMR
> 0000002347 [ncp.at] TRACE: < 23.60
> 0000002349 [ncp.at] TRACE: < OK
> 0000002351 [ncp.at] TRACE: > AT+CGSN
> 0000002365 [ncp.at] TRACE: < 358887099135095
> 0000002365 [ncp.at] TRACE: < OK
> 0000002970 [system.nm] INFO: State changed: IFACE_DOWN -> IFACE_REQUEST_UP
> 0000002973 [net.ppp.client] TRACE: PPP thread event ADM_UP data=0
> 0000002973 [net.ppp.client] TRACE: State NONE -> READY
> 0000002976 [ncp.at] TRACE: > AT+CFUN?
> 0000002977 [system.nm] INFO: State changed: IFACE_REQUEST_UP -> IFACE_UP
> 0000002979 [ncp.at] TRACE: < +CFUN: 1,0
> 0000002980 [ncp.at] TRACE: < OK
> 0000002981 [ncp.at] TRACE: > AT+CCID
> 0000002999 [ncp.at] TRACE: < +CCID: 89314404000791932883
> 0000002999 [ncp.at] TRACE: < OK
> 0000003000 [ncp.at] TRACE: > AT+CIMI
> 0000003003 [ncp.at] TRACE: < 204047125260617
> 0000003004 [ncp.at] TRACE: < OK
> 0000003005 [ncp.at] TRACE: > AT+CGDCONT?
> 0000003008 [ncp.at] TRACE: < +CGDCONT: 1,"IP","vfd1.korem2m.com","0.0.0.0",0,0
> 0000003009 [ncp.at] TRACE: < OK
> 0000003010 [ncp.at] TRACE: > AT+CFUN?
> 0000003013 [ncp.at] TRACE: < +CFUN: 1,0
> 0000003013 [ncp.at] TRACE: < OK
> 0000003014 [ncp.at] TRACE: > AT+CREG=2
> 0000003017 [ncp.at] TRACE: < OK
> 0000003018 [ncp.at] TRACE: > AT+CGREG=2
> 0000003020 [ncp.at] TRACE: < OK
> 0000003021 [ncp.client] TRACE: NCP connection state changed: 1
> 0000003022 [net.pppncp] TRACE: NCP event 2
> 0000003022 [net.pppncp] TRACE: State changed event: 1
> 0000003023 [ncp.at] TRACE: > AT+COPS?
> 0000003024 [net.ppp.client] TRACE: PPP thread event LOWER_DOWN data=0
> 0000003026 [ncp.at] TRACE: < +COPS: 0
> 0000003026 [ncp.at] TRACE: < OK
> 0000003027 [ncp.at] TRACE: > AT+CREG?
> 0000003030 [ncp.at] TRACE: < +CREG: 2,0
> 0000003031 [ncp.at] TRACE: < OK
> 0000003032 [ncp.at] TRACE: > AT+CGREG?
> 0000003035 [ncp.at] TRACE: < +CGREG: 2,0
> 0000003036 [ncp.at] TRACE: < OK
> 0000018036 [ncp.at] TRACE: > AT+CEER
> 0000018040 [ncp.at] TRACE: < +CEER: "No report available"
> 0000018040 [ncp.at] TRACE: < OK
> 0000018041 [ncp.at] TRACE: > AT+CREG?
> 0000018044 [ncp.at] TRACE: < +CREG: 2,0
> 0000018045 [ncp.at] TRACE: < OK
> 0000018045 [ncp.at] TRACE: > AT+CGREG?
> 0000018049 [ncp.at] TRACE: < +CGREG: 2,0
> 0000018049 [ncp.at] TRACE: < OK
> 0000018050 [ncp.at] TRACE: > AT+CSQ
> 0000018053 [ncp.at] TRACE: < +CSQ: 99,99
> 0000018054 [ncp.at] TRACE: < OK
> 0000018154 [ncp.client] TRACE: Sticky not registering CSD state for 15 s, PLMN reselection
> 0000018155 [ncp.at] TRACE: > AT+COPS=0,2
> 0000024721 [ncp.at] TRACE: < ERROR
> 0000024822 [ncp.at] TRACE: < +CGEV: NW CLASS A
> 0000024822 [ncp.at] TRACE: < +CREG: 3
> 0000024923 [ncp.at] TRACE: < +CGREG: 3
> 0000025023 [ncp.at] TRACE: < ERROR
> 0000033123 [ncp.at] TRACE: > AT+CEER
> 0000033127 [ncp.at] TRACE: < +CEER: "No report available"
> 0000033128 [ncp.at] TRACE: < OK
> 0000033128 [ncp.at] TRACE: > AT+CREG?
> 0000033132 [ncp.at] TRACE: < +CREG: 2,3
> 0000033132 [ncp.at] TRACE: < OK
> 0000033133 [ncp.at] TRACE: > AT+CGREG?
> 0000033136 [ncp.at] TRACE: < +CGREG: 2,3
> 0000033137 [ncp.at] TRACE: < OK
> 0000033138 [ncp.at] TRACE: > AT+CSQ
> 0000033141 [ncp.at] TRACE: < +CSQ: 15,1
> 0000033141 [ncp.at] TRACE: < OK
> 0000048142 [ncp.at] TRACE: > AT+CEER
> 0000048146 [ncp.at] TRACE: < +CEER: "No report available"
> 0000048146 [ncp.at] TRACE: < OK
> 0000048147 [ncp.at] TRACE: > AT+CREG?
> 0000048150 [ncp.at] TRACE: < +CREG: 2,3
> 0000048151 [ncp.at] TRACE: < OK
> 0000048151 [ncp.at] TRACE: > AT+CGREG?
> 0000048154 [ncp.at] TRACE: < +CGREG: 2,3
> 0000048155 [ncp.at] TRACE: < OK
> 0000048156 [ncp.at] TRACE: > AT+CSQ
> 0000048159 [ncp.at] TRACE: < +CSQ: 14,1
> 0000048159 [ncp.at] TRACE: < OK
> 0000054860 [ncp.client] TRACE: Sticky CSD and PSD denied state for 30 s, RF reset
> 0000054861 [ncp.at] TRACE: > AT+CFUN=0,0
> 0000054890 [ncp.at] TRACE: < OK
> 0000054890 [ncp.at] TRACE: > AT+CFUN=1,0
> 0000054891 [ncp.at] TRACE: < +CREG: 0
> 0000054892 [ncp.at] TRACE: < +CGREG: 0
> 0000054902 [ncp.at] TRACE: < OK
> 0000055003 [ncp.at] TRACE: < +CGEV: ME CLASS B
> 0000057703 [ncp.at] TRACE: < +CGEV: NW CLASS CC
> 0000057703 [ncp.at] TRACE: < +CREG: 3
> 0000057804 [ncp.at] TRACE: < +CGREG: 3
> 0000063104 [ncp.at] TRACE: > AT+CIMI
> 0000063108 [ncp.at] TRACE: < 204047125260617
> 0000063108 [ncp.at] TRACE: < OK
> 0000063209 [ncp.at] TRACE: > AT+CEER
> 0000063212 [ncp.at] TRACE: < +CEER: "No report available"
> 0000063213 [ncp.at] TRACE: < OK
> 0000063213 [ncp.at] TRACE: > AT+CREG?
> 0000063217 [ncp.at] TRACE: < +CREG: 2,3
> 0000063217 [ncp.at] TRACE: < OK
> 0000063218 [ncp.at] TRACE: > AT+CGREG?
> 0000063221 [ncp.at] TRACE: < +CGREG: 2,3
> 0000063221 [ncp.at] TRACE: < OK
> 0000063222 [ncp.at] TRACE: > AT+CSQ
> 0000063225 [ncp.at] TRACE: < +CSQ: 14,1
> 0000063225 [ncp.at] TRACE: < OK
> 0000078226 [ncp.at] TRACE: > AT+CEER
> 0000078229 [ncp.at] TRACE: < +CEER: "No report available"
> 0000078230 [ncp.at] TRACE: < OK
> 0000078231 [ncp.at] TRACE: > AT+CREG?
> 0000078233 [ncp.at] TRACE: < +CREG: 2,3
> 0000078234 [ncp.at] TRACE: < OK
> 0000078235 [ncp.at] TRACE: > AT+CGREG?
> 0000078238 [ncp.at] TRACE: < +CGREG: 2,3
> 0000078239 [ncp.at] TRACE: < OK
> 0000078239 [ncp.at] TRACE: > AT+CSQ
> 0000078242 [ncp.at] TRACE: < +CSQ: 14,2
> 0000078243 [ncp.at] TRACE: < OK
> 0000093243 [ncp.at] TRACE: > AT+CEER
> 0000093247 [ncp.at] TRACE: < +CEER: "No report available"
> 0000093247 [ncp.at] TRACE: < OK
> 0000093248 [ncp.at] TRACE: > AT+CREG?
> 0000093251 [ncp.at] TRACE: < +CREG: 2,3
> 0000093252 [ncp.at] TRACE: < OK
> 0000093253 [ncp.at] TRACE: > AT+CGREG?
> 0000093256 [ncp.at] TRACE: < +CGREG: 2,3
> 0000093257 [ncp.at] TRACE: < OK
> 0000093258 [ncp.at] TRACE: > AT+CSQ
> 0000093261 [ncp.at] TRACE: < +CSQ: 14,2
> 0000093261 [ncp.at] TRACE: < OK
> 0000102762 [ncp.client] TRACE: Sticky CSD and PSD denied state for 45 s, RF reset
> 0000102763 [ncp.at] TRACE: > AT+CFUN=0,0
> 0000102789 [ncp.at] TRACE: < OK
> 0000102790 [ncp.at] TRACE: > AT+CFUN=1,0
> 0000102791 [ncp.at] TRACE: < +CREG: 0
> 0000102791 [ncp.at] TRACE: < +CGREG: 0
> 0000102803 [ncp.at] TRACE: < OK
> 0000102904 [ncp.at] TRACE: < +CGEV: ME CLASS B
> 0000105704 [ncp.at] TRACE: < +CGEV: NW CLASS CC
> 0000105704 [ncp.at] TRACE: < +CREG: 3
> 0000105805 [ncp.at] TRACE: < +CGREG: 3
> 0000108305 [ncp.at] TRACE: > AT+CEER
> 0000108308 [ncp.at] TRACE: < +CEER: "No report available"
> 0000108309 [ncp.at] TRACE: < OK
> 0000108310 [ncp.at] TRACE: > AT+CREG?
> 0000108312 [ncp.at] TRACE: < +CREG: 2,3
> 0000108313 [ncp.at] TRACE: < OK
> 0000108314 [ncp.at] TRACE: > AT+CGREG?
> 0000108317 [ncp.at] TRACE: < +CGREG: 2,3
> 0000108317 [ncp.at] TRACE: < OK
> 0000108318 [ncp.at] TRACE: > AT+CSQ
> 0000108321 [ncp.at] TRACE: < +CSQ: 23,4
> 0000108321 [ncp.at] TRACE: < OK
> 0000123122 [ncp.at] TRACE: > AT+CIMI
> 0000123125 [ncp.at] TRACE: < 204047125260617
> 0000123126 [ncp.at] TRACE: < OK
> 0000123326 [ncp.at] TRACE: > AT+CEER
> 0000123330 [ncp.at] TRACE: < +CEER: "No report available"
> 0000123330 [ncp.at] TRACE: < OK
> 0000123331 [ncp.at] TRACE: > AT+CREG?
> 0000123334 [ncp.at] TRACE: < +CREG: 2,3
> 0000123335 [ncp.at] TRACE: < OK
> 0000123335 [ncp.at] TRACE: > AT+CGREG?
> 0000123338 [ncp.at] TRACE: < +CGREG: 2,3
> 0000123339 [ncp.at] TRACE: < OK
> 0000123340 [ncp.at] TRACE: > AT+CSQ
> 0000123343 [ncp.at] TRACE: < +CSQ: 14,1
> 0000123343 [ncp.at] TRACE: < OK
> 0000138344 [ncp.at] TRACE: > AT+CEER
> 0000138348 [ncp.at] TRACE: < +CEER: "No report available"
> 0000138349 [ncp.at] TRACE: < OK
> 0000138349 [ncp.at] TRACE: > AT+CREG?
> 0000138352 [ncp.at] TRACE: < +CREG: 2,3
> 0000138353 [ncp.at] TRACE: < OK
> 0000138354 [ncp.at] TRACE: > AT+CGREG?
> 0000138357 [ncp.at] TRACE: < +CGREG: 2,3
> 0000138358 [ncp.at] TRACE: < OK
> 0000138359 [ncp.at] TRACE: > AT+CSQ
> 0000138362 [ncp.at] TRACE: < +CSQ: 14,2
> 0000138362 [ncp.at] TRACE: < OK
> 0000153363 [ncp.at] TRACE: > AT+CEER
> 0000153367 [ncp.at] TRACE: < +CEER: "No report available"
> 0000153367 [ncp.at] TRACE: < OK
> 0000153368 [ncp.at] TRACE: > AT+CREG?
> 0000153371 [ncp.at] TRACE: < +CREG: 2,3
> 0000153372 [ncp.at] TRACE: < OK
> 0000153373 [ncp.at] TRACE: > AT+CGREG?
> 0000153376 [ncp.at] TRACE: < +CGREG: 2,3
> 0000153376 [ncp.at] TRACE: < OK
> 0000153377 [ncp.at] TRACE: > AT+CSQ
> 0000153380 [ncp.at] TRACE: < +CSQ: 14,1
> 0000153381 [ncp.at] TRACE: < OK
> 0000165781 [ncp.client] TRACE: Sticky CSD and PSD denied state for 60 s, RF reset
> 0000165782 [ncp.at] TRACE: > AT+CFUN=0,0
> 0000165810 [ncp.at] TRACE: < OK
> 0000165811 [ncp.at] TRACE: > AT+CFUN=1,0
> 0000165812 [ncp.at] TRACE: < +CREG: 0
> 0000165813 [ncp.at] TRACE: < +CGREG: 0
> 0000165819 [ncp.at] TRACE: < OK
> 0000165919 [ncp.at] TRACE: < +CGEV: ME CLASS B
> 0000168419 [ncp.at] TRACE: > AT+CEER
> 0000168423 [ncp.at] TRACE: < +CEER: "No report available"
> 0000168423 [ncp.at] TRACE: < OK
> 0000168424 [ncp.at] TRACE: > AT+CREG?
> 0000168427 [ncp.at] TRACE: < +CREG: 2,0
> 0000168428 [ncp.at] TRACE: < OK
> 0000168429 [ncp.at] TRACE: > AT+CGREG?
> 0000168431 [ncp.at] TRACE: < +CGREG: 2,0
> 0000168432 [ncp.at] TRACE: < OK
> 0000168433 [ncp.at] TRACE: > AT+CSQ
> 0000168436 [ncp.at] TRACE: < +CSQ: 99,99
> 0000168436 [ncp.at] TRACE: < OK
> 0000169437 [ncp.at] TRACE: < +CGEV: NW CLASS CC
> 0000169437 [ncp.at] TRACE: < +CREG: 3
> 0000169538 [ncp.at] TRACE: < +CGREG: 3
> 0000183138 [ncp.at] TRACE: > AT+CIMI
> 0000183141 [ncp.at] TRACE: < 204047125260617
> 0000183142 [ncp.at] TRACE: < OK
> 0000183442 [ncp.at] TRACE: > AT+CEER
> 0000183445 [ncp.at] TRACE: < +CEER: "No report available"
> 0000183446 [ncp.at] TRACE: < OK
> 0000183447 [ncp.at] TRACE: > AT+CREG?
> 0000183450 [ncp.at] TRACE: < +CREG: 2,3
> 0000183450 [ncp.at] TRACE: < OK
> 0000183451 [ncp.at] TRACE: > AT+CGREG?
> 0000183454 [ncp.at] TRACE: < +CGREG: 2,3
> 0000183455 [ncp.at] TRACE: < OK
> 0000183456 [ncp.at] TRACE: > AT+CSQ
> 0000183459 [ncp.at] TRACE: < +CSQ: 15,2
> 0000183459 [ncp.at] TRACE: < OK
> 0000198460 [ncp.at] TRACE: > AT+CEER
> 0000198464 [ncp.at] TRACE: < +CEER: "No report available"
> 0000198464 [ncp.at] TRACE: < OK
> 0000198465 [ncp.at] TRACE: > AT+CREG?
> 0000198468 [ncp.at] TRACE: < +CREG: 2,3
> 0000198469 [ncp.at] TRACE: < OK
> 0000198469 [ncp.at] TRACE: > AT+CGREG?
> 0000198472 [ncp.at] TRACE: < +CGREG: 2,3
> 0000198473 [ncp.at] TRACE: < OK
> 0000198474 [ncp.at] TRACE: > AT+CSQ
> 0000198477 [ncp.at] TRACE: < +CSQ: 14,4
> 0000198478 [ncp.at] TRACE: < OK
> 0000213478 [ncp.at] TRACE: > AT+CEER
> 0000213482 [ncp.at] TRACE: < +CEER: "No report available"
> 0000213482 [ncp.at] TRACE: < OK
> 0000213483 [ncp.at] TRACE: > AT+CREG?
> 0000213486 [ncp.at] TRACE: < +CREG: 2,3
> 0000213487 [ncp.at] TRACE: < OK
> 0000213488 [ncp.at] TRACE: > AT+CGREG?
> 0000213490 [ncp.at] TRACE: < +CGREG: 2,3
> 0000213491 [ncp.at] TRACE: < OK
> 0000213492 [ncp.at] TRACE: > AT+CSQ
> 0000213495 [ncp.at] TRACE: < +CSQ: 14,2
> 0000213495 [ncp.at] TRACE: < OK
> 0000228496 [ncp.at] TRACE: > AT+CEER
> 0000228500 [ncp.at] TRACE: < +CEER: "No report available"
> 0000228500 [ncp.at] TRACE: < OK
> 0000228501 [ncp.at] TRACE: > AT+CREG?
> 0000228504 [ncp.at] TRACE: < +CREG: 2,3
> 0000228505 [ncp.at] TRACE: < OK
> 0000228505 [ncp.at] TRACE: > AT+CGREG?
> 0000228508 [ncp.at] TRACE: < +CGREG: 2,3
> 0000228509 [ncp.at] TRACE: < OK
> 0000228510 [ncp.at] TRACE: > AT+CSQ
> 0000228512 [ncp.at] TRACE: < +CSQ: 14,3
> 0000228513 [ncp.at] TRACE: < OK
> 0000243213 [ncp.at] TRACE: > AT+CIMI
> 0000243216 [ncp.at] TRACE: < 204047125260617
> 0000243217 [ncp.at] TRACE: < OK
> 0000243517 [ncp.at] TRACE: > AT+CEER
> 0000243520 [ncp.at] TRACE: < +CEER: "No report available"
> 0000243521 [ncp.at] TRACE: < OK
> 0000243521 [ncp.at] TRACE: > AT+CREG?
> 0000243524 [ncp.at] TRACE: < +CREG: 2,3
> 0000243525 [ncp.at] TRACE: < OK
> 0000243526 [ncp.at] TRACE: > AT+CGREG?
> 0000243528 [ncp.at] TRACE: < +CGREG: 2,3
> 0000243529 [ncp.at] TRACE: < OK
> 0000243530 [ncp.at] TRACE: > AT+CSQ
> 0000243533 [ncp.at] TRACE: < +CSQ: 14,2
> 0000243533 [ncp.at] TRACE: < OK
> 0000244534 [ncp.client] TRACE: Sticky CSD and PSD denied state for 75 s, RF reset
> 0000244535 [ncp.at] TRACE: > AT+CFUN=0,0
> 0000244560 [ncp.at] TRACE: < OK
> 0000244562 [ncp.at] TRACE: > AT+CFUN=1,0
> 0000244562 [ncp.at] TRACE: < +CREG: 0
> 0000244563 [ncp.at] TRACE: < +CGREG: 0
> 0000244568 [ncp.at] TRACE: < OK
> 0000244669 [ncp.at] TRACE: < +CGEV: ME CLASS B
> 0000248169 [ncp.at] TRACE: < +CGEV: NW CLASS CC
> 0000248169 [ncp.at] TRACE: < +CREG: 3
> 0000248270 [ncp.at] TRACE: < +CGREG: 3
> 0000258570 [ncp.at] TRACE: > AT+CEER
> 0000258574 [ncp.at] TRACE: < +CEER: "No report available"
> 0000258575 [ncp.at] TRACE: < OK
> 0000258575 [ncp.at] TRACE: > AT+CREG?
> 0000258579 [ncp.at] TRACE: < +CREG: 2,3
> 0000258579 [ncp.at] TRACE: < OK
> 0000258580 [ncp.at] TRACE: > AT+CGREG?
> 0000258583 [ncp.at] TRACE: < +CGREG: 2,3
> 0000258584 [ncp.at] TRACE: < OK
> 0000258585 [ncp.at] TRACE: > AT+CSQ
> 0000258588 [ncp.at] TRACE: < +CSQ: 23,2
> 0000258588 [ncp.at] TRACE: < OK
> 0000273589 [ncp.at] TRACE: > AT+CEER
> 0000273592 [ncp.at] TRACE: < +CEER: "No report available"
> 0000273593 [ncp.at] TRACE: < OK
> 0000273594 [ncp.at] TRACE: > AT+CREG?
> 0000273597 [ncp.at] TRACE: < +CREG: 2,3
> 0000273598 [ncp.at] TRACE: < OK
> 0000273599 [ncp.at] TRACE: > AT+CGREG?
> 0000273602 [ncp.at] TRACE: < +CGREG: 2,3
> 0000273602 [ncp.at] TRACE: < OK
> 0000273603 [ncp.at] TRACE: > AT+CSQ
> 0000273606 [ncp.at] TRACE: < +CSQ: 23,2
> 0000273607 [ncp.at] TRACE: < OK
> 0000288607 [ncp.at] TRACE: > AT+CEER
> 0000288611 [ncp.at] TRACE: < +CEER: "No report available"
> 0000288611 [ncp.at] TRACE: < OK
> 0000288612 [ncp.at] TRACE: > AT+CREG?
> 0000288615 [ncp.at] TRACE: < +CREG: 2,3
> 0000288616 [ncp.at] TRACE: < OK
> 0000288616 [ncp.at] TRACE: > AT+CGREG?
> 0000288620 [ncp.at] TRACE: < +CGREG: 2,3
> 0000288620 [ncp.at] TRACE: < OK
> 0000288621 [ncp.at] TRACE: > AT+CSQ
> 0000288624 [ncp.at] TRACE: < +CSQ: 15,4
> 0000288624 [ncp.at] TRACE: < OK
> 0000303225 [ncp.at] TRACE: > AT+CIMI
> 0000303228 [ncp.at] TRACE: < 204047125260617
> 0000303229 [ncp.at] TRACE: < OK
> 0000303629 [ncp.at] TRACE: > AT+CEER
> 0000303632 [ncp.at] TRACE: < +CEER: "No report available"
> 0000303633 [ncp.at] TRACE: < OK
> 0000303633 [ncp.at] TRACE: > AT+CREG?
> 0000303637 [ncp.at] TRACE: < +CREG: 2,3
> 0000303637 [ncp.at] TRACE: < OK
> 0000303638 [ncp.at] TRACE: > AT+CGREG?
> 0000303641 [ncp.at] TRACE: < +CGREG: 2,3
> 0000303641 [ncp.at] TRACE: < OK
> 0000303642 [ncp.at] TRACE: > AT+CSQ
> 0000303645 [ncp.at] TRACE: < +CSQ: 15,4
> 0000303645 [ncp.at] TRACE: < OK
> 0000318646 [ncp.at] TRACE: > AT+CEER
> 0000318649 [ncp.at] TRACE: < +CEER: "No report available"
> 0000318650 [ncp.at] TRACE: < OK
> 0000318651 [ncp.at] TRACE: > AT+CREG?
> 0000318653 [ncp.at] TRACE: < +CREG: 2,3
> 0000318654 [ncp.at] TRACE: < OK
> 0000318655 [ncp.at] TRACE: > AT+CGREG?
> 0000318658 [ncp.at] TRACE: < +CGREG: 2,3
> 0000318658 [ncp.at] TRACE: < OK
> 0000318659 [ncp.at] TRACE: > AT+CSQ
> 0000318662 [ncp.at] TRACE: < +CSQ: 15,4
> 0000318662 [ncp.at] TRACE: < OK
> 0000333663 [ncp.at] TRACE: > AT+CEER
> 0000333667 [ncp.at] TRACE: < +CEER: "No report available"
> 0000333667 [ncp.at] TRACE: < OK
> 0000333668 [ncp.at] TRACE: > AT+CREG?
> 0000333671 [ncp.at] TRACE: < +CREG: 2,3
> 0000333672 [ncp.at] TRACE: < OK
> 0000333672 [ncp.at] TRACE: > AT+CGREG?
> 0000333676 [ncp.at] TRACE: < +CGREG: 2,3
> 0000333676 [ncp.at] TRACE: < OK
> 0000333677 [ncp.at] TRACE: > AT+CSQ
> 0000333680 [ncp.at] TRACE: < +CSQ: 15,1
> 0000333680 [ncp.at] TRACE: < OK
> 0000338181 [ncp.client] TRACE: Sticky CSD and PSD denied state for 90 s, RF reset
> 0000338182 [ncp.at] TRACE: > AT+CFUN=0,0
> 0000338210 [ncp.at] TRACE: < OK
> 0000338212 [ncp.at] TRACE: > AT+CFUN=1,0
> 0000338212 [ncp.at] TRACE: < +CREG: 0
> 0000338213 [ncp.at] TRACE: < +CGREG: 0
> 0000338218 [ncp.at] TRACE: < OK
> 0000338319 [ncp.at] TRACE: < +CGEV: ME CLASS B
> 0000341519 [ncp.at] TRACE: < +CGEV: NW CLASS CC
> 0000341519 [ncp.at] TRACE: < +CREG: 3
> 0000341620 [ncp.at] TRACE: < +CGREG: 3
> 0000348720 [ncp.at] TRACE: > AT+CEER
> 0000348724 [ncp.at] TRACE: < +CEER: "No report available"
> 0000348724 [ncp.at] TRACE: < OK
> 0000348725 [ncp.at] TRACE: > AT+CREG?
> 0000348728 [ncp.at] TRACE: < +CREG: 2,3
> 0000348728 [ncp.at] TRACE: < OK
> 0000348729 [ncp.at] TRACE: > AT+CGREG?
> 0000348732 [ncp.at] TRACE: < +CGREG: 2,3
> 0000348733 [ncp.at] TRACE: < OK
> 0000348733 [ncp.at] TRACE: > AT+CSQ
> 0000348736 [ncp.at] TRACE: < +CSQ: 23,1
> 0000348737 [ncp.at] TRACE: < OK
> 0000363237 [ncp.at] TRACE: > AT+CIMI
> 0000363240 [ncp.at] TRACE: < 204047125260617
> 0000363241 [ncp.at] TRACE: < OK
> 0000363741 [ncp.at] TRACE: > AT+CEER
> 0000363745 [ncp.at] TRACE: < +CEER: "No report available"
> 0000363745 [ncp.at] TRACE: < OK
> 0000363746 [ncp.at] TRACE: > AT+CREG?
> 0000363749 [ncp.at] TRACE: < +CREG: 2,3
> 0000363750 [ncp.at] TRACE: < OK
> 0000363750 [ncp.at] TRACE: > AT+CGREG?
> 0000363753 [ncp.at] TRACE: < +CGREG: 2,3
> 0000363754 [ncp.at] TRACE: < OK
> 0000363755 [ncp.at] TRACE: > AT+CSQ
> 0000363758 [ncp.at] TRACE: < +CSQ: 13,2
> 0000363758 [ncp.at] TRACE: < OK
> 0000378759 [ncp.at] TRACE: > AT+CEER
> 0000378763 [ncp.at] TRACE: < +CEER: "No report available"
> 0000378763 [ncp.at] TRACE: < OK
> 0000378764 [ncp.at] TRACE: > AT+CREG?
> 0000378767 [ncp.at] TRACE: < +CREG: 2,3
> 0000378768 [ncp.at] TRACE: < OK
> 0000378769 [ncp.at] TRACE: > AT+CGREG?
> 0000378772 [ncp.at] TRACE: < +CGREG: 2,3
> 0000378772 [ncp.at] TRACE: < OK
> 0000378773 [ncp.at] TRACE: > AT+CSQ
> 0000378777 [ncp.at] TRACE: < +CSQ: 14,2
> 0000378777 [ncp.at] TRACE: < OK
> 0000393778 [ncp.at] TRACE: > AT+CEER
> 0000393782 [ncp.at] TRACE: < +CEER: "No report available"
> 0000393782 [ncp.at] TRACE: < OK
> 0000393783 [ncp.at] TRACE: > AT+CREG?
> 0000393786 [ncp.at] TRACE: < +CREG: 2,3
> 0000393787 [ncp.at] TRACE: < OK
> 0000393788 [ncp.at] TRACE: > AT+CGREG?
> 0000393791 [ncp.at] TRACE: < +CGREG: 2,3
> 0000393791 [ncp.at] TRACE: < OK
> 0000393792 [ncp.at] TRACE: > AT+CSQ
> 0000393795 [ncp.at] TRACE: < +CSQ: 13,2
> 0000393796 [ncp.at] TRACE: < OK
> 0000408796 [ncp.at] TRACE: > AT+CEER
> 0000408799 [ncp.at] TRACE: < +CEER: "No report available"
> 0000408800 [ncp.at] TRACE: < OK
> 0000408801 [ncp.at] TRACE: > AT+CREG?
> 0000408804 [ncp.at] TRACE: < +CREG: 2,3
> 0000408804 [ncp.at] TRACE: < OK
> 0000408805 [ncp.at] TRACE: > AT+CGREG?
> 0000408808 [ncp.at] TRACE: < +CGREG: 2,3
> 0000408809 [ncp.at] TRACE: < OK
> 0000408810 [ncp.at] TRACE: > AT+CSQ
> 0000408813 [ncp.at] TRACE: < +CSQ: 13,2
> 0000408813 [ncp.at] TRACE: < OK
> 0000423314 [ncp.at] TRACE: > AT+CIMI
> 0000423317 [ncp.at] TRACE: < 204047125260617
> 0000423318 [ncp.at] TRACE: < OK
> 0000423818 [ncp.at] TRACE: > AT+CEER
> 0000423821 [ncp.at] TRACE: < +CEER: "No report available"
> 0000423822 [ncp.at] TRACE: < OK
> 0000423823 [ncp.at] TRACE: > AT+CREG?
> 0000423825 [ncp.at] TRACE: < +CREG: 2,3
> 0000423826 [ncp.at] TRACE: < OK
> 0000423827 [ncp.at] TRACE: > AT+CGREG?
> 0000423829 [ncp.at] TRACE: < +CGREG: 2,3
> 0000423830 [ncp.at] TRACE: < OK
> 0000423831 [ncp.at] TRACE: > AT+CSQ
> 0000423834 [ncp.at] TRACE: < +CSQ: 15,1
> 0000423834 [ncp.at] TRACE: < OK
> 0000438835 [ncp.at] TRACE: > AT+CEER
> 0000438838 [ncp.at] TRACE: < +CEER: "No report available"
> 0000438839 [ncp.at] TRACE: < OK
> 0000438840 [ncp.at] TRACE: > AT+CREG?
> 0000438842 [ncp.at] TRACE: < +CREG: 2,3
> 0000438843 [ncp.at] TRACE: < OK
> 0000438844 [ncp.at] TRACE: > AT+CGREG?
> 0000438847 [ncp.at] TRACE: < +CGREG: 2,3
> 0000438848 [ncp.at] TRACE: < OK
> 0000438848 [ncp.at] TRACE: > AT+CSQ
> 0000438851 [ncp.at] TRACE: < +CSQ: 15,1
> 0000438852 [ncp.at] TRACE: < OK
> 0000446552 [ncp.client] TRACE: Sticky CSD and PSD denied state for 105 s, RF reset
> 0000446553 [ncp.at] TRACE: > AT+CFUN=0,0
> 0000446580 [ncp.at] TRACE: < OK
> 0000446581 [ncp.at] TRACE: > AT+CFUN=1,0
> 0000446582 [ncp.at] TRACE: < +CREG: 0
> 0000446583 [ncp.at] TRACE: < +CGREG: 0
> 0000446588 [ncp.at] TRACE: < OK
> 0000446689 [ncp.at] TRACE: < +CGEV: ME CLASS B
> 0000449689 [ncp.at] TRACE: < +CGEV: NW CLASS CC
> 0000449689 [ncp.at] TRACE: < +CREG: 3
> 0000449790 [ncp.at] TRACE: < +CGREG: 3
> 0000453890 [ncp.at] TRACE: > AT+CEER
> 0000453893 [ncp.at] TRACE: < +CEER: "No report available"
> 0000453894 [ncp.at] TRACE: < OK
> 0000453895 [ncp.at] TRACE: > AT+CREG?
> 0000453898 [ncp.at] TRACE: < +CREG: 2,3
> 0000453898 [ncp.at] TRACE: < OK
> 0000453899 [ncp.at] TRACE: > AT+CGREG?
> 0000453902 [ncp.at] TRACE: < +CGREG: 2,3
> 0000453903 [ncp.at] TRACE: < OK
> 0000453903 [ncp.at] TRACE: > AT+CSQ
> 0000453907 [ncp.at] TRACE: < +CSQ: 23,2
> 0000453907 [ncp.at] TRACE: < OK
> 0000468908 [ncp.at] TRACE: > AT+CEER
> 0000468911 [ncp.at] TRACE: < +CEER: "No report available"
> 0000468912 [ncp.at] TRACE: < OK
> 0000468913 [ncp.at] TRACE: > AT+CREG?
> 0000468916 [ncp.at] TRACE: < +CREG: 2,3
> 0000468917 [ncp.at] TRACE: < OK
> 0000468917 [ncp.at] TRACE: > AT+CGREG?
> 0000468920 [ncp.at] TRACE: < +CGREG: 2,3
> 0000468921 [ncp.at] TRACE: < OK
> 0000468922 [ncp.at] TRACE: > AT+CSQ
> 0000468925 [ncp.at] TRACE: < +CSQ: 15,1
> 0000468925 [ncp.at] TRACE: < OK
> 0000483325 [ncp.at] TRACE: > AT+CIMI
> 0000483328 [ncp.at] TRACE: < 204047125260617
> 0000483329 [ncp.at] TRACE: < OK
> 0000483929 [ncp.at] TRACE: > AT+CEER
> 0000483932 [ncp.at] TRACE: < +CEER: "No report available"
> 0000483933 [ncp.at] TRACE: < OK
> 0000483934 [ncp.at] TRACE: > AT+CREG?
> 0000483937 [ncp.at] TRACE: < +CREG: 2,3
> 0000483938 [ncp.at] TRACE: < OK
> 0000483938 [ncp.at] TRACE: > AT+CGREG?
> 0000483941 [ncp.at] TRACE: < +CGREG: 2,3
> 0000483942 [ncp.at] TRACE: < OK
> 0000483943 [ncp.at] TRACE: > AT+CSQ
> 0000483945 [ncp.at] TRACE: < +CSQ: 15,1
> 0000483946 [ncp.at] TRACE: < OK
> 0000498946 [ncp.at] TRACE: > AT+CEER
> 0000498949 [ncp.at] TRACE: < +CEER: "No report available"
> 0000498950 [ncp.at] TRACE: < OK
> 0000498951 [ncp.at] TRACE: > AT+CREG?
> 0000498953 [ncp.at] TRACE: < +CREG: 2,3
> 0000498954 [ncp.at] TRACE: < OK
> 0000498955 [ncp.at] TRACE: > AT+CGREG?
> 0000498957 [ncp.at] TRACE: < +CGREG: 2,3
> 0000498958 [ncp.at] TRACE: < OK
> 0000498959 [ncp.at] TRACE: > AT+CSQ
> 0000498962 [ncp.at] TRACE: < +CSQ: 14,4
> 0000498962 [ncp.at] TRACE: < OK
> 0000513963 [ncp.at] TRACE: > AT+CEER
> 0000513967 [ncp.at] TRACE: < +CEER: "No report available"
> 0000513967 [ncp.at] TRACE: < OK
> 0000513968 [ncp.at] TRACE: > AT+CREG?
> 0000513971 [ncp.at] TRACE: < +CREG: 2,3
> 0000513972 [ncp.at] TRACE: < OK
> 0000513973 [ncp.at] TRACE: > AT+CGREG?
> 0000513976 [ncp.at] TRACE: < +CGREG: 2,3
> 0000513976 [ncp.at] TRACE: < OK
> 0000513977 [ncp.at] TRACE: > AT+CSQ
> 0000513980 [ncp.at] TRACE: < +CSQ: 14,1
> 0000513980 [ncp.at] TRACE: < OK
> 0000528981 [ncp.at] TRACE: > AT+CEER
> 0000528985 [ncp.at] TRACE: < +CEER: "No report available"
> 0000528985 [ncp.at] TRACE: < OK
> 0000528986 [ncp.at] TRACE: > AT+CREG?
> 0000528989 [ncp.at] TRACE: < +CREG: 2,3
> 0000528990 [ncp.at] TRACE: < OK
> 0000528990 [ncp.at] TRACE: > AT+CGREG?
> 0000528994 [ncp.at] TRACE: < +CGREG: 2,3
> 0000528994 [ncp.at] TRACE: < OK
> 0000528995 [ncp.at] TRACE: > AT+CSQ
> 0000528998 [ncp.at] TRACE: < +CSQ: 15,1
> 0000528999 [ncp.at] TRACE: < OK
> 0000543399 [ncp.at] TRACE: > AT+CIMI
> 0000543402 [ncp.at] TRACE: < 204047125260617
> 0000543403 [ncp.at] TRACE: < OK
> 0000544003 [ncp.at] TRACE: > AT+CEER
> 0000544007 [ncp.at] TRACE: < +CEER: "No report available"
> 0000544007 [ncp.at] TRACE: < OK
> 0000544008 [ncp.at] TRACE: > AT+CREG?
> 0000544011 [ncp.at] TRACE: < +CREG: 2,3
> 0000544012 [ncp.at] TRACE: < OK
> 0000544013 [ncp.at] TRACE: > AT+CGREG?
> 0000544016 [ncp.at] TRACE: < +CGREG: 2,3
> 0000544017 [ncp.at] TRACE: < OK
> 0000544017 [ncp.at] TRACE: > AT+CSQ
> 0000544020 [ncp.at] TRACE: < +CSQ: 15,1
> 0000544021 [ncp.at] TRACE: < OK
I would appreciate any suggestion about what else to check or how to proceed.
There is a problem with the state of your SIM card on the Particle side. It's being investigated.
Hi @pegator!
Your internal SIM was moved to a pre-scrap state as it was an old SIM never been activated. Don't worry, we already moved it to the usual pre-register state. You should be able to activate it now.
Please keep me posted!
Perfect, now is working.
I have had to manually import SIM card into SIMs page, and wait few minutes till SIM appears as active, then it started working.
Thx.
