Boron 310 cant connect to network (stuck on green blinking LED)
Have tried everything ios app, particle cli, setup.particle.io and gets stuck at the same place when trying to connect to the network using internal sim.
I am in a remote location in the Cook Islands so it could be that, but we do have vodafone coverage. But im hoping its something like this guys issue where the sim was in a pre-scrap state due to not being activated. This boron has been unopened in a box for a couple of years. So im hoping someone from the Particle team can fix?
Device Doctor log below:
Device ID: e00fce681cca899f53115354
ICCID: 89314404000573211753
IMEI: 358887094312145
IMSI: 204047105351942
Modem Manufacturer: u-blox
Modem Model: SARA-U201
Modem Firmware Version: 23.60
Modem Application Version: 23.60,A01.01
Power Supply: USB Host
Battery: Charging
Battery SoC: 94.2266
Country:
Carrier:
Access Technology:
Band:
Cellular Global Identity:
0000000316 [system.nm] TRACE: Request to power on the interface
0000000316 [ncp.client] TRACE: Powering modem on, ncpId: 0x42
0000000317 [ncp.client] TRACE: Modem already on
0000000317 [ncp.client] TRACE: Setting UART voltage translator state 1
0000000319 [system.nm] INFO: State changed: DISABLED -> IFACE_DOWN
0000000418 [ncp.client] TRACE: Setting UART voltage translator state 0
0000000518 [ncp.client] TRACE: Setting UART voltage translator state 1
0000000518 [ncp.client] TRACE: Muxer is not currently running
0000000520 [ncp.client] TRACE: Initialized muxer @ 921600 baudrate
0000000520 [mux] INFO: Starting GSM07.10 muxer
0000000521 [mux] INFO: GSM07.10 muxer thread started
0000000523 [ncp.client] TRACE: Resumed muxed session
0000000524 [mux] INFO: Openning mux channel 1
0000000873 [mux] INFO: Closing mux channel 2
0000001224 [ncp.at] TRACE: > AT
0000001227 [ncp.at] TRACE: < A
0000001227 [ncp.at] TRACE: < ABORTED
0000002224 [ncp.at] TRACE: > AT
0000002226 [ncp.at] TRACE: < OK
0000002227 [ncp.client] TRACE: NCP ready to accept AT commands
0000002228 [ncp.at] TRACE: > AT
0000002230 [ncp.at] TRACE: < OK
0000002230 [ncp.at] TRACE: > ATI9
0000002244 [ncp.at] TRACE: < 23.60,A01.01
0000002244 [ncp.at] TRACE: < OK
0000002245 [ncp.client] TRACE: App firmware: 101
0000002246 [ncp.at] TRACE: > AT+UGPIOC?
0000002249 [ncp.at] TRACE: < +UGPIOC:
0000002250 [ncp.at] TRACE: < 16,255
0000002251 [ncp.at] TRACE: < 23,255
0000002251 [ncp.at] TRACE: < 24,4
0000002252 [ncp.at] TRACE: < 25,5
0000002252 [ncp.at] TRACE: < 34,12
0000002253 [ncp.at] TRACE: < 35,12
0000002253 [ncp.at] TRACE: < 36,12
0000002254 [ncp.at] TRACE: < 37,12
0000002254 [ncp.at] TRACE: < 42,7
0000002255 [ncp.at] TRACE: < OK
0000002255 [ncp.client] INFO: Using internal SIM card
0000002257 [ncp.at] TRACE: > AT+CPIN?
0000002259 [ncp.at] TRACE: < +CPIN: READY
0000002260 [ncp.at] TRACE: < OK
0000002261 [ncp.at] TRACE: > AT+CCID
0000002278 [ncp.at] TRACE: < +CCID: 89314404000573211753
0000002279 [ncp.at] TRACE: < OK
0000002280 [ncp.at] TRACE: > AT+IFC?
0000002282 [ncp.at] TRACE: < +IFC: 2,2
0000002283 [ncp.at] TRACE: < OK
0000002284 [ncp.at] TRACE: > AT+IFC=2,2
0000002286 [ncp.at] TRACE: < OK
0000002287 [ncp.at] TRACE: > AT
0000002289 [ncp.at] TRACE: < OK
0000002290 [ncp.at] TRACE: > AT+COPS=3,2
0000002293 [ncp.at] TRACE: < OK
0000002294 [ncp.at] TRACE: > AT+CGEREP=1,0
0000002297 [ncp.at] TRACE: < OK
0000002297 [ncp.at] TRACE: > AT+UPSV=0
0000002300 [ncp.at] TRACE: < OK
0000002300 [mux] INFO: Mux channel 1 already opened
0000002301 [ncp.at] TRACE: > AT
0000002303 [ncp.at] TRACE: < OK
0000002304 [ncp.client] TRACE: NCP state changed: 1
0000002304 [net.pppncp] TRACE: NCP event 1
0000002307 [app] INFO: cellular is on
0000002308 [ncp.at] TRACE: > AT+CCID
0000002326 [ncp.at] TRACE: < +CCID: 89314404000573211753
0000002327 [ncp.at] TRACE: < OK
0000002329 [ncp.at] TRACE: > AT+CGMI
0000002333 [ncp.at] TRACE: < u-blox
0000002333 [ncp.at] TRACE: < OK
0000002335 [ncp.at] TRACE: > AT+CGMM
0000002338 [ncp.at] TRACE: < SARA-U201
0000002339 [ncp.at] TRACE: < OK
0000002341 [ncp.at] TRACE: > AT+CGMR
0000002344 [ncp.at] TRACE: < 23.60
0000002345 [ncp.at] TRACE: < OK
0000002347 [ncp.at] TRACE: > AT+CGSN
0000002362 [ncp.at] TRACE: < 358887094312145
0000002362 [ncp.at] TRACE: < OK
0000005294 [app] INFO: Auto-connect disabled
0000005737 [ncp.at] TRACE: > AT+CFUN?
0000005740 [ncp.at] TRACE: < +CFUN: 1,0
0000005741 [ncp.at] TRACE: < OK
0000005743 [ncp.at] TRACE: > AT+CCID
0000005760 [ncp.at] TRACE: < +CCID: 89314404000573211753
0000005761 [ncp.at] TRACE: < OK
0000005762 [ncp.at] TRACE: > AT+CGSN
0000005775 [ncp.at] TRACE: < 358887094312145
0000005776 [ncp.at] TRACE: < OK
0000005777 [ncp.at] TRACE: > ATI9
0000005788 [ncp.at] TRACE: < 23.60,A01.01
0000005789 [ncp.at] TRACE: < OK
0000006590 [system.nm] INFO: State changed: IFACE_DOWN -> IFACE_REQUEST_UP
0000006593 [net.ppp.client] TRACE: PPP thread event ADM_UP data=0
0000006593 [net.ppp.client] TRACE: State NONE -> READY
0000006596 [ncp.at] TRACE: > AT+CFUN?
0000006597 [system.nm] INFO: State changed: IFACE_REQUEST_UP -> IFACE_UP
0000006599 [ncp.at] TRACE: < +CFUN: 1,0
0000006600 [ncp.at] TRACE: < OK
0000006601 [ncp.at] TRACE: > AT+CCID
0000006618 [ncp.at] TRACE: < +CCID: 89314404000573211753
0000006619 [ncp.at] TRACE: < OK
0000006620 [ncp.at] TRACE: > AT+CIMI
0000006623 [ncp.at] TRACE: < 204047105351942
0000006623 [ncp.at] TRACE: < OK
0000006624 [ncp.at] TRACE: > AT+CGDCONT?
0000006628 [ncp.at] TRACE: < +CGDCONT: 1,"IP","vfd1.korem2m.com","0.0.0.0",0,0
0000006629 [ncp.at] TRACE: < OK
0000006630 [ncp.at] TRACE: > AT+CFUN?
0000006633 [ncp.at] TRACE: < +CFUN: 1,0
0000006633 [ncp.at] TRACE: < OK
0000006634 [ncp.at] TRACE: > AT+CREG=2
0000006637 [ncp.at] TRACE: < OK
0000006638 [ncp.at] TRACE: > AT+CGREG=2
0000006640 [ncp.at] TRACE: < OK
0000006641 [ncp.client] TRACE: NCP connection state changed: 1
0000006641 [net.pppncp] TRACE: NCP event 2
0000006642 [net.pppncp] TRACE: State changed event: 1
0000006643 [ncp.at] TRACE: > AT+COPS?
0000006643 [net.ppp.client] TRACE: PPP thread event LOWER_DOWN data=0
0000006646 [ncp.at] TRACE: < +COPS: 0
0000006646 [ncp.at] TRACE: < OK
0000006647 [ncp.at] TRACE: > AT+CREG?
0000006651 [ncp.at] TRACE: < +CREG: 2,0
0000006651 [ncp.at] TRACE: < OK
0000006652 [ncp.at] TRACE: > AT+CGREG?
0000006655 [ncp.at] TRACE: < +CGREG: 2,0
0000006656 [ncp.at] TRACE: < OK
0000021656 [ncp.at] TRACE: > AT+CEER
0000021660 [ncp.at] TRACE: < +CEER: "No report available"
0000021661 [ncp.at] TRACE: < OK
0000021662 [ncp.at] TRACE: > AT+CREG?
0000021665 [ncp.at] TRACE: < +CREG: 2,0
0000021665 [ncp.at] TRACE: < OK
0000021666 [ncp.at] TRACE: > AT+CGREG?
0000021670 [ncp.at] TRACE: < +CGREG: 2,0
0000021670 [ncp.at] TRACE: < OK
0000021671 [ncp.at] TRACE: > AT+CSQ
0000021674 [ncp.at] TRACE: < +CSQ: 99,99
0000021675 [ncp.at] TRACE: < OK
0000021775 [ncp.client] TRACE: Sticky not registering CSD state for 15 s, PLMN reselection
0000021776 [ncp.at] TRACE: > AT+COPS=0,2
0000149937 [ncp.at] TRACE: < ERROR
0000149938 [ncp.at] TRACE: > AT+CIMI
0000149939 [ncp.at] TRACE: < +CREG: 4
0000149940 [ncp.at] TRACE: < +CGREG: 4
0000149941 [ncp.at] TRACE: < +CGEV: NW CLASS A
0000149942 [ncp.at] TRACE: < +CREG: 2
0000149943 [ncp.at] TRACE: < +CGREG: 2
0000149943 [ncp.at] TRACE: < +CREG: 3
0000149944 [ncp.at] TRACE: < +CGREG: 3
0000149944 [ncp.at] TRACE: < 204047105351942
0000149945 [ncp.at] TRACE: < OK
0000149946 [ncp.at] TRACE: > AT+CEER
0000149949 [ncp.at] TRACE: < +CEER: "No report available"
0000149950 [ncp.at] TRACE: < OK
0000149951 [ncp.at] TRACE: > AT+CREG?
0000149954 [ncp.at] TRACE: < +CREG: 2,3
0000149954 [ncp.at] TRACE: < OK
0000149955 [ncp.at] TRACE: > AT+CGREG?
0000149958 [ncp.at] TRACE: < +CGREG: 2,3
0000149959 [ncp.at] TRACE: < OK
0000149960 [ncp.at] TRACE: > AT+CSQ
0000149963 [ncp.at] TRACE: < +CSQ: 26,1
0000149963 [ncp.at] TRACE: < OK
0000165063 [ncp.at] TRACE: > AT+CEER
0000165067 [ncp.at] TRACE: < +CEER: "No report available"
0000165068 [ncp.at] TRACE: < OK
0000165068 [ncp.at] TRACE: > AT+CREG?
0000165071 [ncp.at] TRACE: < +CREG: 2,3
0000165072 [ncp.at] TRACE: < OK
0000165073 [ncp.at] TRACE: > AT+CGREG?
0000165076 [ncp.at] TRACE: < +CGREG: 2,3
0000165076 [ncp.at] TRACE: < OK
0000165077 [ncp.at] TRACE: > AT+CSQ
0000165080 [ncp.at] TRACE: < +CSQ: 25,0
0000165081 [ncp.at] TRACE: < OK
0000179981 [ncp.client] TRACE: Sticky CSD and PSD denied state for 30 s, RF reset
0000179982 [ncp.at] TRACE: > AT+CFUN=0,0
0000179987 [ncp.at] TRACE: < ERROR
0000180087 [ncp.at] TRACE: < +CREG: 0
0000180088 [ncp.at] TRACE: > AT+CEER
0000180088 [ncp.at] TRACE: < +CGREG: 0
0000180089 [ncp.at] TRACE: < OK
0000180091 [ncp.at] TRACE: < +CEER: "No report available"
0000180092 [ncp.at] TRACE: < OK
0000180093 [ncp.at] TRACE: > AT+CREG?
0000180096 [ncp.at] TRACE: < +CREG: 2,0
0000180097 [ncp.at] TRACE: < OK
0000180098 [ncp.at] TRACE: > AT+CGREG?
0000180101 [ncp.at] TRACE: < +CGREG: 2,0
0000180101 [ncp.at] TRACE: < OK
0000180102 [ncp.at] TRACE: > AT+CSQ
0000180105 [ncp.at] TRACE: < +CSQ: 99,99
0000180106 [ncp.at] TRACE: < OK
0000195106 [ncp.at] TRACE: > AT+CEER
0000195110 [ncp.at] TRACE: < +CEER: "No report available"
0000195110 [ncp.at] TRACE: < OK
0000195111 [ncp.at] TRACE: > AT+CREG?
0000195115 [ncp.at] TRACE: < +CREG: 2,0
0000195115 [ncp.at] TRACE: < OK
0000195116 [ncp.at] TRACE: > AT+CGREG?
0000195119 [ncp.at] TRACE: < +CGREG: 2,0
0000195120 [ncp.at] TRACE: < OK
0000195121 [ncp.at] TRACE: > AT+CSQ
0000195124 [ncp.at] TRACE: < +CSQ: 99,99
0000195124 [ncp.at] TRACE: < OK
0000210024 [ncp.at] TRACE: > AT+CIMI
0000210027 [ncp.at] TRACE: < 204047105351942
0000210028 [ncp.at] TRACE: < OK
0000210128 [ncp.at] TRACE: > AT+CEER
0000210131 [ncp.at] TRACE: < +CEER: "No report available"
0000210132 [ncp.at] TRACE: < OK
0000210133 [ncp.at] TRACE: > AT+CREG?
0000210136 [ncp.at] TRACE: < +CREG: 2,0
0000210136 [ncp.at] TRACE: < OK
0000210137 [ncp.at] TRACE: > AT+CGREG?
0000210140 [ncp.at] TRACE: < +CGREG: 2,0
0000210140 [ncp.at] TRACE: < OK
0000210141 [ncp.at] TRACE: > AT+CSQ
0000210144 [ncp.at] TRACE: < +CSQ: 99,99
0000210144 [ncp.at] TRACE: < OK
0000225144 [ncp.client] TRACE: Sticky not registering CSD state for 45 s, PLMN reselection
0000225145 [ncp.at] TRACE: > AT+COPS=0,2
0000225148 [ncp.at] TRACE: < ERROR
0000225149 [ncp.at] TRACE: > AT+CEER
0000225153 [ncp.at] TRACE: < +CEER: "No report available"
0000225153 [ncp.at] TRACE: < OK
0000225154 [ncp.at] TRACE: > AT+CREG?
0000225157 [ncp.at] TRACE: < +CREG: 2,0
0000225157 [ncp.at] TRACE: < OK
0000225158 [ncp.at] TRACE: > AT+CGREG?
0000225161 [ncp.at] TRACE: < +CGREG: 2,0
0000225162 [ncp.at] TRACE: < OK
0000225163 [ncp.at] TRACE: > AT+CSQ
0000225165 [ncp.at] TRACE: < +CSQ: 99,99
0000225166 [ncp.at] TRACE: < OK
0000240166 [ncp.at] TRACE: > AT+CEER
0000240170 [ncp.at] TRACE: < +CEER: "No report available"
0000240171 [ncp.at] TRACE: < OK
0000240172 [ncp.at] TRACE: > AT+CREG?
0000240175 [ncp.at] TRACE: < +CREG: 2,0
0000240175 [ncp.at] TRACE: < OK
0000240176 [ncp.at] TRACE: > AT+CGREG?
0000240179 [ncp.at] TRACE: < +CGREG: 2,0
0000240180 [ncp.at] TRACE: < OK
0000240181 [ncp.at] TRACE: > AT+CSQ
0000240184 [ncp.at] TRACE: < +CSQ: 99,99
0000240184 [ncp.at] TRACE: < OK
0000255284 [ncp.at] TRACE: > AT+CEER
0000255288 [ncp.at] TRACE: < +CEER: "No report available"
0000255288 [ncp.at] TRACE: < OK
0000255289 [ncp.at] TRACE: > AT+CREG?
0000255292 [ncp.at] TRACE: < +CREG: 2,0
0000255292 [ncp.at] TRACE: < OK
0000255293 [ncp.at] TRACE: > AT+CGREG?
0000255296 [ncp.at] TRACE: < +CGREG: 2,0
0000255296 [ncp.at] TRACE: < OK
0000255297 [ncp.at] TRACE: > AT+CSQ
0000255300 [ncp.at] TRACE: < +CSQ: 99,99
0000255300 [ncp.at] TRACE: < OK
0000270101 [ncp.at] TRACE: > AT+CIMI
0000270105 [ncp.at] TRACE: < 204047105351942
0000270105 [ncp.at] TRACE: < OK
0000270305 [ncp.at] TRACE: > AT+CEER
0000270309 [ncp.at] TRACE: < +CEER: "No report available"
0000270309 [ncp.at] TRACE: < OK
0000270310 [ncp.at] TRACE: > AT+CREG?
0000270313 [ncp.at] TRACE: < +CREG: 2,0
0000270313 [ncp.at] TRACE: < OK
0000270314 [ncp.at] TRACE: > AT+CGREG?
0000270318 [ncp.at] TRACE: < +CGREG: 2,0
0000270318 [ncp.at] TRACE: < OK
0000270319 [ncp.at] TRACE: > AT+CSQ
0000270322 [ncp.at] TRACE: < +CSQ: 99,99
0000270323 [ncp.at] TRACE: < OK
0000285223 [ncp.client] TRACE: Sticky not registering CSD state for 60 s, PLMN reselection
0000285224 [ncp.at] TRACE: > AT+COPS=0,2
0000285227 [ncp.at] TRACE: < ERROR
0000285327 [ncp.at] TRACE: > AT+CEER
0000285331 [ncp.at] TRACE: < +CEER: "No report available"
0000285331 [ncp.at] TRACE: < OK
0000285332 [ncp.at] TRACE: > AT+CREG?
0000285335 [ncp.at] TRACE: < +CREG: 2,0
0000285336 [ncp.at] TRACE: < OK
0000285337 [ncp.at] TRACE: > AT+CGREG?
0000285340 [ncp.at] TRACE: < +CGREG: 2,0
0000285340 [ncp.at] TRACE: < OK
0000285341 [ncp.at] TRACE: > AT+CSQ
0000285344 [ncp.at] TRACE: < +CSQ: 99,99
0000285345 [ncp.at] TRACE: < OK
0000300345 [ncp.at] TRACE: > AT+CEER
0000300349 [ncp.at] TRACE: < +CEER: "No report available"
0000300349 [ncp.at] TRACE: < OK
0000300350 [ncp.at] TRACE: > AT+CREG?
0000300354 [ncp.at] TRACE: < +CREG: 2,0
0000300354 [ncp.at] TRACE: < OK
0000300355 [ncp.at] TRACE: > AT+CGREG?
0000300358 [ncp.at] TRACE: < +CGREG: 2,0
0000300359 [ncp.at] TRACE: < OK
0000300360 [ncp.at] TRACE: > AT+CSQ
0000300362 [ncp.at] TRACE: < +CSQ: 99,99
0000300363 [ncp.at] TRACE: < OK
0000315364 [ncp.at] TRACE: > AT+CEER
0000315368 [ncp.at] TRACE: < +CEER: "No report available"
0000315368 [ncp.at] TRACE: < OK
0000315369 [ncp.at] TRACE: > AT+CREG?
0000315372 [ncp.at] TRACE: < +CREG: 2,0
0000315373 [ncp.at] TRACE: < OK
0000315374 [ncp.at] TRACE: > AT+CGREG?
0000315377 [ncp.at] TRACE: < +CGREG: 2,0
0000315377 [ncp.at] TRACE: < OK
0000315378 [ncp.at] TRACE: > AT+CSQ
0000315381 [ncp.at] TRACE: < +CSQ: 99,99
0000315382 [ncp.at] TRACE: < OK
0000330182 [ncp.at] TRACE: > AT+CIMI
0000330185 [ncp.at] TRACE: < 204047105351942
0000330186 [ncp.at] TRACE: < OK
0000330386 [ncp.at] TRACE: > AT+CEER
0000330389 [ncp.at] TRACE: < +CEER: "No report available"
0000330390 [ncp.at] TRACE: < OK
0000330391 [ncp.at] TRACE: > AT+CREG?
0000330393 [ncp.at] TRACE: < +CREG: 2,0
0000330394 [ncp.at] TRACE: < OK
0000330395 [ncp.at] TRACE: > AT+CGREG?
0000330398 [ncp.at] TRACE: < +CGREG: 2,0
0000330398 [ncp.at] TRACE: < OK
0000330399 [ncp.at] TRACE: > AT+CSQ
0000330402 [ncp.at] TRACE: < +CSQ: 99,99
0000330403 [ncp.at] TRACE: < OK
0000345403 [ncp.at] TRACE: > AT+CEER
0000345406 [ncp.at] TRACE: < +CEER: "No report available"
0000345407 [ncp.at] TRACE: < OK
0000345408 [ncp.at] TRACE: > AT+CREG?
0000345411 [ncp.at] TRACE: < +CREG: 2,0
0000345411 [ncp.at] TRACE: < OK
0000345412 [ncp.at] TRACE: > AT+CGREG?
0000345415 [ncp.at] TRACE: < +CGREG: 2,0
0000345415 [ncp.at] TRACE: < OK
0000345416 [ncp.at] TRACE: > AT+CSQ
0000345419 [ncp.at] TRACE: < +CSQ: 99,99
0000345420 [ncp.at] TRACE: < OK
0000360420 [ncp.client] TRACE: Sticky not registering CSD state for 75 s, PLMN reselection
0000360421 [ncp.at] TRACE: > AT+COPS=0,2
0000360424 [ncp.at] TRACE: < ERROR
0000360425 [ncp.at] TRACE: > AT+CEER
0000360428 [ncp.at] TRACE: < +CEER: "No report available"
0000360429 [ncp.at] TRACE: < OK
0000360430 [ncp.at] TRACE: > AT+CREG?
0000360432 [ncp.at] TRACE: < +CREG: 2,0
0000360433 [ncp.at] TRACE: < OK
0000360434 [ncp.at] TRACE: > AT+CGREG?
0000360437 [ncp.at] TRACE: < +CGREG: 2,0
0000360437 [ncp.at] TRACE: < OK
0000360438 [ncp.at] TRACE: > AT+CSQ
0000360441 [ncp.at] TRACE: < +CSQ: 99,99
0000360442 [ncp.at] TRACE: < OK
0000375442 [ncp.at] TRACE: > AT+CEER
0000375446 [ncp.at] TRACE: < +CEER: "No report available"
0000375446 [ncp.at] TRACE: < OK
0000375447 [ncp.at] TRACE: > AT+CREG?
0000375450 [ncp.at] TRACE: < +CREG: 2,0
0000375451 [ncp.at] TRACE: < OK
0000375452 [ncp.at] TRACE: > AT+CGREG?
0000375455 [ncp.at] TRACE: < +CGREG: 2,0
0000375455 [ncp.at] TRACE: < OK
0000375456 [ncp.at] TRACE: > AT+CSQ
0000375459 [ncp.at] TRACE: < +CSQ: 99,99
0000375460 [ncp.at] TRACE: < OK
0000390260 [ncp.at] TRACE: > AT+CIMI
0000390263 [ncp.at] TRACE: < 204047105351942
0000390264 [ncp.at] TRACE: < OK
0000390464 [ncp.at] TRACE: > AT+CEER
0000390471 [ncp.at] TRACE: < +CEER: "No report available"
0000390472 [ncp.at] TRACE: < OK
0000390473 [ncp.at] TRACE: > AT+CREG?
0000390476 [ncp.at] TRACE: < +CREG: 2,0
0000390476 [ncp.at] TRACE: < OK
0000390477 [ncp.at] TRACE: > AT+CGREG?
0000390480 [ncp.at] TRACE: < +CGREG: 2,0
0000390480 [ncp.at] TRACE: < OK
0000390481 [ncp.at] TRACE: > AT+CSQ
0000390484 [ncp.at] TRACE: < +CSQ: 99,99
0000390484 [ncp.at] TRACE: < OK
0000405485 [ncp.at] TRACE: > AT+CEER
0000405488 [ncp.at] TRACE: < +CEER: "No report available"
0000405489 [ncp.at] TRACE: < OK
0000405490 [ncp.at] TRACE: > AT+CREG?
0000405493 [ncp.at] TRACE: < +CREG: 2,0
0000405493 [ncp.at] TRACE: < OK
0000405494 [ncp.at] TRACE: > AT+CGREG?
0000405497 [ncp.at] TRACE: < +CGREG: 2,0
0000405497 [ncp.at] TRACE: < OK
0000405498 [ncp.at] TRACE: > AT+CSQ
0000405501 [ncp.at] TRACE: < +CSQ: 99,99
0000405502 [ncp.at] TRACE: < OK
0000420502 [ncp.at] TRACE: > AT+CEER
0000420506 [ncp.at] TRACE: < +CEER: "No report available"
0000420506 [ncp.at] TRACE: < OK
0000420507 [ncp.at] TRACE: > AT+CREG?
0000420510 [ncp.at] TRACE: < +CREG: 2,0
0000420511 [ncp.at] TRACE: < OK
0000420512 [ncp.at] TRACE: > AT+CGREG?
0000420515 [ncp.at] TRACE: < +CGREG: 2,0
0000420515 [ncp.at] TRACE: < OK
0000420516 [ncp.at] TRACE: > AT+CSQ
0000420519 [ncp.at] TRACE: < +CSQ: 99,99
0000420520 [ncp.at] TRACE: < OK
0000435520 [ncp.at] TRACE: > AT+CEER
0000435524 [ncp.at] TRACE: < +CEER: "No report available"
0000435525 [ncp.at] TRACE: < OK
0000435526 [ncp.at] TRACE: > AT+CREG?
0000435529 [ncp.at] TRACE: < +CREG: 2,0
0000435529 [ncp.at] TRACE: < OK
0000435530 [ncp.at] TRACE: > AT+CGREG?
0000435534 [ncp.at] TRACE: < +CGREG: 2,0
0000435534 [ncp.at] TRACE: < OK
0000435535 [ncp.at] TRACE: > AT+CSQ
0000435538 [ncp.at] TRACE: < +CSQ: 99,99
0000435539 [ncp.at] TRACE: < OK
0000450339 [ncp.at] TRACE: > AT+CIMI
0000450342 [ncp.at] TRACE: < 204047105351942
0000450343 [ncp.at] TRACE: < OK
0000450443 [ncp.client] TRACE: Sticky not registering CSD state for 90 s, PLMN reselection
0000450444 [ncp.at] TRACE: > AT+COPS=0,2
0000450447 [ncp.at] TRACE: < ERROR
0000450547 [ncp.at] TRACE: > AT+CEER
0000450551 [ncp.at] TRACE: < +CEER: "No report available"
0000450552 [ncp.at] TRACE: < OK
0000450552 [ncp.at] TRACE: > AT+CREG?
0000450555 [ncp.at] TRACE: < +CREG: 2,0
0000450556 [ncp.at] TRACE: < OK
0000450557 [ncp.at] TRACE: > AT+CGREG?
0000450560 [ncp.at] TRACE: < +CGREG: 2,0
0000450560 [ncp.at] TRACE: < OK
0000450561 [ncp.at] TRACE: > AT+CSQ
0000450564 [ncp.at] TRACE: < +CSQ: 99,99
0000450565 [ncp.at] TRACE: < OK
0000465565 [ncp.at] TRACE: > AT+CEER
0000465568 [ncp.at] TRACE: < +CEER: "No report available"
0000465569 [ncp.at] TRACE: < OK
0000465570 [ncp.at] TRACE: > AT+CREG?
0000465573 [ncp.at] TRACE: < +CREG: 2,0
0000465573 [ncp.at] TRACE: < OK
0000465574 [ncp.at] TRACE: > AT+CGREG?
0000465577 [ncp.at] TRACE: < +CGREG: 2,0
0000465577 [ncp.at] TRACE: < OK
0000465578 [ncp.at] TRACE: > AT+CSQ
0000465581 [ncp.at] TRACE: < +CSQ: 99,99
0000465581 [ncp.at] TRACE: < OK
0000480681 [ncp.at] TRACE: > AT+CEER
0000480685 [ncp.at] TRACE: < +CEER: "No report available"
0000480685 [ncp.at] TRACE: < OK
0000480686 [ncp.at] TRACE: > AT+CREG?
0000480689 [ncp.at] TRACE: < +CREG: 2,0
0000480690 [ncp.at] TRACE: < OK
0000480691 [ncp.at] TRACE: > AT+CGREG?
0000480694 [ncp.at] TRACE: < +CGREG: 2,0
0000480694 [ncp.at] TRACE: < OK
0000480695 [ncp.at] TRACE: > AT+CSQ
0000480699 [ncp.at] TRACE: < +CSQ: 99,99
0000480699 [ncp.at] TRACE: < OK
0000495699 [ncp.at] TRACE: > AT+CEER
0000495703 [ncp.at] TRACE: < +CEER: "No report available"
0000495703 [ncp.at] TRACE: < OK
0000495704 [ncp.at] TRACE: > AT+CREG?
0000495707 [ncp.at] TRACE: < +CREG: 2,0
0000495708 [ncp.at] TRACE: < OK
0000495709 [ncp.at] TRACE: > AT+CGREG?
0000495712 [ncp.at] TRACE: < +CGREG: 2,0
0000495712 [ncp.at] TRACE: < OK
0000495713 [ncp.at] TRACE: > AT+CSQ
0000495716 [ncp.at] TRACE: < +CSQ: 99,99
0000495717 [ncp.at] TRACE: < OK
0000510417 [ncp.at] TRACE: > AT+CIMI
0000510420 [ncp.at] TRACE: < 204047105351942
0000510421 [ncp.at] TRACE: < OK
0000510721 [ncp.at] TRACE: > AT+CEER
0000510724 [ncp.at] TRACE: < +CEER: "No report available"
0000510725 [ncp.at] TRACE: < OK
0000510726 [ncp.at] TRACE: > AT+CREG?
0000510729 [ncp.at] TRACE: < +CREG: 2,0
0000510729 [ncp.at] TRACE: < OK
0000510730 [ncp.at] TRACE: > AT+CGREG?
0000510733 [ncp.at] TRACE: < +CGREG: 2,0
0000510733 [ncp.at] TRACE: < OK
0000510734 [ncp.at] TRACE: > AT+CSQ
0000510737 [ncp.at] TRACE: < +CSQ: 99,99
0000510737 [ncp.at] TRACE: < OK
0000525738 [ncp.at] TRACE: > AT+CEER
0000525741 [ncp.at] TRACE: < +CEER: "No report available"
0000525742 [ncp.at] TRACE: < OK
0000525743 [ncp.at] TRACE: > AT+CREG?
0000525746 [ncp.at] TRACE: < +CREG: 2,0
0000525746 [ncp.at] TRACE: < OK
0000525747 [ncp.at] TRACE: > AT+CGREG?
0000525750 [ncp.at] TRACE: < +CGREG: 2,0
0000525750 [ncp.at] TRACE: < OK
0000525751 [ncp.at] TRACE: > AT+CSQ
0000525755 [ncp.at] TRACE: < +CSQ: 99,99
0000525755 [ncp.at] TRACE: < OK
0000540855 [ncp.at] TRACE: > AT+CEER
0000540858 [ncp.at] TRACE: < +CEER: "No report available"
0000540859 [ncp.at] TRACE: < OK
0000540860 [ncp.at] TRACE: > AT+CREG?
0000540863 [ncp.at] TRACE: < +CREG: 2,0
0000540863 [ncp.at] TRACE: < OK
0000540864 [ncp.at] TRACE: > AT+CGREG?
0000540867 [ncp.at] TRACE: < +CGREG: 2,0
0000540867 [ncp.at] TRACE: < OK
0000540868 [ncp.at] TRACE: > AT+CSQ
0000540871 [ncp.at] TRACE: < +CSQ: 99,99
0000540872 [ncp.at] TRACE: < OK
0000555572 [ncp.client] TRACE: Sticky not registering CSD state for 105 s, PLMN reselection
0000555573 [ncp.at] TRACE: > AT+COPS=0,2
0000555576 [ncp.at] TRACE: < ERROR
0000555876 [ncp.at] TRACE: > AT+CEER
0000555879 [ncp.at] TRACE: < +CEER: "No report available"
0000555880 [ncp.at] TRACE: < OK
0000555881 [ncp.at] TRACE: > AT+CREG?
0000555884 [ncp.at] TRACE: < +CREG: 2,0
0000555884 [ncp.at] TRACE: < OK
0000555885 [ncp.at] TRACE: > AT+CGREG?
0000555888 [ncp.at] TRACE: < +CGREG: 2,0
0000555889 [ncp.at] TRACE: < OK
0000555890 [ncp.at] TRACE: > AT+CSQ
0000555893 [ncp.at] TRACE: < +CSQ: 99,99
0000555893 [ncp.at] TRACE: < OK
0000570493 [ncp.at] TRACE: > AT+CIMI
0000570496 [ncp.at] TRACE: < 204047105351942
0000570497 [ncp.at] TRACE: < OK
0000570897 [ncp.at] TRACE: > AT+CEER
0000570901 [ncp.at] TRACE: < +CEER: "No report available"
0000570902 [ncp.at] TRACE: < OK
0000570903 [ncp.at] TRACE: > AT+CREG?
0000570905 [ncp.at] TRACE: < +CREG: 2,0
0000570906 [ncp.at] TRACE: < OK
0000570907 [ncp.at] TRACE: > AT+CGREG?
0000570910 [ncp.at] TRACE: < +CGREG: 2,0
0000570910 [ncp.at] TRACE: < OK
0000570911 [ncp.at] TRACE: > AT+CSQ
0000570914 [ncp.at] TRACE: < +CSQ: 99,99
0000570915 [ncp.at] TRACE: < OK
0000585915 [ncp.at] TRACE: > AT+CEER
0000585919 [ncp.at] TRACE: < +CEER: "No report available"
0000585920 [ncp.at] TRACE: < OK
0000585921 [ncp.at] TRACE: > AT+CREG?
0000585924 [ncp.at] TRACE: < +CREG: 2,0
0000585924 [ncp.at] TRACE: < OK
0000585925 [ncp.at] TRACE: > AT+CGREG?
0000585927 [ncp.at] TRACE: < +CGREG: 2,0
0000585928 [ncp.at] TRACE: < OK
0000585929 [ncp.at] TRACE: > AT+CSQ
0000585932 [ncp.at] TRACE: < +CSQ: 99,99
0000585932 [ncp.at] TRACE: < OK
0000601032 [ncp.at] TRACE: > AT+CEER
0000601036 [ncp.at] TRACE: < +CEER: "No report available"
0000601036 [ncp.at] TRACE: < OK
0000601037 [ncp.at] TRACE: > AT+CREG?
0000601040 [ncp.at] TRACE: < +CREG: 2,0
0000601041 [ncp.at] TRACE: < OK
0000601042 [ncp.at] TRACE: > AT+CGREG?
0000601045 [ncp.at] TRACE: < +CGREG: 2,0
0000601045 [ncp.at] TRACE: < OK
0000601046 [ncp.at] TRACE: > AT+CSQ
0000601049 [ncp.at] TRACE: < +CSQ: 99,99
0000601050 [ncp.at] TRACE: < OK
0000616050 [ncp.at] TRACE: > AT+CEER
0000616054 [ncp.at] TRACE: < +CEER: "No report available"
0000616054 [ncp.at] TRACE: < OK
0000616055 [ncp.at] TRACE: > AT+CREG?
0000616058 [ncp.at] TRACE: < +CREG: 2,0
0000616059 [ncp.at] TRACE: < OK
0000616060 [ncp.at] TRACE: > AT+CGREG?
0000616063 [ncp.at] TRACE: < +CGREG: 2,0
0000616063 [ncp.at] TRACE: < OK
0000616064 [ncp.at] TRACE: > AT+CSQ
0000616067 [ncp.at] TRACE: < +CSQ: 99,99
0000616068 [ncp.at] TRACE: < OK
0000616068 [ncp.client] WARN: Resetting the modem due to the network registration timeout
0000616069 [ncp.client] TRACE: NCP connection state changed: 0
0000616069 [net.pppncp] TRACE: NCP event 2
0000616070 [net.pppncp] TRACE: State changed event: 0
0000616070 [ncp.client] TRACE: NCP state changed: 0
0000616071 [net.pppncp] TRACE: NCP event 1
0000616072 [mux] INFO: Stopping GSM07.10 muxer
0000616071 [net.ppp.client] TRACE: PPP thread event LOWER_DOWN data=0
0000616073 [mux] INFO: Gracefully stopping GSM07.10 muxer
0000616073 [mux] INFO: Closing all muxed channels
0000616074 [mux] INFO: Closing mux channel 1
0000616074 [mux] INFO: Muxed channel 2 already closed
0000616075 [mux] INFO: Muxed channel 3 already closed
0000616076 [mux] INFO: Muxed channel 4 already closed
0000617342 [mux] INFO: Sending CLD (multiplexer close down)
0000617344 [mux] INFO: Received response to CLD or timed out, exiting multiplexed mode
0000617344 [mux] INFO: GSM07.10 muxer thread exiting
0000617345 [mux] INFO: GSM07.10 muxer stopped
0000617346 [net.pppncp] TRACE: NCP event 3
0000617346 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_DOWN
0000617347 [system.nm] TRACE: Interface 4 power state changed: 3
0000617347 [ncp.client] TRACE: Powering modem off using hardware control
0000617348 [ncp.client] TRACE: Setting UART voltage translator state 0
0000618848 [net.pppncp] TRACE: NCP event 3
0000618848 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_DOWN
0000618849 [system.nm] TRACE: Interface 4 power state changed: 1
0000618849 [ncp.client] TRACE: Modem powered off
0000618950 [ncp.client] TRACE: Powering modem on, ncpId: 0x42
0000618950 [net.pppncp] TRACE: NCP event 3
0000618951 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_UP
0000618951 [system.nm] TRACE: Interface 4 power state changed: 4
0000618962 [net.pppncp] TRACE: NCP event 3
0000618962 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_UP
0000618963 [system.nm] TRACE: Interface 4 power state changed: 2
0000618963 [ncp.client] TRACE: Modem powered on
0000618964 [ncp.client] TRACE: Setting UART voltage translator state 1
0000619064 [ncp.client] TRACE: Setting UART voltage translator state 0
0000619164 [ncp.client] TRACE: Setting UART voltage translator state 1
0000620165 [ncp.at] TRACE: > AT
0000621165 [ncp.at] TRACE: > AT
0000622165 [ncp.at] TRACE: > AT
0000623165 [ncp.at] TRACE: > AT
0000624165 [ncp.at] TRACE: > AT
0000624167 [ncp.at] TRACE: < OK
0000624168 [ncp.client] TRACE: NCP ready to accept AT commands
0000624168 [ncp.at] TRACE: > AT
0000624171 [ncp.at] TRACE: < OK
0000624171 [ncp.at] TRACE: > ATI9
0000624196 [ncp.at] TRACE: < 23.60,A01.01
0000624196 [ncp.at] TRACE: < OK
0000624197 [ncp.client] TRACE: App firmware: 101
0000624197 [ncp.at] TRACE: > AT+UGPIOC?
0000624201 [ncp.at] TRACE: < +UGPIOC:
0000624202 [ncp.at] TRACE: < 16,255
0000624203 [ncp.at] TRACE: < 23,255
0000624203 [ncp.at] TRACE: < 24,4
0000624204 [ncp.at] TRACE: < 25,5
0000624204 [ncp.at] TRACE: < 34,12
0000624205 [ncp.at] TRACE: < 35,12
0000624206 [ncp.at] TRACE: < 36,12
0000624206 [ncp.at] TRACE: < 37,12
0000624207 [ncp.at] TRACE: < 42,7
0000624207 [ncp.at] TRACE: < OK
0000624208 [ncp.client] INFO: Using internal SIM card
0000624209 [ncp.at] TRACE: > AT+CPIN?
0000624213 [ncp.at] TRACE: < +CPIN: READY
0000624214 [ncp.at] TRACE: < OK
0000624214 [ncp.at] TRACE: > AT+CCID
0000624448 [ncp.at] TRACE: < +CCID: 89314404000573211753
0000624449 [ncp.at] TRACE: < OK
0000624449 [ncp.at] TRACE: > AT+IFC?
0000624453 [ncp.at] TRACE: < +IFC: 2,2
0000624454 [ncp.at] TRACE: < OK
0000624454 [ncp.at] TRACE: > AT+IFC=2,2
0000624458 [ncp.at] TRACE: < OK
0000624459 [ncp.at] TRACE: > AT
0000625459 [ncp.at] TRACE: > AT
0000625461 [ncp.at] TRACE: < OK
0000625462 [ncp.at] TRACE: > AT+IPR=921600
0000625465 [ncp.at] TRACE: < OK
0000626466 [ncp.at] TRACE: > AT
0000626468 [ncp.at] TRACE: < OK
0000626468 [ncp.at] TRACE: > AT+COPS=3,2
0000626471 [ncp.at] TRACE: < OK
0000626472 [ncp.at] TRACE: > AT+CGEREP=1,0
0000626474 [ncp.at] TRACE: < OK
0000626475 [ncp.at] TRACE: > AT+UPSV=0
0000626478 [ncp.at] TRACE: < OK
0000626478 [ncp.at] TRACE: > AT+CMUX=0,0,,1509,,,,,
0000626608 [ncp.at] TRACE: < OK
0000626608 [mux] INFO: Starting GSM07.10 muxer
0000626609 [mux] INFO: Openning mux channel 0
0000626610 [mux] INFO: GSM07.10 muxer thread started
0000626612 [mux] INFO: Openning mux channel 1
0000627880 [ncp.at] TRACE: > AT
0000627883 [ncp.at] TRACE: < OK
0000627883 [ncp.client] TRACE: NCP state changed: 1
0000627884 [net.pppncp] TRACE: NCP event 1
0000627885 [net.ppp.client] TRACE: PPP thread event ADM_UP data=0
0000627887 [ncp.at] TRACE: > AT+CFUN?
0000627890 [ncp.at] TRACE: < +CFUN: 1,0
00000812466 [ncp.at] TRACE: < ERROR
0000812467 [ncp.at] TRACE: > AT+CIMI
0000812468 [ncp.at] TRACE: < +CREG: 4
0000812469 [ncp.at] TRACE: < +CGREG: 4
0000812470 [ncp.at] TRACE: < +CREG: 2
0000812471 [ncp.at] TRACE: < +CGREG: 2
0000812471 [ncp.at] TRACE: < +CREG: 3
0000812472 [ncp.at] TRACE: < +CGREG: 3
0000812473 [ncp.at] TRACE: < 204047105351942
0000812473 [ncp.at] TRACE: < OK
0000812474 [ncp.at] TRACE: > AT+CEER
That SIM successfully transitioned to active state Oct 6, 2024, 02:41:58 PM EDT (-0400).
If the log was taken after that, either that location does not have 2G/3G service, or there could be a problem with the antenna. If you are in the United States, it almost certainly will not be able to connect now.
