Tryng to get started with Electron 3G-U270
OK, failing at the first hurdle here. setup.paticle.io does not proceed past step 1 with a new deice out of the box. Device is detected, but then nothing happens. Installed CLI to do it that way, but CLI helpfully informs me that electrons cannot be setup via the CLI
I've just noticed that the electron has finally stopped blinking green madly and is now 'breathing' cyan - but that doesn't appear to change the behaviour at setup.particle.io - just can't get past the detect statge.
Anyone else experienced this?
What else can I try to help fix or diagnose the problem further?
