I can’t connect the core to the Wifi network, it gets stuck in green light forever. I tried using the USB connection without any luck, factory reset, recheck the credentials and still no luck. Tried using Android Nexus 5, iPhone 5s and nothing yet. Please any help will be appreciated.
This is a procedure that I’ve used many times to fix a stuck green core.
Green Flash Fix:
-Connect your core via usb
-Hold down both buttons and release the reset button, keep holding until your core flashes yellow
-Open Node.js command prompt as administrator
-Start session
spark cloud login
-Update your factory reset version:
spark flash --factory tinker
-Run the patch
spark flash --usb cc3000
-Once your core stops flashing purple, and starts flashing yellow again, reload tinker
spark flash --usb tinker
-Plug your wifi credentials back in with
spark setup wifi
I'm getting this error if try to run from the Node.js prompt:
npm install -g spark-cli
npm should be run outside of t
(Press Control-D to exit.)
and this is the result with the dfu-util:
D:\Spark>dfu-util -d 1d50:607f -a 0 -s 0x08005000:leave -D cc3000-patch-programm
er.bin
dfu-util 0.8
Invalid DFU suffix signature
ID 1d50:607f
Claiming USB DFU Interface...
Determining device status: state = dfuERROR, status = 10
dfuERROR, clearing status
dfuIDLE, continuing
Device returned transfer size 1024
Downloading to address = 0x08005000, size = 25248
Download [=========================] 100% 25248 bytes
Download done.
File downloaded successfully
Transitioning to dfuMANIFEST state
