I’ve been trying to get around this without luck.
I have a spark core that connects to the cloud without problem (most of the time breathing cyan, once in a while (after a long time) flashes cyan a little). I tried to flash the example blink-an-led.ino through the web-ide without luck: sometimes it goes magenta for a momento but the flash fails on the web.
Things I tried:
factory reset using the buttons
factory reset using the cli (particle flash --factory tinker fails thought: Last page at 0x000343af is not writeable) and I ended having to do a factory reset with the buttons again
I have the console too, didn’t try to flash through there yet because I’m just starting to play with this.
Okey, I tried to flash it through the CLI at first didn’t work but I put into DFU mode and resetted the keys (keys server & keys doctor ) and everything started to work. I can use the web-ide without problems now.
