[Solved] Doing deep update
Hello all,
I am a newbie in sparkcore. So please excuse me if this sounds a petty issue.
I want to do a deep update for the spark firmware as I read on forums that its necessary to do so if you want to get connected to a webpage. However, while doing so I get the following error:
Apparently I didn’t find a DFU device? util said
Error writing firmware… no dfu device found.
I have kept the core in dfu mode(the led blinks yellow). Still I cannot do the update. Also now after trying to do this update for several times, I cannot connect to the core anymore. Even after doing a factory reset.
Please suggest me. I am kind of lost now. As I am new to all this, I am not very sure which direction to proceed now.
Thank you in advance.
Make sure you have the DFU driver installed properly if you are on windows or try changing a USB cable. :slight_smile:
Hi @nj187 Sounds like you are using the Spark CLI with this command?
spark flash --usb cc3000
If so you also need to make sure you have the DFU driver installed, and DFU-UTIL is installed on your machine.
Windows:
Mac:
Hello BDub,
Thank you for a prompt reply. I am using a linux system. And I learned that I have a dfu-util version 0.5
Could that be a problem?
Also, I have the spark-cli installed. But not very sure if I am using it. Could you tell me if there is a certain procedure to use it? Or once its installed, I just us my normal command line?
Sorry for this petty query. But I am a bit lost now.
Possibly, since 0.8 is out… and most of the development for Spark has been done with dfu-util 0.7.
If you have Homebrew installed… try this:
brew update
brew upgrade dfu-util
Or if on a Linux machine check here for the right setup:
http://wiki.openmoko.org/wiki/Dfu-util
To use Spark-CLI open a terminal and type spark --version to check and see if your version reported is 0.4.4 and if not run sudo npm update -g spark-cli to upgrade it.
After that you can put your core into DFU mode and run the deep update:
I get the following now:
File downloaded successfully
Transitioning to dfuMANIFEST state
Error during download get_status
Flashed!
Not sure about the Error.
Hello,
I just checked. And this seems to have worked.
I could connect the core again to the cloud.
thank you so much.
Now my actual task begins. I need to connect to a webpage (.php) which will then via twillio send a message to a number.
Could you give me any suggestions/guidance for the same?
You are going to want to look at http://docs.spark.io/firmware/#communication-tcpclient but I think this would be best done in it’s own thread (for easy searching). Would you mind creating a new topic if you have questions about connecting to a web page? I’m going to make this “solved” for now. Feel free to comment back if you have additional deep update issues.
Yes sure. I will create a new topic. thank you again.
Check these projects out…
