Hello everyone,
I am attempting to read values over serial, but receive this message in the terminal:
I didn't find any cores available via serial
No serial port identified
I’ve connected one of my Cores to both a MacBook Pro and a PC, trying every USB port on each. Of my three Cores, this is the only one for which that message is displayed. Has anyone else encountered this issue and is there a way to resolve it?
Wondering if the issue was the code on each Core, I flashed the code from the “faulty” Core onto the others and the others worked fine. That single Core does not. Below is the code currently loaded:
#define STEPS 200
#define ADCwidth 12
#define ADCsteps pow(2, ADCwidth)
#define maxSpeed 256 //RPM (for test, using max LED value 255)
//Stepper stepper1(STEPS, D0, D1, D2, D3);
int potPin = A0;
int ledPin = D7;
int potVal = 0;
uint8_t speed = 0;
pinMode(potPin, INPUT);
pinMode(ledPin, OUTPUT); //LED brightness correlates to motor speed
//stepper1.setSpeed(0);
potVal = analogRead(potPin);
speed = floor(potVal/(ADCsteps/maxSpeed));
analogWrite(ledPin, speed);
//stepper1.setSpeed(speed);
//stepper1.step(1);
display();
void display() {
Serial.print("Pot Val: ");
Serial.print(potVal);
Serial.print(" | ");
Serial.print("Speed: ");
Serial.println(speed);
Finally, I flashed the “Blink An LED” app onto the Core and modified it to print the LEDstate. Terminal again displayed the above message.
Any help would be greatly appreciated.
