SOLVED -- Cannot connect Photon - blinking cyan with red flashes
Brand new Photon, right out of the box - can’t connect it to the cloud. Blinking cyan with red flashes.
  • The Tinker app setup fails
  • Using the CLI (on Mac running for 10.11.2) for USB setup fails
  • Then I’ve done:
Manual Firmware Update, following instructions here:
https://docs.particle.io/support/troubleshooting/common-issues/photon/#flashing-cyan
  • Then I’ve done:
Public Key Reset, following instructions here:
  • Then I hit the Particle forum and tried this:
• place Photon in DFU-mode
• particle update
• particle flash --usb tinker
• hold on to the SETUP button until the device blinks blue
• release SETUP button and press and hold until it blinks blue rapidly to clear wifi credentials
• particle serial wifi to setup Wifi credentials
Network meets all of the Wi-Fi network requirements. I’ve tried it on multiple networks (that I’ve connected other Cores and Photons to).
I don’t know what else to try. Just a bad unit maybe? Can I get a new one? Anyone got any suggestions?
I just had the same problem, scroll down to 60th comments where I solve this issue.
Who solved your issue(s)?
Hahaha touche
Thanks so much, but the solutions from that thread did not work.
I put the device in DFU mode and pasted in the device id with this command:
particle keys doctor paste-device-id
It failed and I got this message:
Deducing device DFU version from functional descriptor length
ID 2b04:d006
Claiming USB DFU Interface...
Setting Alternate Setting #1 ...
dfuIDLE, continuing
DfuSe interface name: "DCT Flash   "
Downloading to address = 0x00000022, size = 608
Download	[=========================] 100%          608 bytes
Download done.
File downloaded successfully
Saved!
running openssl rsa -inform PEM -in paste-device-id_rsa_new.pub.pem -pubout -outform PEM -out /var/folders/sy/trb7qvx90hj2fqxfd96xt7n00000gp/T/116024-20605-1etqrk0.pub.pem
running openssl rsa -pubin -inform PEM -in paste-device-id_rsa_new.pub.pem -pubout -outform PEM -out /var/folders/sy/trb7qvx90hj2fqxfd96xt7n00000gp/T/116024-20605-1etqrk0.pub.pem
attempting to add a new public key for device paste-device-id
Error sending public key to server: Permission Denied
Make sure your device is in DFU mode (blinking yellow), and that your computer is online.
Error - undefined
This thing will not connect! Any other suggestions would be appreciated. Thanks all.
Just out of curiosity
How often have you replaced your Device ID in the output pasted there?
Just once. Well maybe twice - I inadvertently ran the “paste-device-id” command without the Device ID number and got the message below. Then I ran it properly and got the message above.
   Warning! - device id was shorter than 24 characters - did you use something other than an id?
   use particle identify to find your device id
running dfu-util -l
Found DFU device 2b04:d006
running dfu-util -l
running openssl genrsa -out paste-device-id_rsa_new.pem 1024
running openssl rsa -in paste-device-id_rsa_new.pem -pubout -out paste-device-id_rsa_new.pub.pem
running openssl rsa -in paste-device-id_rsa_new.pem -outform DER -out paste-device-id_rsa_new.der
New Key Created!
running dfu-util -l
running dfu-util -l
running dfu-util -d 2b04:d006 -a 1 -s 34:612 -U backup_rsa_paste-device-id_rsa_new.der
running openssl rsa -in backup_rsa_paste-device-id_rsa_new.der -inform DER -pubout -out backup_rsa_paste-device-id_rsa_new.pub.pem
Unable to generate public key from the key downloaded from the device. This usually means you had a corrupt key on the device. Error:  { [Error: Command failed: /bin/sh -c openssl rsa -in backup_rsa_paste-device-id_rsa_new.der -inform DER -pubout -out backup_rsa_paste-device-id_rsa_new.pub.pem
unable to load Private Key
20539:error:0D07207B:asn1 encoding routines:ASN1_get_object:header too long:/BuildRoot/Library/Caches/com.apple.xbs/Sources/OpenSSL098/OpenSSL098-59/src/crypto/asn1/asn1_lib.c:153:
20539:error:0D068066:asn1 encoding routines:ASN1_CHECK_TLEN:bad object header:/BuildRoot/Library/Caches/com.apple.xbs/Sources/OpenSSL098/OpenSSL098-59/src/crypto/asn1/tasn_dec.c:1328:
20539:error:0D06A03A:asn1 encoding routines:ASN1_COLLECT:nested asn1 error:/BuildRoot/Library/Caches/com.apple.xbs/Sources/OpenSSL098/OpenSSL098-59/src/crypto/asn1/tasn_dec.c:1212:
20539:error:0D094071:asn1 encoding routines:d2i_ASN1_SET:error parsing set element:/BuildRoot/Library/Caches/com.apple.xbs/Sources/OpenSSL098/OpenSSL098-59/src/crypto/asn1/a_set.c:218:address=140221475812576 offset=1994379272
20539:error:0D0680A8:asn1 encoding routines:ASN1_CHECK_TLEN:wrong tag:/BuildRoot/Library/Caches/com.apple.xbs/Sources/OpenSSL098/OpenSSL098-59/src/crypto/asn1/tasn_dec.c:1341:
20539:error:0D06C03A:asn1 encoding routines:ASN1_D2I_EX_PRIMITIVE:nested asn1 error:/BuildRoot/Library/Caches/com.apple.xbs/Sources/OpenSSL098/OpenSSL098-59/src/crypto/asn1/tasn_dec.c:845:
20539:error:0D08303A:asn1 encoding routines:ASN1_TEMPLATE_NOEXP_D2I:nested asn1 error:/BuildRoot/Library/Caches/com.apple.xbs/Sources/OpenSSL098/OpenSSL098-59/src/crypto/asn1/tasn_dec.c:765:Field=iqmp, Type=RSA
20539:error:0D09A00D:asn1 encoding routines:d2i_PrivateKey:ASN1 lib:/BuildRoot/Library/Caches/com.apple.xbs/Sources/OpenSSL098/OpenSSL098-59/src/crypto/asn1/d2i_pr.c:99:
  killed: false,
  code: 1,
  signal: null,
  cmd: '/bin/sh -c openssl rsa -in backup_rsa_paste-device-id_rsa_new.der -inform DER -pubout -out backup_rsa_paste-device-id_rsa_new.pub.pem' }
Saved!
checking file paste-device-id_rsa_new.der
spawning dfu-util -d 2b04:d006 -a 1 -i 0 -s 34:leave -D paste-device-id_rsa_new.der
dfu-util 0.8
ID 2b04:d006
dfuIDLE, continuing
Downloading to address = 0x00000022, size = 610
Download	[=========================] 100%          610 bytes
Download done.
Saved!
running openssl rsa -inform PEM -in paste-device-id_rsa_new.pub.pem -pubout -outform PEM -out /var/folders/sy/trb7qvx90hj2fqxfd96xt7n00000gp/T/116024-20525-160309o.pub.pem
running openssl rsa -pubin -inform PEM -in paste-device-id_rsa_new.pub.pem -pubout -outform PEM -out /var/folders/sy/trb7qvx90hj2fqxfd96xt7n00000gp/T/116024-20525-160309o.pub.pem
Error - undefined
c-6106-cp:~ doug$ particle keys doctor paste-device-id 3D0020000347343339373536
Hmm, it still doesn’t make sense tho’
I think you are misunderstanding the suggested command line
It’s not meant to be
but
particle keys doctor <replace-this-with-your-device-id>
so in your case
particle keys doctor 3D0020000347343339373536
Well, that could be. I think I used your second command there, but I might not have - command line still somewhat new to me. I’ll try again. Thanks.
Ok I ran the key doctor command while in DFU mode,
$ particle keys doctor 3D0020000347343339373536
got this:
running dfu-util -l
running dfu-util -l
running openssl genrsa -out 3D0020000347343339373536_rsa_new.pem 1024
running openssl rsa -in 3D0020000347343339373536_rsa_new.pem -pubout -out 3D0020000347343339373536_rsa_new.pub.pem
running openssl rsa -in 3D0020000347343339373536_rsa_new.pem -outform DER -out 3D0020000347343339373536_rsa_new.der
New Key Created!
running dfu-util -l
running dfu-util -l
running dfu-util -d 2b04:d006 -a 1 -s 34:612 -U backup_rsa_3D0020000347343339373536_rsa_new.der
running openssl rsa -in backup_rsa_3D0020000347343339373536_rsa_new.der -inform DER -pubout -out backup_rsa_3D0020000347343339373536_rsa_new.pub.pem
Saved!
checking file 3D0020000347343339373536_rsa_new.der
spawning dfu-util -d 2b04:d006 -a 1 -i 0 -s 34:leave -D 3D0020000347343339373536_rsa_new.der
dfu-util 0.8
ID 2b04:d006
dfuIDLE, continuing
Download done.
Saved!
running openssl rsa -inform PEM -in 3D0020000347343339373536_rsa_new.pub.pem -pubout -outform PEM -out /var/folders/sy/trb7qvx90hj2fqxfd96xt7n00000gp/T/116024-24342-2td6bk.pub.pem
running openssl rsa -pubin -inform PEM -in 3D0020000347343339373536_rsa_new.pub.pem -pubout -outform PEM -out /var/folders/sy/trb7qvx90hj2fqxfd96xt7n00000gp/T/116024-24342-2td6bk.pub.pem
attempting to add a new public key for device 3D0020000347343339373536
Error - undefined
From the above, this seems significant:
Error - undefined
Well, now it might be time to call The Keymaker @kennethlimcp
And I guess you had checked the things noted
And you had run particle login and particle device add 3D0020000347343339373536 (or had it claimed) beforehand.
Think so. I’ll review / try agian. Thanks again.
Device has never been claimed. Never successfully connected.
Definetly something for Kenneth then (or Particle during office hours).
If the device hasn’t been claimed then you don’t need to send the key to the cloud. If it’s still not connecting, then please try also flashing the server key to the device.
Maybe this is a chance for me to get clear on the nomenclature. “Claiming” is going through the process of setting up the device, under my account, connecting it to a wifi network and to the cloud, yes?
This process has never been successfully completed. It bonks at the end of the setup process (either tinker app or usb / CLI) and blinks cyan with red flashes…then I’ve tried all of the things mentioned in this thread. I’ll try Kenneth. Thanks all.
Solved!!
Though I had previously flashed the server key to the device, I did it one more time, on mdma’s suggestion, after running the keys doctor command and voila!! Connected, claimed! I have indeed won the internet.
Thanks so much, everyone in this thread, for hanging in there with me.
Experiencing the same issues with an e-series electron. What command(s) are you running to “flash the server key to the device”.
Thanks in advance for any help!
Hi @until_arch @mdma
Exactly same issue. My device also not claimed before and giving me same error.
Will you please guide me how to flash server key to the device?
