The default method from Spark is using the (Android or iOS) Apps to perform Smart Configure core to WiFi network.
I would like know anyone had tried to use PC Web platform (like a webpage with JavaScript) to perform this ?
Or this is possible to do ?
I’m not sure if it’s possible. If so, you’d at least need a wireless connection, since the packages that are transmitted through that is what the Spark picks up for its credentials.
I think it should be possible. Check this:
http://processors.wiki.ti.com/index.php/Smart_Config_Application_development_information_-_Java_Applet
