I am starting to use Particle Dev (have been using the particle.io/build cloud before) … My problem is that If I try to click connect in the Serial monitor nothing happends,
if I connect to the serial port using putty everything works, so there seems to be no issue with hardware, if I disconnect the USB cable then the COM3 (which is the COMport my photon is on) will dissapear and it will re-appear when I connect (like it should),
If I try to enter anything in “Enter string to send” field nothing happends, no letters or anything appears,
to me it looks like the Serial monitor is somehow disabled, Don’t know how that can be thoug…
