No Serial Monitor Ports listed in Particle Desktop IDE
I’m using the Particle Desktop IDE on Windows 10. When I open the Serial Monitor, the combo box which is suppose to list the COM ports is empty. If I click connect, nothing happens.
ideas?
Just to confirm, you do see the COM ports listed in DevMgr?
Thanks for the quick reply.
The crazy thing is that I have fought on and off with this for a few days, and it just started working after I plugged my USB into a different port on my laptop.
Works perfectly now.
