SCADA project available
The “Jobs” section doesn’t seem to be taking new posts, so here seemed like the next best place. I have developed and installed a SCADA system for Waynesville, Ohio’s municipal water system. I’d like to pass it on to a Particle developer in the Waynesville area. The project requires a few “billable” hours per week to support and as hardware is involved this person needs to be somewhat local. Why do I want to give this project away, because I’m 72 and want to spend may available time on other stuff. Here’s a look at the system,
Let me know if you or someone you know might be interested.
I switched it over to jobs for you.
I own a SCADA company and am just down the road in Liberty Township. We install and develop traditional SCADA system using VHF/UHF radios but we have also developed custom cell based SCADA equipment based on the Particle Electron. We have a pump control board that uses the Electron and has 2 relay output, 6 digital inputs, 4 analog inputs (4-20 mA), 2 analog outputs (4-20 mA), with a touch screen. We have also developed a custom board using the Particle that has solar charging circuit, 2 analog inputs (0-5 vdc), and pulse input for connecting to pulse meters.
Our website is <www.incontroltechsolutions.com>.
Feel free to contact me if you are interested.
Best Regards,
Dave Stout
