Hello, I certainly don’t want to break the forum rules so, if this is inappropriate then please remove!
I just want to say i am currently looking for some Particle/Arduino programming and have advertised on freelancer.com. I’ve been battling to attach a link to the job. but if you use the Project ID: 19889238 it should come up.
Essentially I require code written for a Particle Micro-controller (Electron).
The electron will need to check a website for a 5 separate variables every 15 minutes,
Then adjusts a bank of relays to either open fill valves or drain valves until analog signals form a level sensor matches that of the website variables. The hardware is completed, i can supply pin in/out diagrams etc, I would need a brief written that i can supply my client to make the necessary and minimal adjustments to their website.
Kind Regards
Nick
