Hi All,
I have an Argon which is running its code at home controlling a greenhouse, and I’m away for another week. Today a sensor has failed, and I want to modify the code to keep the environment it controls stable. I cannot flash new code, it has stopped responding to the flash command within Particle Build.
The compile command is also not working, on any hardware I select, and any firmware I select. Is there a problem with build going on currently? Is there some explanation for the lack of ability to control this unit? From Console, I can see it’s operating normally other than the sensor reading zero humidity. I can ping the unit. I can refresh the vitals.
