Can't over-the-air flash
I've been away for quite some time, so I'm likely very out of date. I just tried to command line cloud flash an Argon running 2.1.0 with a new binary and I got the error "Failed to flash garageDoorChime: Permission Denied". I'm logged in as the correct user and updated the command line tool. I can see my device listed via particle list. Any suggestions would be welcome. I've missed working in this space and I'm eager to get re-acquainted.
@Support - can you take a look tomorrow?
By "take a look" do you mean trying again? If so, then yes. Thanks
was tagging in the support team :slight_smile:
Can you DM me the device ID (and your account email if it’s different from the forum) please?
Just to update any interested party and close this issue, I had evidently logged in so long ago the session was invalidated and I simply had to logout and login. Strange how so much functionality was available to me, but not flashing. Thanks @no1089 for the assist!
I assume this thread has not been solved. If it has been solved, please start a new topic. :grinning:
If you meant "not Cloud flashing" then yes, several things have changed which might be affecting your projects. Just yesterday, I tripped myself up by not following relatively new guidelines in using Workbench and CLI. Here are some posts with good explanations with what has changed and could be affecting you:
https://community.particle.io/t/issues-compiling-locally-and-on-the-cloud/64759
https://community.particle.io/t/sending-additional-files-to-cloud-compiler/64733
In my case, I was sending TOO MANY, or, irrelevant files to the cloud which caused an error. So, for every project I add to my workspace two files:
particle.include
particle.ignore
This ignore file allowed be to keep copies of libraries in my file structure and NOT use them for cloud compile or cloud flash to the cloud. (e.g. lib-old, lib-old2, lib 2, etc.)
https://community.particle.io/t/issue-cloud-compile-fails-but-local-compile-succeeds/64878/5
Sometimes I make a change to a library I am using in my local workspace compared to the cloud release version. In those cases, I need to make a change to the file: project.properties so my local version of the library will be flashed instead of the cloud version.
The issue was solved early today as I mentioned in my previous post.
Sorry, I misunderstood. :blush:
No problem. I appreciate your intent to help!
