I'm having trouble flashing locally, but I am able to cloud flash the project. The error is
Last page at 0x080a430f is not writeable (full output below), but I'm not sure what I need to do to tell VS Code how to deploy properly. Given that VS Code cloud flash works and my project then runs correctly I believe it is not code related. Thankfully not a huge issue, but I'd like to get it sorted out as I sometimes want to develop offline.
Argon with 2.3.0, error happens with or without a battery connected.
Executing task: make -f 'C:\Users{username-redacted}.particle\toolchains\buildscripts\1.10.0\Makefile' flash-user -s <
:::: PUTTING DEVICE INTO DFU MODE
Done.
:::: FLASHING APPLICATION
text data bss dec hex filename
16580 588 1492 18660 48e4 d:/{projectfolder-redacted}/target/2.3.0/photon/tempmon.elf
dfu-suffix (dfu-util) 0.9
Copyright 2011-2012 Stefan Schmidt, 2013-2014 Tormod Volden
Please report bugs to dfu-util / Tickets
Suffix successfully added to file
Serial device PARTICLE_SERIAL_DEV : not available
Flashing using dfu:
dfu-util 0.9
ID 2b04:d00c
Claiming USB DFU Interface...
dfuIDLE, continuing
Downloading to address = 0x080a0000, size = 17168
make[2]: *** [../../../build/module.mk:126: program-dfu] Error 74
make[1]: *** [../build/recurse.mk:12: modules/photon/user-part] Error 2
make: *** [C:\Users{username-redacted}.particle\toolchains\buildscripts\1.10.0\Makefile:86: flash-user] Error 2
The terminal process "C:\Users{username-redacted}.particle\toolchains\buildtools\1.1.1\bin\bash.exe '-c', 'make -f 'C:\Users{username-redacted}.particle\toolchains\buildscripts\1.10.0\Makefile' flash-user -s'" terminated with exit code: 2.
