out of the blue my photon is giving me suddenly a SOS with 14 blinks.
I did all the tricks found in the tutorial but nothing helps.
When in the cli I try to run "Particle device doctor" I get the following message:
The Doctor didn't complete successfully. Cannot read property 'code' of undefined
Please visit our community forums for help with this error:
Can anyone help me please.
O yes, an other little thing, after 1 min my photon is so hot that I can cook an egg on it. (a small egg)
14 blinks is heap error - what this means is that the RAM memory used by the application software as ‘working memory’ has run out or possibly become fragmented and unrecoverable.
This is an application problem.
Have you tried reloading the Tinker application and checking whether the photon works normally after that? Given you may have by now screwed up the device OS - I would reload the device OS from scratch using the CLI $particle flash --usb
Some photons do run hot - it could be that the voltage regulator is on the way out.
