I believe that what you’re saying is correct.
Currently, we have only been able to setup a device with windows 10 using: particle serial wifi
and getting the deviceID in advance to issue:
````particle device add deviceID``` once you’ve added the wifi credentials to it using the first step.
Has anyone been able to get the photon working in Windows 10? I’ve tried everything listed above with no luck. In DFU mode it shows up under Other Devices. In listening mode I see it under Serial ports after I force the driver to install as a legacy device but I get an error 10 stating the device is not working correctly.
I also had the same problem with my windows 10 system and my photon;
as @smogs posted above, did the same to get my photon to appear.
after my photon was visible it worked fine.
I’m really disappointed and frustrated with using the Particle Photon on Windows 10. I’m trying to write a program in which I need to get sample values from the Photon over a serial connection, but I can’t even get the Photon driver installed. When I plug the photon in to my laptop’s USB port, I get a message “USB device not recognized. The last USB device you connected has malfunctioned and Windows does not recognize it” I have tried using several different cables (all of which work perfectly with other USB devices) and had one success using a USB 2.0 hub between the Photon and my computer. However that was short-lived as the error re-surfaced the first time I re-flashed my Photon while working on my project. After that I have not been able to get it working after multiple tries. After I get the message, I see the connected Photon listed only as an Unkown USB Device (Device Descriptor Request Failed), and I cannot update the driver for it or do anything to make it work as a port.
I have the same problem on all my 3 photon boards. It recognize the hardware, but having problem creating a Comm port on windows 10. I will try to install the new driver tonight the one from ScruffR above…
