I have a connection problem with the photon.
It connect to the internet and after that blinking red 3 times.
As I read in the manual this is a problem to connect to the cloud, but in the other computers on the same network there isn’t a connection problem with the connection.
@iftach, red blinking (SOS) is an indication of code problems typically. Are you saying that putting the photon in safe mode give you SOS blinking as well?
As it’s write in the getting started guide:
3 red blinks: Connected to the internet, but could not reach the Particle Cloud.
its seem to be some problem with the router because when I connect the photon through the hot-spot in my phone it’s work fine.
But all the other devices in the network is working.
I'm facing the same issue. 3 Red SOS: Connected to the internet, but could not reach the Particle Cloud.
I tried several methods to troubleshoot the problem but nothing happened
Problem: My photon was working perfectly from last 6 months but suddenly, it shows RED SOS error (i mentioned) then I unclaimed from my account. Again, I try to setup the photon but setup failed at "verifying product ownership". Due to this, I'm not able to claim again.
On the other hand, When I read below statement, I though that it may be code problem, so I tried to flash the device to tinker through serial (usb).
Despite of successful flash, it shows same RED SOS error.
I also tried the local flash, both system+application firmware through build system in dfu mode. Again, same error. So, I think, it is not the code problem.
One more thing- When I try to put the device in safe mode, it doesn't stop on magneta, rather it blinks green then again cyan-red-cyan SOS error.
Ultimately, neither claiming nor connecting to cloud.
Just to clarify, since that confusion seemed to exist in the previous posts.
Do you see three red blinks between cyan or do you see a red SOS (… — …) followed by three red blinks and SOS again and the device restarting completely?
I had a flashing cyan light, follow by a quick burst of red/orange. This happened after my battery had did earlier and I found my photon had forgotten the wifi settings. After setting the Wifi again I hada this issue. I already tried installing the firmware again and serial loading the tinker app, but that not helped. Also the particle keys server cloud_public.der particle keys new photon particle keys load photon.der particle keys send photon.pub.pem didn’t help.
