I hve a 2 brand new Photon 2 device and I'm trying to set them up with USB on Ubuntu 22.04.3 LTS. When I connect to USB the device goes into flashing blue mode.
from https://setup.particle.io/ it click "Select Device" and I get a dialog that finds a device and shows:
P2
When i select P2 and click connect, I'm brought back to the original setup screen at https://setup.particle.io/ at the "Detect" phase. It never advances to "Update".
When I try again - I get a different option in the dialog: "P2-Paired", but still it doesn't advance to Update.
I tried installing cli with:
bash <( curl -sL https://particle.io/install-cli )
and it reported success, but I can't run command "particle" from my /bin directory even though I see the command and it seems executable:
ls -la gives:
-rwx--x--x 1 tgm tgm 8107418 Mar 1 09:09 particle
(base) tgm@aragorn:~/bin$ particle
particle: command not found
I'm using a Particle USB-cable.
