After several tentative to claim my third photon module, I was not able to flash the code. It says Time out! Also I noticed that the device loses the wifi connectivity several times. The IDE shows the device breathing Cyan, but not able to flash the code. Any suggestion?
If the device is repeatedly losing the connection, can you make sure you’ve got a sustainable signal at the location the Photon is at? Could you try moving it closer to the access point to see if that makes a noticeable difference?
Hi, thanks for the suggestion. I moved them closer to the wifi router and the are keeping the connection fine now. Even the claim was faster. BUT, I still can’t flash the blink led code to any of the 2 devices. I can send the “signal” and the RGB change colours, but not able to flash any code. Error message says:“Request Timed Out”.
Tried and didn’t work. The funny thing is that the IDE update the device quickly after unclaimed and claimed, but to flash the code it says time out. Even the Signal button is working.
