Monitor One I/O card connectors
Have been trying to find P/N's for the I/O card connectors (designing my own I/O card) most importantly for the connector used for the 8-pin M12 (labeled #16 in the manual), but it would also be good to know the P/N for the terminal block used for the 4-pin M12 connector.
Thank you!
The 8-pin connector is:
CONN HEADER SMD R/A 8POS 2MM S8B-PH-SM4-TB(LF)(SN) JST Sales America
The 4-pin connector is made from two 2-pin blade connectors:
CONN QC TAB 0.187 THT SOLDER 726389-2 TE Connectivity
Thank you!
The first P/N looks right, the second one is supposed to be a screw terminal, not a blade connector.
Sorry, the blades are on a different card.
TERMINAL BLOCK 3.5MM 2POS PCB J8, J9 2 KAWEEI CT3501-02-02P-04
However, you probably won't be able to source this, and new cards have a single 4-pin connector instead of two 2-pin screw terminal connectors. Fortunately, you should be able to source a standard 3.5mm screw terminal connector from almost any manufacturer and it should fit.
Thank you!
Sure this connector is essentially identical:
The color is sadly different :wink:
