Mac CLI installs but doesn't work
On Mac 11.5.2, I used the command
bash <( curl -sL https://particle.io/install-cli )
and get
:::: Installing the Particle CLI for darwin to "/Users/ewilhelm/bin/particle"
Traceback (most recent call last):
File "<string>", line 1, in <module>
KeyError: 'arm'
gunzip: (stdin): unexpected end of file
:::: Done!
:::: Installing dependencies
:::: The Particle CLI uses dfu-util. Install it for your OS
:::: Done!
:::: Success!
:::: The Particle CLI has been installed to: "/Users/ewilhelm/bin"
:::: Your "/Users/ewilhelm/.zprofile" file has been updated to properly set $PATH
:::: If you previously installed the CLI with npm, run "npm uninstall -g particle-cli"
** YOU MUST CLOSE AND REOPEN YOUR TERMINAL BEFORE CHANGES TAKE EFFECT **
I close and reopen terminal (I even tried restarting), but when I type in Terminal
particle
particle login
particle token create
I get no response, just a new line in Terminal.
What is my next step?
Eric
