I used the links on the particle website to create the command line for my particle electron, but I was unable to run anything on the command line. Below is one example of the error that keeps on approaching when I try to run anything with the particle command.
First, see if it installed correctly:
~/bin/particle login
If that doesnāt give a command not found error, then you just need to fix your PATH.
The .profile file in your home directory should have this in it (usually at the end):
# set PATH so it includes user's private bin if it exists
if [ -d "$HOME/bin" ] ; then
PATH="$HOME/bin:$PATH"
fi
If not, you should add it. Then reload it.
source ~/.profile
That should fix the problem, unless you are using an alternate shell like zsh.
I can't get the CLI to work on Mac OS Mojave. I've installed it using the curl command in the docs, and I got the welcome message. I see the particle executable in ~/bin. Trying to login from that directory, I get
"-bash: particle: command not found"
rics-iMac:bin ricdelmar$ pwd
/Users/ricdelmar/bin
rics-iMac:bin ricdelmar$ ls
particle
rics-iMac:bin ricdelmar$ particle login
If you are in the bin directory you probably will need to use ./particle login to use the particle command in the current directory.
Thanks, that worked. I was unaware that you couldnāt run an app from the directory itās in without that. I fixed my PATH variable using the instructions you wrote above, and now it works from my home directory.
I donāt know why this has to be so difficult. I tried to install it with ānpm install -g particle-cliā, and all the fixes (some that worked before) in this post, but they all gave me many errors. Iāll probably be back the next time I need to update the CLI to the latest version because that always goes badly. Unless there is a new, better way to update, I assume Iāll run into the same problems next time.
Definitely donāt use the npm update command on the Mac if youāve use the CLI installer bash command, instead just do:
particle update-cli
All of a sudden Iāve got this error where the āparticleā command from the terminal on my Mac is suddenly unrecognised. Weird.
booms-MacBook-Pro:parlour dac$ particle compile photon .
booms-MacBook-Pro:parlour dac$ sudo ln -s /usr/local/lib/particle-cli/bin/particle.js /usr/local/bin/particle
ln: /usr/local/bin/particle: File exists
booms-MacBook-Pro:parlour dac$ particle update-cli
booms-MacBook-Pro:parlour dac$ ~/bin/particle login
-bash: /Users/dac/bin/particle: No such file or directory
Running ābash <( curl -sL https://particle.io/install-cli )ā fixed it.
