I create a new particle project and call it TestProject. I set the build configuration to Xenon and rc.27. All builds just fine.
I go through the EXACT same process to create another particle project, in the same root directory and call it XenonTempSensor. I set the build configuration like in the TestProject.
When I try to compile the stub ino file it gives the following error.
> Executing task: make -f '/Users/johndoe/.particle/toolchains/buildscripts/1.0.1/Makefile' compile-user <
"/Users/johndoe/.vscode/extensions/particle.particle-vscode-core-1.0.0-alpha.7/src/cli/bin/darwin/amd64/particle" preprocess /Users/johndoe/Documents/projects/XenonTempSensor/src/XenonTempSensor.ino
cd "/Users/johndoe/.particle/toolchains/deviceOS/0.8.0-rc.27/firmware-0.8.0-rc.27//main" && make all
fatal: not a git repository (or any of the parent directories): .git
make[1]: Entering directory `/Users/johndoe/.particle/toolchains/deviceOS/0.8.0-rc.27/firmware-0.8.0-rc.27/main'
make -C ../modules/xenon/user-part all
make[2]: Entering directory `/Users/johndoe/.particle/toolchains/deviceOS/0.8.0-rc.27/firmware-0.8.0-rc.27/modules/xenon/user-part'
make -f ../../../modules/shared/nRF52840/build_linker_script.mk PREBUILD=1
make[3]: Entering directory `/Users/johndoe/.particle/toolchains/deviceOS/0.8.0-rc.27/firmware-0.8.0-rc.27/modules/xenon/user-part'
Creating module_user_memory.ld ...
make[3]: Leaving directory `/Users/johndoe/.particle/toolchains/deviceOS/0.8.0-rc.27/firmware-0.8.0-rc.27/modules/xenon/user-part'
make -C ../../../user
make[3]: Entering directory `/Users/johndoe/.particle/toolchains/deviceOS/0.8.0-rc.27/firmware-0.8.0-rc.27/user'
make[3]: *** No rule to make target `/Users/johndoe/Dropbox/projects/XenonTemp/XenonTempSensor//src/XenonTempSensor.cpp', needed by `../build/target/user/platform-14-m/XenonTempSensor/src/XenonTempSensor.o'. Stop.
make[3]: Leaving directory `/Users/johndoe/.particle/toolchains/deviceOS/0.8.0-rc.27/firmware-0.8.0-rc.27/user'
make[2]: *** [user] Error 2
make[2]: Leaving directory `/Users/johndoe/.particle/toolchains/deviceOS/0.8.0-rc.27/firmware-0.8.0-rc.27/modules/xenon/user-part'
make[1]: *** [modules/xenon/user-part] Error 2
make[1]: Leaving directory `/Users/johndoe/.particle/toolchains/deviceOS/0.8.0-rc.27/firmware-0.8.0-rc.27/main'
make: *** [compile-user] Error 2
The terminal process terminated with exit code: 2
Press any key to close the terminal.
I need to try some other examples but it appears to get confused if Xenon is in the name of the project?
can you try running the Particle: Clean application & DeviceOS (local) task - from VSCode’s main menu, select “Terminal > Run Task…” - and then try reproducing your issue?
That did the trick. Apparently going back and forth in VSCode via file-> open recents where I am developing code for both the argon and xenon gets the particle stuff confused. Cleaning fixed the issue, hooray!
I’m having the same kind of issue with the release 1.0 version of Particle Workbench. I’ve created a default project with no code and it still doesn’t compile and provides the same error.
> Executing task: make -f '/Users/xxx/.particle/toolchains/buildscripts/1.5.0/Makefile' compile-user -s <
../../../build/module.mk:239: warning: overriding commands for target `/Users/xxx/Local'
../../../build/module.mk:232: warning: ignoring old commands for target `/Users/xxx/Local'
../../../build/module.mk:239: warning: overriding commands for target `Files/dev/particle/GardenMon/GardenMon/target//Local'
../../../build/module.mk:232: warning: ignoring old commands for target `Files/dev/particle/GardenMon/GardenMon/target//Local'
../../../build/module.mk:248: warning: overriding commands for target `/Users/xxx/Local'
../../../build/module.mk:239: warning: ignoring old commands for target `/Users/xxx/Local'
../../../build/module.mk:248: warning: overriding commands for target `Files/dev/particle/GardenMon/GardenMon/target//Local'
../../../build/module.mk:239: warning: ignoring old commands for target `Files/dev/particle/GardenMon/GardenMon/target//Local'
../../../build/module.mk:272: warning: overriding commands for target `/Users/xxx/Local'
../../../build/module.mk:248: warning: ignoring old commands for target `/Users/xxx/Local'
../../../build/module.mk:277: warning: overriding commands for target `/Users/xxx/Local'
../../../build/module.mk:272: warning: ignoring old commands for target `/Users/xxx/Local'
../../../build/module.mk:293: warning: overriding commands for target `/Users/xxx/Local'
../../../build/module.mk:277: warning: ignoring old commands for target `/Users/xxx/Local'
make[2]: Circular /Users/xxx/Local <- /Users/xxx/Local dependency dropped.
build.mk:65: *** "No sources found in /Users/xxx/Local Files/dev/particle/GardenMon/GardenMon/". Stop.
make[1]: *** [modules/electron/user-part] Error 2
