We have a new Developer Preview release of Workbench to share that adds support for Device OS 1.0.0 and support for Multi-root workspaces.
Using Multi-root Workspaces in Workbench
Visual Studio Code supports more complex projects where you have separate but related workspaces. For example, you may have a Device OS app and a Node.js server to respond to webhooks or a network of Argons and Xenons, each running different apps. Based on community feedback, we decided to add support. By adding support for Multi-root workspaces in Workbench, we can manage all the configuration and build system metadata cleanly. If your application doesn’t require the use of Multi-root workspaces, no action required. If you want to use Multi-root workspaces on existing projects, you’ll need upgrade.
How to migrate a Particle Workspace:
- Open the folder of a an existing project within Visual Studio Code: “File > Open Folder…”
- Run
Particle: Configure Workspace for Device - Delete the
.code-workspacefile in the root of your project (or if you’ve made customizations, copy thesettingsblock into./.vscode/settings.json, then delete)
Note new projects created with Alpha 7 will support Multi-root workspaces be default
If you’ve already signed up for Workbench, you’ll receive an email with a link to download the update. If you’re not already using Workbench, visit particle.io/workbench to sign up and start building.
You can install the new version by following the instructions in Tutorial: Installing the Particle Workbench developer preview.
Please read the post, Information: How to report bugs and provide feedback for detailed instructions on how to provide feedback on Particle Workbench during developer preview.
We don’t plan on making a new release until after the New Year but please continue to share your feedback in the forum.
Here’s the full changelog:
New
- Added support for Device OS
v1.0.0as well asv0.8.0-rc.11,v0.8.0-rc.12&v0.8.0-rc.14 - Support Multi-root workspaces by modifying workspaces-related logic
- New Command:
Particle: Find Libraries - New Commands for Local Compilation Tasks - e.g.
Particle: Compile application (local)can now be run via the command palette in addition to the standard task runner UI - New: Current Toolchain settings are shown in the status bar
Fixes and Improvements
- Fixed "please install dependencies” prompts at start-up with improved CLI health check at activation-time
- Toolchains updated with
buildscripts@1.0.1 - You no longer need to reload window after changing your toolchain
Particle: Audit Environmentcommand now includes project settings for each project within the workspace - Better “environment unsupported” messaging at activation-time (hello and sorry to our windows / linux 32bit friends)
- Fix: Correct cpu arch mapping for CLI binaries
