Today we’re happy to share the first Developer Preview release of Workbench since Spectra. We’ve received tons of great feedback in that time and wanted to focus this release on fixes and improvements — but don’t worry, there’s plenty of new features as well!
If you’ve already signed up for Workbench, you’ll receive an email with a link to download the update. If you’re not already using Workbench, visit particle.io/workbench to sign up and start building.
You can install the new version by following the instructions in Tutorial: Installing the Particle Workbench developer preview.
Please read the post, Information: How to report bugs and provide feedback for detailed instructions on how to provide feedback on Particle Workbench during developer preview.
We’re looking forward to hearing your continued feedback and exctited to see what you build!
Here’s the full changelog:
New Commands
Particle: Audit Environment- Scans your system and prints a report to a dedicated output channel (helpful for filing bug reports)
Particle: Update CLI- Updates the local copy of the
particlecommand-line interface (CLI)
Particle: Serial Monitor- Monitor serial messages from the Integrated Terminal
Particle: Show Welcome Screen- Displays a new Particle welcome screen
Particle: Import Project- Attempts to convert an existing particle project into a Visual Studio Code Workspace
Particle: Reset Environment- Automatically uninstalls and re-installs all enabled local compiler toolchains
Fixes & Improvements
Particle: Login- Now supports Two-Factor Authentication
Particle: Cloud CompileandParticle: Cloud Flash- Now use the
--targetflag to prevent unintentional Device OS upgrades
- Now use the
Particle: Uninstall Local Compiler- No longer removes shared dependencies
Particle: Install Local Compiler- Displays list of available Device OS version
Particle: Launch CLI- Now prompts to re-use terminal if one exists
Particle: Cloud Flash- Now prompts you to set a target device if missing
Both
Particle: Install Local CompilerandParticle: Uninstall Local Compilerdisplay which Particle platforms each version supports -
All CLI-related commands provide a
view logsoption so users can see the full CLI error details (e.g. syntax errors causingParticle: Cloud Compileto fail) -
Local Compilation Tasks use
PLATFORM_IDinstead ofPLATFORMto prevent name collision -
Fixed bug that triggered “allow C++ IntelliSense configuration” prompt in non-Particle projects
Better logic to only show workspace-related functionality (e.g. tasks, IntelliSense) when working in a Particle Workspace
