IFTTT integrations not working
My next issue:
I just created a new webhook integration between my app and IFTTT, designed to initiate an alert via email if a certain event happens. My Particle.publish command correctly sends the event name ‘NoSignal’ to IFTTT, as shown in the integrations log in the Particle console. The webhook URL precisely matches between Particle and IFTTT. Yet the IFTTT applet refuses to run. Note that I have other very similar IFTTT applets that initiate emails (for different events) and they have all worked fine for years. It seems fairly certain that the problem is at the IFTTT end since the webhook is being triggered properly, but there is no user forum on IFTTT where I can post this inquiry, so I am hoping that someone here might be able to assist.
Any ideas what I am missing?
Hey, for completion, can you add pics of the webhook?
One remark: do your other applets use case sensitive names like this one?
NoSignal instead of nosignal
I would try all lowercase just for fun.
Opened a ticket with IFTTT. Here's their response: "We are aware of a problem causing issues with the email service. The team is looking at this, and should have a fix very shortly."
Ergo, not my issue, but thanks Gustavo.
