Ifttt apps not working with particle 9-8-2021
As a temporary solution, I’d recommend recreating your applets using the Webhooks Trigger on IFTTT along with a Particle Webhook. It’s effectively the reverse of using the Particle Trigger on IFTTT but I’ve found it to be more reliable. (You won’t need to change your application firmware on your devices if you use the same event name(s) in the Particle Webhook.)
