I have a Photon connected via usb and when I run particle flash --usb cc3000 I get this:
Found DFU device 2b04:d006
Error writing firmware…no known App found.
I am not able to connect to the Photon via the app. I can connect to it using particle setup but after setup is complete it doesn’t connect to anything, just continues to flash blue.
I’ve spent the last 2 hours trying to fix them. I’ve tried everything and they’re both not getting passed the flashing green.
The odd thing is I had them setup on my home network a couple of days ago. I reset them both to demo setup for a class. While I was able to get them connected to my tethered phone at the time, I haven’t been able to get them back on my home network.
Very confused and frustrated. Hoping my students aren’t in a similar situation.
This is a command to update the TI CC3000 chip that is only present on a Core and not a Photon. This command should not work on a Photon, although a better error message would certainly be helpful.
I solved it. After getting them both to work with my phone I realized there was something wrong with my local network. Not sure how that happened but everything is back up.
