I see nothing on Windows Terminal and Mac Terminal. No com ports or /dev/tty.usbmodem?
Did you install the windows usb driver and did you have a Serial.begin() in your code?
yes. but I see nothing on Arduino ide terminal… no port
Does DFU mode work?
Yes, but I can’t see serial monitor and port for Raspberry Pi zero, w, 3.
Core, I can see port and serial monitor.
Does your device manager list the Photon as a device?
Did you flash an code to get an serial output?
if (Serial.available()) {
char ch = Serial.read();
if (ch == '?') {
Serial.print("Hi ParticleIce - running ms()=");
Serial.println(millis());
Serial.println("Hi ParticleIce - type in a '?' and press enter");
delay(2000);
